The MacBook was initially drawing only 5 V. After removing C9081, it now draws 20 V, but the current remains at only 0.05 A, and the MacBook still does not power on.
A1990 Macbook Pro Doesn't Turn On
Tags: None
Review the voltage to ground for the following points of interest on the battery connector:
SMBUS_3V3_BATT_SCL
SMBUS_3V3_BATT_SDA
This case may be linked to corrupt T2 firmware:
(see last discussion)
https://repair.wiki/w/MacBook_Pro_A1...k_at_5V_repairComment
by silver60618Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...Today, 06:36 PM -
by Ledgurrahello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
thank you all6 Photos -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
I have this machine, one of the few that arrives on the bench without a short on PPBUS_G3H. At least these voltages are present. I also have the PP3V3 voltage on L7660 and P5VG3 on L7600. I'm not used to dealing with machines where the shorts are not on PPBUS_G3H, so I need help from my colleagues to analyze where this sequence is failing. From what I've measured, the SSD voltages are fine.
The analyzer shows it as seen in the attached photo.... -
mb code:820-01827-A;
sn:C02Z349ALVDR;
i9 32GB Ram 1TB
Hi, I found short on one of 6 black nand (total 1TB).
i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
macbook with A2141 configuration run on recovery but don't complete it.
anyone can help me?05-26-2025, 09:27 AM - Loading...
