MacBook Pro A1990 15 2019, motherboard 820-01814-A, won't turn on.
  • evandrocarlosv
    Evandro Carlos
    • Feb 2018
    • 5
    • Brasil
    I have this machine, one of the few that arrives on the bench without a short on PPBUS_G3H. At least these voltages are present. I also have the PP3V3 voltage on L7660 and P5VG3 on L7600. I'm not used to dealing with machines where the shorts are not on PPBUS_G3H, so I need help from my colleagues to analyze where this sequence is failing. From what I've measured, the SSD voltages are fine.
    The analyzer shows it as seen in the attached photo.
  • mon2
    • Dec 2019
    • 14713
    Review these threads:
    https://repair.wiki/w/MacBook_Pro_A1..._at_20V_repair
    https://repair.wiki/w/MacBook_Pro_A1990
    Attempt a DFU for which you will require a good battery with a charge since the power adapter is unable to power the logic board.
    Hunt for any parts with a heat signature if you have a thermal camera.
    • evandrocarlosv
      Evandro Carlos
      • Feb 2018
      • 5
      • Brasil
      Thank you for your response, my friend. It seems we have a corrupted firmware. I looked for shorts using the thermal sensor but didn’t find anything abnormal. I only noticed that Q8102 has a slight heating, but nothing exceeding 30/35°C, almost room temperature. I will try the DFU and post the results.
      • evandrocarlosv
        Evandro Carlos
        • Feb 2018
        • 5
        • Brasil
        Unfortunately, the Mac didn’t respond to DFU mode. So, I returned the device because I believe the issue is with the NANDs. I don’t yet perform replacements or programming of them, so I decided to return it.
        • alfredodinolfo
          MacBook Pro 2019 (A1990)
          by alfredodinolfo
          mb code:820-01827-A;
          sn:C02Z349ALVDR;
          i9 32GB Ram 1TB
          Hi, I found short on one of 6 black nand (total 1TB).
          i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
          I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
          macbook with A2141 configuration run on recovery but don't complete it.​
          anyone can help me?
          05-26-2025, 09:27 AM
        • silver60618
          Macbook Pro A1990 - Battery not detected after connector torn off
          by silver60618
          Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
          Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
          Today, 06:36 PM
        • bouch
          unlock macbook air A1932 2019
          by bouch
          hi
          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
          I need help or information?
          Does anyone have the minat2 activator 1.4 software?
          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
          Thank yo...
          03-12-2025, 10:14 AM
        • robka
          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
          by robka
          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
          After that the Macbook was dead. It isn't charging anymore.
          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
          03-02-2024, 02:58 PM
        • Kristion
          Recognising an item on a MacBook Pro 13" 2020 A2251 motherboard
          by Kristion
          Hi there, I had a MacBook Pro 13" 2020 A2251 at work, and it suddenly stopped working without having being bad to it (I ride my bike everyday though). I replaced the motherboard so now it works again, but with other data. I would like to repair the 661-15938 motherboard. I spotted where it burned, I saw that there is a post where there are the 820-01949 pdf and bvr but I don't know what to do with it. I tried to install OpenBoardView because it seems like it's what I should use to have a look at the schematic view of my motherboard. But I failed:
          But surely some people on this...
          08-13-2024, 11:46 AM
