MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
  • cheebster
    • May 2008
    • 376
    Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
    Nand voltages are missing.
    I've found no shorts at all so far, no signs of heat via thermal camera either.
    PPBUS_G3H 12.31
    PP3V3_G3H_RTC 3.387v
    PP3V3_G3H 12.31v
    PP2v5_NAND_SSD0 0v 58 ohms
    PP2v5_NAND_SSD1 0v 57.8 ohms
    PP1v8_SLPS2R 1.8v
    PP1v1_SLPS2R 1.1v
    P3V3_G3H_SOCPMU 3.37v
    PP0V9_SLPDDR 0.9v
    P3v3_UPC_XA LDO 3.3v
    PP3v3_UPC_XB_LDO
    PP3v3_UPC_TA_LDO
    PP3v3_UPC_TB_LDO
    PP3v3_G3H_T
    Tried revive and restore via apple configurator, fails every time with 4014. Device is detected in DFU mode without me forcing it, booting into it by itself, but i've noticed P2v5_NAND_SSD0/P2v5_NAND_SSD0 ramping up to 2.5v 1 second when trying restore/revive, then back to zero. So it's trying to power on the NANDS, but shutting them off after.
    Anyone has an idea at this point ? Thanks.
  • cheebster
    • May 2008
    • 376
    Re: MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
    Sorry for the missing values for the tests.. the ldo's are all 3.3v.
    • tech_guru
      Macbook Pro 2019 A2141 NAND Shorted
      by tech_guru
      Hello. If you could please help me understand what I am doing wrong...
      This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
      I also replaced the tps power ic for the ssd.
      Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
      08-28-2025, 08:04 AM
    • martyjelen
      Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
      by martyjelen
      Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
      PP3v3_G3H_RTC_X is present - 3,3V
      PP3v3_G3H_SOCPMU is present - 3,3V
      ​What else should I check?
      Thank you for your help.
      05-05-2025, 01:34 AM
    • tranquility
      Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
      by tranquility
      i want to repair an Onkyo TX-NR809 receiver.
      symptoms:
      on power on, display appears and i hear one click. enue functions is given.
      - no hdmi output
      - audio output not tested, but i think it is not there
      - usb sticks are not recognized
      if i read out the chips with display+standby button + tone+
      both dts show only ????
      chip is D830K013BZKB4
      things i have done:
      - reflow of the dts chip without taking off and reballing
      - changed the aluminium caps without the big one with 25v because i dont...
      08-25-2025, 01:04 AM
    • sdogs
      Macbook Pro 15 A2141 820-01700-A stuck at 5V
      by sdogs
      Happy Sunday everyone,
      I have this Macbook Pro 15 A2141 820-01700-A stuck at 5V, it doesn't have any liquid marks or burn marks, I have carefully inspected the logic with the microscope and have not found any anomalies.
      By connecting the usb-c tester I could see that it is blocked at 5v, and as a first measurement I checked PPBUS_G3H which has a voltage value of 0.8v and measured in 0.06 ohm diode mode.
      I read a bit in the forum and I tried to inject 1v on the F7000 not having any current absorption, I then went up to 1.5v and I had a light current absorption (0.10Amp) and...
      09-03-2023, 09:52 AM
    • sdogs
      Macbook Pro 16 A2141 stuck in network boot
      by sdogs
      Good evening guys ;-) In a moment of lucid madness I bought a macbook pro 16 A2141 on which they sat on it. Aside from the banana shape and obviously gone screen, the macbook turns on, sounds the initial gong.
      I disassembled the screen and connected it to an external display, using a usb-c adapter, but I can't reinstall the os.
      I tried SMC and PRAM reset but the result doesn't change, the recovery starts only from the network, I tried different USB pendrives with different operating systems but nothing, it sees the boot device for an instant and immediately goes looking for the network....
      02-25-2023, 11:27 AM
