MacBook Pro A1990 doest turn on
  • mon2
    • Dec 2019
    • 14157
    Re: MacBook Pro A1990 doest turn on
    No worries. Treat it like a fresh start. It may be easier this time around. At least we got to the 20V on the ports so it is possible.
    Like Lior Raz's TV show - Fauda !!
    • noz_1974
      • Nov 2021
      • 71
      • Israel
      #122
      You Know Fauda
      • mon2
        • Dec 2019
        • 14157
        Love the show - watched all 3-4 seasons of it. It is on our local Netflix. A bit violent but great show. His one in NY is also very good. Former bodyguard of Arnold. Also, Homeland was great (Gideon Raff) - wow!!
        The one goofy part of the show was the little listening bug in the teapot they had in the govt office - sure thing buddy if you can have the range they claim with the coin cell battery
        On the logic board review - after a close visual inspection, if you find an off voltage - check the resistance and also post the DIODE mode reading (red probe to ground; black probe on the part).
        Suspecting that a solder joint or component has broken off during the fall.
        • noz_1974
          • Nov 2021
          • 71
          • Israel
          #124
          Oh boy.
          Check for any damaged parts on the top / bottom of the PCB.
          Post the voltage readings for:
          1) Each CD3215 LDO rail - if any of the rails are OFF or low then stop searching and need to focus on that ACE controller for damaged parts.
          Now i am getting 5v on all USB C ports, and drawing 250mA.
          Lets take for example that U3200 is faulty , Does it means that if i will check UB300 and UB400 LDO rails i will get all four of them ( 2x1.8 , 3.3v and 1.1v) even that the voltage is 5v?
          • mon2
            • Dec 2019
            • 14157
            From the assorted websites, we need to have all LDO rails on each CD3215 working.
            The 5 volts is the default output from the external power adapter. The 1v1 is critical as this is the BMC communication rail for the USB Power Delivery interface. If this is dead then the CC1 & CC2 lines cannot function for that CD3215.
            • noz_1974
              • Nov 2021
              • 71
              • Israel
              #126
              Yes i see, but does it means that if UB300 is good so i will get 1.1V LDO even if this USB C port is taking 5v .And the reason for not getting the 20v is because that we have other CD3215 which is faulty ?
              • noz_1974
                • Nov 2021
                • 71
                • Israel
                #127
                I am not familiar with this show .
                • mon2
                  • Dec 2019
                  • 14157
                  Yes. Check for the presence of the 1v1 LDO rail on each CD3215. It is a great start.
                  Respectively, from our last review, the CD3215 devices are working in pairs. If you do not see 20v on one pair then something is wrong with the CD3215 OR SPI flash OR SMC unable to communicate with the pair.
                  Start with the LDO review and then we can proceed from there. If the LDOs are enabled, then need to check the next step on the SPI flash voltage. Also note, if a part is missing due to the fall, this can of course cause the communication to stop and leave us @ 5 volts.
                  https://www.imdb.com/title/tt9073940...=nm_flmg_act_1
                  • noz_1974
                    • Nov 2021
                    • 71
                    • Israel
                    #129
                    Will Post and update.
                    Will see, thanks for the link
                    • noz_1974
                      • Nov 2021
                      • 71
                      • Israel
                      #130
                      Oh boy.
                      All The LDO rails are on, of course for each ACE when its connected to power adapter
                      2) PPBUS_G3H
                      present : 12.3v
                      3) U2890 flash - each pin
                      Pin1 TBT_X_SPI_CS_L : 3.3v
                      Pin2 TBT_X_SPI_MISO : 3.33v
                      Pin3 TBT_X_SPI_ROM_WP_L :3.34
                      Pin4 GND : 0v
                      Pin5 TBT_X_SPI_MOSI: 1.434v
                      Pin6 TBT_X_SPI_CLK: 1.08v
                      Pin7 TBT_X_ROM_HOLD_L: 3.33v
                      Pin8 PP3V3_UPC_XB_LDO: 3.33v
                      4) UB090 flash - each pin
                      Pin1: TBT_T_SPI_CS_L : 3.34v
                      Pin2: TBT_T_SPI_MISO: 3.34v
                      Pin3: TBT_T_ROM_WP_L : 3.34v
                      Pin4 : GND
                      Pin5 : TBT_T_SPI_MOSI: 1.51v
                      Pin6: TBT_T_SPI_CLK: 1.152v
                      Pin7: TBT_T_ROM_HOLD_L: 3.34v
                      Pin8: PP3V3_UPC_TA_LDO: 3.34v
                      Pin9: GND
                      5)
                      I2C_TBT_T_SCL (RB034, pin #2)
                      I2C_TBT_T_SDA (RB034, pin #2)
                      the voltage is 0v
                      6)
                      I2C_TBT_X_SCL (R2834, pin # 2)
                      I2C_TBT_X_SDA (R2835, pin # 2)
                      the voltage is 0v
                      Hey @mon2,
                      please see my results in bold .
                      Moreover i checked diode mode for the CC1 and CC2 lines:
                      U3100 and U3200 :
                      CC1 : 0.424
                      CC2 : 0.472
                      UB300 and UB400 :
                      CC1 : 0.469
                      CC2 : 0.421
                      thanks
                      • mon2
                        • Dec 2019
                        • 14157
                        I think the diode values look ok.
                        With the power adapter connected, confirm the voltage of each LDO rail on these CD3215 devices. As per before, the LDO rails must be present for each component.
                        • noz_1974
                          • Nov 2021
                          • 71
                          • Israel
                          #132
                          Hey Mon2,
                          The LDO rails are present for each component.
                          same values as before .
                          • noz_1974
                            • Nov 2021
                            • 71
                            • Israel
                            #133
                            Hey mon2,
                            Have you noticed that the values of UB090 and U2890 are little bit different than before ?
                            moreover , i think that i see small fluctuation on the SPI_CLK for both of them .
                            • mon2
                              • Dec 2019
                              • 14157
                              Check to confirm the voltage readings for the local SPI flash rom. Each pair of these devices has a local flash rom (SPI). Do the voltage readings match for either side of the logic board ?
                              Also, have you attempted top / flipped down orientation for each USB port with the adapter ? To check if either side can support 20V ?
                              Check the voltage of PPBUS_g3H. Is it normal ?
                              • noz_1974
                                • Nov 2021
                                • 71
                                • Israel
                                #135
                                Pin4 GND : 0v
                                Pin6 TBT_X_SPI_CLK: 1.08v ( low than before)
                                Pin4 : GND
                                Pin9: GND
                                and PPbus is 12.3V
                                I dont have 20v at all , sutck on 5V 250mA in all four ports
                                • mon2
                                  • Dec 2019
                                  • 14157
                                  Value of PP3V42_G3H ?
                                  Value of SMC_RESET_L ?
                                  Post the voltage readings for the SMC_I2C SDA & CLK lines.
                                  You may have an issue here since the PPBUS_G3H is @ 12v3 and should be 12v6. This higher value is configured using the SMC_I2C lines.
                                  Are these lines @ ~3v3 for each ? If not, remove all power.
                                  Meter in resistance mode (2k scale). Then measure the resistance to ground for these I2C lines again. Post the values.
                                  If the resistance is not too low then there may be a broken part (likely) or trace between the SMC I2C bus master connection to the U7000 device for at least one of these 2 lines.
                                  • noz_1974
                                    • Nov 2021
                                    • 71
                                    • Israel
                                    #137
                                    I dont have this net in my board
                                    Also dont have this net in my board , but i found:
                                    SMC_RSMRST_L = 0v
                                    SMC_SYSRST_L = 0v
                                    Post the voltage readings for the SMC_I2C SDA & CLK lines (I2C_PWR_SCL and I2C_PWR_SDA)
                                    The voltage for those lines is flactuating between 1.784v-1.8v .
                                    i dont think that they are suppose to be 3.3v because they are pulled up to PP1V8_SLPS2R but maybe i am wrong.
                                    the resistnace for I2C_PWR_SCL and I2C_PWR_SDA is 4.9k and 5.2k.
                                    • mon2
                                      • Dec 2019
                                      • 14157
                                      The voltage for those lines is fluctuating between 1.784v-1.8v .
                                      You are so correct. My bad..good readings.
                                      Yes, ignore the other labels - from another logic board.
                                      Post the voltage of CHGR_RST_IN (mates with U7000).
                                      You can measure @ R6940 (check both sides of this resistor).
                                      PS: Will check back later - time to be Arnold movers again - stove time. Bad weather did not allow for it on past weekends.
                                      • noz_1974
                                        • Nov 2021
                                        • 71
                                        • Israel
                                        #139
                                        Hey ,
                                        CHGR_RST_IN and CHGR_RST_IN_R are on 0v.
                                        the resistance to ground of CHGR_RST_IN_R is 54ohm.
                                        VDDA and VDDP of U7000 are on 5V.
                                        And thanks again
                                        enjoy the stove time , sorry but i an not familiar with this expression unless you mean lunch
                                        • mon2
                                          • Dec 2019
                                          • 14157
                                          Hi. No, had to move 2 stoves but it is still too much ice for a safe move so next week..
                                          The above readings are not good.
                                          Pretty sure the reset line to the U7000 is active LOW so this means when the line is LOW (ie. ~0v), then the part will be held in RESET. So this means that the device @ U6940 is also spitting out the 0V.
                                          Confirm that U6940 is being powered. Check the voltage on PP3V3_G3H_RTC_X.
                                          While there, check the voltage of pins 3 & 4 of U6940.
                                          Check that this value matches BOTH sides of R4911.
                                          The resistance to ground of CHGR_RST_IN_R is too low.
                                          Remove the resistor @ R6940 and then check the resistance again for CHGR_RST_IN_R. Is it still very low ?
                                          If yes, remove the resistor @ R6941 and then check CHGR_RST_IN_R resistance to ground again.
                                          Something is causing this line to be with a low resistance to ground. Perhaps U6940 is faulty but try to remove the above parts to see if the resistance on the line can be increased.
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • evandrocarlosv
                                            MacBook Pro A1990 15 2019, motherboard 820-01814-A, won't turn on.
                                            by evandrocarlosv
                                            I have this machine, one of the few that arrives on the bench without a short on PPBUS_G3H. At least these voltages are present. I also have the PP3V3 voltage on L7660 and P5VG3 on L7600. I'm not used to dealing with machines where the shorts are not on PPBUS_G3H, so I need help from my colleagues to analyze where this sequence is failing. From what I've measured, the SSD voltages are fine.
                                            The analyzer shows it as seen in the attached photo....
                                            11-25-2024, 05:23 AM
                                          • alfredodinolfo
                                            MacBook Pro 2019 (A1990)
                                            by alfredodinolfo
                                            mb code:820-01827-A;
                                            sn:C02Z349ALVDR;
                                            i9 32GB Ram 1TB
                                            Hi, I found short on one of 6 black nand (total 1TB).
                                            i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                                            I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                                            macbook with A2141 configuration run on recovery but don't complete it.​
                                            anyone can help me?
                                            05-26-2025, 09:27 AM
                                          • mkdj
                                            MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                            by mkdj
                                            About me, my goal and the equipment I (don't) have:
                                            I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                            About my issue and my goal:
                                            A friend of mine has a MacBook Air M1 A2337 that does not...
                                            04-03-2025, 08:28 AM
                                          • Adogabriel100
                                            Macbook pro A1278 820-2936 No light/turn on
                                            by Adogabriel100
                                            Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
                                            History:
                                            this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
                                            A month later comes back again and has the actual problem (no green/orange light and dont turn on)
                                            The macbook can turn on with only the battery connected but in fact, dosent charge.
                                            Voltajes:
                                            PP3V42_G3H = 3.3v
                                            PPBUS_G3H = 12.2V
                                            PM_PWRBTN_L...
                                            06-28-2023, 07:41 PM
