macbook A2141 - SOUND ISSUE
  • saisoni20
    • Feb 2022
    • 116
    hi ,
    I have A2141 macbook with sound issue. Left speaker is working ok but right is not working.
    After running sudo command it is working good and after sometime is shutoff.
    Anyone facing this kind of issues before?
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • Stephen
    A2141 MacBook Pro 16" lid sensor issue.
    by Stephen
    Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
    11-01-2024, 03:45 PM
  • saisoni20
    MacBook Air A2337 820-02016-07 No sound ISSUE
    by saisoni20
    I have A2337 MacBook Air no sound issue.
    I have replaced new Audio Board but still same issue. I went through repair wiki and checked critical voltages.
    In terms of voltages, I have following voltages,
    1 PP1V25_AWAKE_IO - 1.2V
    2 PP1V25_AWAKE_IO - 1.8V
    3 SPKRAMP_A_OUTP_R - 0V
    ​4 SPKRAMP_A_OUTN_R - 0V
    Am I missing any other critical voltages?
    07-28-2024, 05:53 PM
  • cheebster
    MacBook Pro 2019 A2141 820-01700 NAND Issue Stuck in DFU
    by cheebster
    Ok, here's an issue ive got on a A2141 820-01700 MBP 16' 2019. No signs of life, 5.06v 0.0a on usb-c meter, on each 4 usb-c ports.
    Nand voltages are missing.
    I've found no shorts at all so far, no signs of heat via thermal camera either.
    PPBUS_G3H 12.31
    PP3V3_G3H_RTC 3.387v
    PP3V3_G3H 12.31v
    PP2v5_NAND_SSD0 0v 58 ohms
    PP2v5_NAND_SSD1 0v 57.8 ohms
    PP1v8_SLPS2R 1.8v
    PP1v1_SLPS2R 1.1v
    P3V3_G3H_SOCPMU 3.37v
    PP0V9_SLPDDR 0.9v...
    10-11-2023, 11:31 AM
  • benspawn02
    Anthem MRX500 - no sound. R2A15218FP issue??
    by benspawn02
    Dear Electronics Experts:
    I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
    08-12-2023, 04:46 AM
