MacBook Pro A1990 doest turn on
  • mon2
    • Dec 2019
    • 14176
    Re: MacBook Pro A1990 doest turn on
    Post your voltage reading for PP3V3_G3H_RTC_X.
    • noz_1974
      • Nov 2021
      • 71
      • Israel
      #62
      Hey @mon2,
      Before the short the voltage on PP3v3_G3H_RTC_X was 3.3v.
      Does this info helps in anything?
      thanks
      • mon2
        • Dec 2019
        • 14176
        Is it no longer 3v3 ? This is a critical voltage.
        • noz_1974
          • Nov 2021
          • 71
          • Israel
          #64
          Hey ,
          I can measure it .
          But why its important if i cant generate this voltage till i replace the U7650 ( PMIC) ?
          • mon2
            • Dec 2019
            • 14176
            It is ok if you have parts off the logic board. Proceed to replace.
            The PP3v3_G3H_RTC_X is required to power the CD3215 controllers.
            Rail is generated by U6960. Just thought to mention it.
            • noz_1974
              • Nov 2021
              • 71
              • Israel
              #66
              Hey @mon2,
              Finally the parts arrived and i am going to replace them tomorrow.
              But i thought to check with you something.
              As you remember i think that i burned U7650 ( TPS51980A PMIC ), and today i thought that maybe there is also a chance that maybe U7660 (CSD58873Q3D) also was ruined .
              can you please share what is the impedance that should i get when i am measuring this transistor .
              the Macbook is A1990A.
              thanks
              • Ksansan
                • Jan 2022
                • 19
                • Нидерланды
                #67
                Originally posted by noz_1974
                Hey @mon2,
                thanks
                There should not be a short between pin 1 and pin 6.
                It should be hundreds of ohms
                • noz_1974
                  • Nov 2021
                  • 71
                  • Israel
                  #68
                  Hey @mon2 and @Ksansan,
                  Here is an update
                  I replaced U7650 which i shorted and returned to ground zero .
                  Now , all the USB C ports were stuck on 5V and drawing between 370mA to 390mA.
                  From my corresponding with mon2 i started to replace U3200 ( CD3215C).
                  And now this is the situation :
                  U3100 and U3200 USB C ports are stuck on 5V and drawing 370mA-390mA
                  UB300 and UB400 USB C ports are stuck on 20.2V and drawing 110mA.
                  I measured all the LDO voltages from the CD3215 and also the PP3v3_G3H_RTC_x here are the readings :
                  note: in U3100 and U3200 PP1v1_LDO is missing.
                  U3100 :
                  PP3v3_LDO - 3.34v
                  PP1v8_LDOD-1.8v
                  PP1v8_LDOA-1.811v
                  PP1v1_LDO - 0v ( missing)
                  PP3v3_G3H_RTC_X- 3.38v
                  PP1v8_SLPS2R- 1.8v
                  U3200 :
                  PP3v3_LDO - 3.38v
                  PP1v8_LDOD-1.791v
                  PP1v8_LDOA-1.814v
                  PP1v8_SLPS2R- 1.803v
                  UB300 :
                  PP3v3_LDO - 3.34v
                  PP1v8_LDOD-1.789v
                  PP1v8_LDOA-1.795v
                  PP1v1_LDO - 1.113v
                  PP1v8_SLPS2R- 1.786v
                  UB400 :
                  PP3v3_LDO - 3.34v
                  PP1v8_LDOD-1.789v
                  PP1v8_LDOA-1.818v
                  PP1v1_LDO - 1.121v
                  I dont know what happened !! do i still have a problem with the U3200 ?
                  maybe i didnt solder it correctly?
                  please advice
                  • mon2
                    • Dec 2019
                    • 14176
                    Hi. See attached.
                    1) Start with removing all power. Meter in resistance mode (2k scale). Check the resistance to ground for the 1v1 LDO rail for the ports that are not working.
                    What are the readings for each CD3215 1v1 voltage rail ?
                    Next, place the meter in DIODE mode.
                    Then RED METER lead to GROUND.
                    BLACK METER lead to the 1v1 voltage rail. Reading ?
                    Repeat for each CD3215 stuck @ 5v and then for the working CD3215 devices.
                    DO NOT have power to the logic board during these tests.
                    2) Post the voltage reading for PP3V3_G3H.
                    reference:
                    https://repair.wiki/w/Charger_stuck_...nstead_of_20_V
                    • noz_1974
                      • Nov 2021
                      • 71
                      • Israel
                      #70
                      Hey @mon2,
                      Here are the measurements
                      U3100 :
                      PP1V1_LDO impedance is 198k, in diode mode 0.49v
                      U3200 :
                      PP1V1_LDO impedance is 202k, in diode mode 0.49v
                      UB300 :
                      PP1V1_LDO impedance is 201k, in diode mode 0.49v
                      UB400 :
                      The PP3V3_G3H_T is 3.34v .
                      thanks
                      • mon2
                        • Dec 2019
                        • 14176
                        Post the voltages on each pin of the SPI ROM used by the CD3215 (non-working) @ U2890.
                        See attached. You can measure at the resistors.
                        • noz_1974
                          • Nov 2021
                          • 71
                          • Israel
                          #72
                          Hey @mon2,
                          here are the results for U2890 , DC measurements:
                          Pin1 TBT_X_SPI_CS_L : 3.3v
                          Pin2 TBT_X_SPI_MISO : 3.33v
                          Pin3 TBT_X_SPI_ROM_WP_L :0.726v
                          Pin4 GND : 0v
                          Pin5 TBT_X_SPI_MOSI: 0v
                          Pin6 TBT_X_SPI_CLK: 0.07v
                          Pin7 TBT_X_ROM_HOLD_L: 3.33v
                          Pin8 PP3V3_UPC_XB_LDO: 3.33v
                          thanks
                          • mon2
                            • Dec 2019
                            • 14176
                            Remove all power. Meter in resistance mode.
                            Check & post the resistance of
                            R3095
                            R3096
                            R3097
                            • noz_1974
                              • Nov 2021
                              • 71
                              • Israel
                              #74
                              Hey @mon2,
                              Will do , but unfortunately I could do it only tomorrow . Thank you a lot for your support.
                              By the way , is it normal that one side of the USB C controller is stuck on 20v and the other side is stuck on 5v ? Does it means that I succeed to replace U3200 , because the other side of the USB C port are now on 20v ?
                              • mon2
                                • Dec 2019
                                • 14176
                                U3100 & U3200 are paired together. They need to function together to allow for the 20V selection. Since this side of the USB C ports is stuck @ 5 volts, there is some issue.
                                From my understanding:
                                1) U3200 is the MASTER controller & U3100 is the SLAVE controller.
                                2) U3200 is looking to extract firmware from an external SPI flash device @ U2890. Presently, your CLK and MOSI (Master Out; Slave in) are showing the wrong voltages. It is possible that they are 0v because the MASTER controller gave up searching for the flash memory chip. TBD.
                                3) After the firmware is extracted from U2890, then this MASTER device will communicate with the SLAVE controller @ U3100 over the UART lines (TX & RX) to send out the firmware details to the slave device.
                                UPC_XA_UART_TX
                                UPC_XA_UART_RX
                                will be used.
                                If any of these fail, then the 1v1 LDO rail will not function.
                                To add to this, the CD3215 itself could be defective. Is your source for the part a known good vendor ? Just asking but basing this concern from assorted postings.
                                4) For the soldering, consider to flux the replaced part well, hot air the part in circles and use tweezers to nudge the corners till the part moves on its own. Then it should spring back into place, naturally. This is a great method to allow for any shorts to correct themselves underneath the BGA device. It is worth a go to try this process.
                                Apply aluminum foil onto the parts you wish to protect. Be sure there is no power to the board. Or use kapton (polymide) tape for the same purpose.
                                5) It is good to have the 20V on the other ports and that may be all we need to move forward, for now. Perhaps others have additional feedback.
                                • noz_1974
                                  • Nov 2021
                                  • 71
                                  • Israel
                                  #76
                                  Hey @mon2,
                                  I ordered my parts from Louis Rossman store and also from beetstech, so no concern here.
                                  I was wondering about the 20V on UB300 and UB400 only because they were also stuck on 5v and draw 380mA-390mA before the replacement of U3200.
                                  I will measure the resistors tomorrow and will update you .
                                  If I need to re-hot / re solder U3200 I will do it .
                                  • noz_1974
                                    • Nov 2021
                                    • 71
                                    • Israel
                                    #77
                                    Question about this : The kapton didn’t succeed to prevent from the heat to “melt” the RF shield a little bit . Is it a problem ? Can I replace the shield ? And if I can, from where I can order it ?
                                    • mon2
                                      • Dec 2019
                                      • 14176
                                      No need to replace the RF shield. Continue to use as-is.
                                      • Ksansan
                                        • Jan 2022
                                        • 19
                                        • Нидерланды
                                        #79
                                        I've got a damn power button that doesn't work.
                                        That's bad!
                                        • mon2
                                          • Dec 2019
                                          • 14176
                                          Apple repairs...
                                          https://www.youtube.com/watch?v=NWsgBqNuVEk
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • evandrocarlosv
                                            MacBook Pro A1990 15 2019, motherboard 820-01814-A, won't turn on.
                                            by evandrocarlosv
                                            I have this machine, one of the few that arrives on the bench without a short on PPBUS_G3H. At least these voltages are present. I also have the PP3V3 voltage on L7660 and P5VG3 on L7600. I'm not used to dealing with machines where the shorts are not on PPBUS_G3H, so I need help from my colleagues to analyze where this sequence is failing. From what I've measured, the SSD voltages are fine.
                                            The analyzer shows it as seen in the attached photo....
                                            11-25-2024, 05:23 AM
                                          • alfredodinolfo
                                            MacBook Pro 2019 (A1990)
                                            by alfredodinolfo
                                            mb code:820-01827-A;
                                            sn:C02Z349ALVDR;
                                            i9 32GB Ram 1TB
                                            Hi, I found short on one of 6 black nand (total 1TB).
                                            i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                                            I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                                            macbook with A2141 configuration run on recovery but don't complete it.​
                                            anyone can help me?
                                            05-26-2025, 09:27 AM
                                          • mkdj
                                            MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                            by mkdj
                                            About me, my goal and the equipment I (don't) have:
                                            I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                            About my issue and my goal:
                                            A friend of mine has a MacBook Air M1 A2337 that does not...
                                            04-03-2025, 08:28 AM
                                          • Adogabriel100
                                            Macbook pro A1278 820-2936 No light/turn on
                                            by Adogabriel100
                                            Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
                                            History:
                                            this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
                                            A month later comes back again and has the actual problem (no green/orange light and dont turn on)
                                            The macbook can turn on with only the battery connected but in fact, dosent charge.
                                            Voltajes:
                                            PP3V42_G3H = 3.3v
                                            PPBUS_G3H = 12.2V
                                            PM_PWRBTN_L...
                                            06-28-2023, 07:41 PM
