MacBook Pro A1990 doest turn on
  • Ksansan
    • Jan 2022
    • 19
    • Нидерланды
    #81
    Re: MacBook Pro A1990 doest turn on
    No, that's not our method!
    • noz_1974
      • Nov 2021
      • 71
      • Israel
      #82
      Originally posted by mon2
      Remove all power. Meter in resistance mode.
      Check & post the resistance of
      R3095
      R3096
      R3097
      Hey @mon2,
      the resistance of those resistors is: 15 ohm for each one of them,
      as in the schematic.
      thanks
      • mon2
        • Dec 2019
        • 14217
        The resistance values are good. Do they look to be without damage as far as soldering is concerned ? Just need to be sure that the flash memory device is able to reach these resistors.
        When you connect the power adapter onto one of the non-working CD3215, what is the current draw showing ? You are stuck @ 5 volts and both of these ports have been tested ? The master & slave ?
        What is the voltage on the 1v1 LDO rail for the non-working ports ?
        You may have a firmware fault for the U2890 IC.
        After the above, use the side that is working and post the voltage readings for the ROM on that side. I believe there will be a local rom there as well - my schematic database is having issues but will check it later to confirm the location for the ROM that is local to the other ports.
        • noz_1974
          • Nov 2021
          • 71
          • Israel
          #84
          Hey @mon2,
          1. The resistors are looking good and not damaged.
          2. The faulty CD3215 are stuck on 5.11v-5.12v and drawing 380mA - 390mA. master and slave.
          3. The 1.1 LDO rail is missing for the slave and the master of the non-working ports.
          4. The ROM chip for the working USB C port is UB090. Those ports are stuck on 20.2v and drawing 110mA. The voltage values for the UB090 are:
          Pin1: TBT_T_SPI_CS_L : 3.34v
          Pin2: TBT_T_SPI_MISO: 3.34v
          Pin3: TBT_T_ROM_WP_L : 3.34v
          Pin4 : GND
          Pin5 : TBT_T_SPI_MOSI: 1.48v
          Pin6: TBT_T_SPI_CLK: 1.186v
          Pin7: TBT_T_ROM_HOLD_L: 3.34v
          Pin8: PP3V3_UPC_TA_LDO: 3.34v
          Pin9: GND
          few notes :
          1. The Voltage on the working USB C ports was changed to 20.2v only after replacing the CD3215 ( U3200) before that those ports were also stuck on 5v and draw 380mA-390mA .
          2. the Computer was shut down after that a little bit of water touch the USB C port ( of the faulty CD3215) , this is why i dont think that its a firmware problem , but you are the expert ( can the firmware be damaged from this kind of accident?).
          3. Lets say that the CD3215 is faulty , how can i know if its the U3200 or U3100 that is faulty ?
          thanks
          • mon2
            • Dec 2019
            • 14217
            My schematic service is having connection issues.
            According to the repairwiki on this topic, you may have a fault on the PP2V5_NAND_SSD0 rail.
            See the last case here:
            https://repair.wiki/w/A1990_2018-201...ar_MacBook_Pro
            Measure and post the voltage of this power rail.
            • noz_1974
              • Nov 2021
              • 71
              • Israel
              #86
              Hey @mon2,
              The voltage on PP2V5_NAND_SSD0 rail is 2.524v , no short.
              • mon2
                • Dec 2019
                • 14217
                Voltage value on PPBUS_G3H ? Use the ports that are @ 20V.
                When you attach the power adapter, does the current cycle from 0 to xx mA ?
                Test both of the non-working ports to see if there is a difference in their behaviour.
                For the above PPBUS_G3H measurement, use the side that appears to be working. Just not sure if you need the non-working side to be working to move forward.
                • noz_1974
                  • Nov 2021
                  • 71
                  • Israel
                  #88
                  The voltage value on PPBUS_G3H is 12.6V.
                  • mon2
                    • Dec 2019
                    • 14217
                    With this good PPBUS_G3H value, proceed to check the voltage on each and every coil on the logic board.
                    • noz_1974
                      • Nov 2021
                      • 71
                      • Israel
                      #90
                      Hey @mon2,
                      1. The PPBUS_G3H for all off the USB C ports is 12.6v.
                      2. When i attach the power adapter to the non-working ports i dont see any current cycle , i draw 380mA-390mA but maybe i have a slow USB C volt meter.
                      3. From Louis Rossmann video i need all the USB C to work in order to turn on the MacBook.
                      • noz_1974
                        • Nov 2021
                        • 71
                        • Israel
                        #91
                        From which port to connect the power adapter? does it matter?
                        • mon2
                          • Dec 2019
                          • 14217
                          I would use the 20v group.
                          The ISL9240 is a buck / boost regulator.
                          When you feed it 5v (non-working ports) - this chip boosts the voltage to the desired PPBUS_G3H value.
                          When it is 20v (working ports) - this chip lowers the voltage to the desired PPBUS_G3H value.
                          However, the current that can be supported will be higher when you start with the higher voltage and lower it using the BUCK mode of the regulator.
                          So use the 20v side.
                          • mon2
                            • Dec 2019
                            • 14217
                            Have you tried the SMC Bypass mode ? Press the ON switch on your keyboard and plug in the power adapter. Personally recommend that you use a power bar to turn on the adapter - hate the hot-swapping of the Type C connectors. Keep the ON/OFF button pressed for like 10 seconds. Does this make a difference on the current draw from the side that is ~ 0.1A @ 20V ?
                            Post the voltage readings on both sides of R3041 & R3042
                            Check the resistance to ground of capacitor C3104.
                            Check the resistance to ground of capacitor C3204.
                            These are the caps on each 1v1 voltage rail and are used for the BMC line (CC1/CC2) communication. These rails are @ 0v on the non-working side - why?
                            Try the non-working ports again but flip the adapter cable to test the communication from the other side of the type C connector blade.
                            Any difference on the voltage that is negotiated ?
                            Perhaps your CD3215 @ U3100 is damaged but early to say.
                            If you feel ambitious, you could hot air off the SPI flash that IS working and swap onto the side that is NOT working. Only to test if the contents of the flash chip are the key to get that side to work. Only a suggestion.
                            • noz_1974
                              • Nov 2021
                              • 71
                              • Israel
                              #94
                              Hey mon2 ,
                              I measured the voltages on the coils.
                              also i measured the resistance without power.
                              The voltages on the coils are:
                              For all the coils near the CPU the voltage is zero volt ( 0v).
                              L7410- resistance to ground ( 4.8ohm)
                              L7420- resistance to ground ( 4.8ohm)
                              L7211- resistance to ground ( 2.4ohm)
                              L7221- resistance to ground ( 2.3ohm)
                              L7231- resistance to ground ( 2.3ohm)
                              L7330- resistance to ground ( 14.4ohm)
                              LA340- resistance to ground ( 1.7ohm)
                              LA640- resistance to ground ( 1.7ohm)
                              LA650 - resistance to ground ( 1.7ohm)
                              LA350 - resistance to ground ( 18.9ohm)
                              LA300- resistance to ground ( 292 ohm)
                              L9081 and L9080 - PP2v5_NAND_SSD0 - 2.5v
                              L9020 and L9021 - PP0V9_SSD0 - 0.9v
                              L9030 - PP1V8_SSD0 - 1.8v
                              LB700 - P5UVSBCT_LL - 0v resistance to ground 13.4K
                              L7660 - PP3V3_G3H_T - 3.3v resistance to ground 100K
                              L7600-PP5V_G3S - 5v resistance to ground above 25k
                              L8102-PP0V95_S0_CPUVCCIO - 0v resistance to ground above 49ohm
                              L7030 - CHGR_PHASE1 - 12.48 resistance to ground 200K
                              L7701 - P1V2_PHASE - 0V resistance to ground 138ohm
                              L8410 - PPVIN_S0SW_LCDBKLT- 0v resistance to ground above 300k
                              L6961 - PP3V3_G3H_RTC_REG - 3.34v resistance to ground above 50k
                              L6960 - PP3V3_G3H_RTC_REG - 3.34v resistance to ground above 50k
                              coils from the other side:
                              LA900 - PP1V8_GPU -0v
                              L7700 - P2V5S3_REG- 0v
                              L3500- P5VUSBC_X_LL - 0v
                              • noz_1974
                                • Nov 2021
                                • 71
                                • Israel
                                #95
                                The resistance on those capacitors is 198K.
                                • noz_1974
                                  • Nov 2021
                                  • 71
                                  • Israel
                                  #96
                                  Hey mon2 ,
                                  I also followed the power rail sequence from 820-01598 data sheet that i found.
                                  I have all the rails up to the stage of : SMC BEGINS PWRBTN MONITORING.
                                  THE PMU_ONOFF_L is 3.38v but :
                                  1. PP3V3_S5 is 1.329v
                                  2. PP1v8_S5 is 0.44v.
                                  • mon2
                                    • Dec 2019
                                    • 14217
                                    Remove all power.
                                    Measure and post the resistance to ground for each of these rails.
                                    • noz_1974
                                      • Nov 2021
                                      • 71
                                      • Israel
                                      #98
                                      Hey @mon2,
                                      I decided to check and compare QB400 and Q3100 and Q3200 .
                                      Those chips as i see it are responsible to deliver 20v to the board ( PPDCIN_G3H).
                                      the results on the working USB C , QB400 :
                                      1. UPC_TB_GATE1 : 26V ( FROM CD3215)
                                      2. UNCONNECTED
                                      3. UNCONNECTED
                                      4. UPC_TB_GATE2 : 22.5V ( FROM CD3215)
                                      5/6/7 : PP20V_USBC_TB_VBUS: 20.37V
                                      8: PPDCIN_G3H: 20.37V
                                      the results on the un working USB C , Q3100 :
                                      1. UPC_XA_GATE1 : 10.83V ( FROM CD3215)
                                      2. TP_Q3100_DRAIN: 5.11 V
                                      3. UNCONNECTED
                                      4. UPC_XA_GATE2 : 8.27V ( FROM CD3215)
                                      5/6/7 : PP20V_USBC_XA_VBUS: 5.11V
                                      8: PPDCIN_G3H: 5.11V
                                      the results on the un working USB C , Q3200 :
                                      1. UPC_XB_GATE1 : unable to measure ( FROM CD3215)
                                      2. TP_Q3200_DRAIN: 5.11 V
                                      3. UNCONNECTED
                                      4. UPC_XB_GATE2 : 6.87V ( FROM CD3215)
                                      5/6/7 : PP20V_USBC_XB_VBUS: 5.11V
                                      Is it helpful in any way?
                                      • noz_1974
                                        • Nov 2021
                                        • 71
                                        • Israel
                                        #99
                                        Remove all power.
                                        the resistances are:
                                        For PP3V3_S5 - 74K
                                        For PP1v8_S5 - 23.33K
                                        • mon2
                                          • Dec 2019
                                          • 14217
                                          Place the meter in diode mode.
                                          Remove all power. Red meter probe to ground.
                                          Black meter probe to CC1 pin of the cd3215. Value?
                                          Repeat for the CC2 pin.
                                          Repeat for each cd3215. Post the measurements.
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • evandrocarlosv
                                            MacBook Pro A1990 15 2019, motherboard 820-01814-A, won't turn on.
                                            by evandrocarlosv
                                            I have this machine, one of the few that arrives on the bench without a short on PPBUS_G3H. At least these voltages are present. I also have the PP3V3 voltage on L7660 and P5VG3 on L7600. I'm not used to dealing with machines where the shorts are not on PPBUS_G3H, so I need help from my colleagues to analyze where this sequence is failing. From what I've measured, the SSD voltages are fine.
                                            The analyzer shows it as seen in the attached photo....
                                            11-25-2024, 05:23 AM
                                          • alfredodinolfo
                                            MacBook Pro 2019 (A1990)
                                            by alfredodinolfo
                                            mb code:820-01827-A;
                                            sn:C02Z349ALVDR;
                                            i9 32GB Ram 1TB
                                            Hi, I found short on one of 6 black nand (total 1TB).
                                            i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                                            I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                                            macbook with A2141 configuration run on recovery but don't complete it.​
                                            anyone can help me?
                                            05-26-2025, 09:27 AM
                                          • mkdj
                                            MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                            by mkdj
                                            About me, my goal and the equipment I (don't) have:
                                            I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                            About my issue and my goal:
                                            A friend of mine has a MacBook Air M1 A2337 that does not...
                                            04-03-2025, 08:28 AM
                                          • Adogabriel100
                                            Macbook pro A1278 820-2936 No light/turn on
                                            by Adogabriel100
                                            Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
                                            History:
                                            this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
                                            A month later comes back again and has the actual problem (no green/orange light and dont turn on)
                                            The macbook can turn on with only the battery connected but in fact, dosent charge.
                                            Voltajes:
                                            PP3V42_G3H = 3.3v
                                            PPBUS_G3H = 12.2V
                                            PM_PWRBTN_L...
                                            06-28-2023, 07:41 PM
