Replace BQ24781 with BQ24780?
  • Antonynl
    • Apr 2021
    • 74
    • Nederland
    Can I replace a BQ24781 with a BQ24780?
    I can't find a datasheet on the BQ24781 by the way.
    Thanks!
  • R_J
    • 9526
    Re: Replace BQ24781 with BQ24780?
    I found this https://e2e.ti.com/support/power-man...81-description
    Information from the TI forum:
    They are family parts, with minor difference on the switching frequency. BQ24781 supports 300kHz/400kHz lower switching frequency options. For your information, BQ24800 has better accuracy and improved performance.
    BQ24781 datasheet is not available online. Please use BQ24780S. They have the same SMBUS address, default values and options.
    Not sure if this is helpful or not.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Yes, BQ24780 can be replaced with BQ24781 but if it has "S" suffix(Like BQ24780S) then it has to be replaced with same suffix.
      • Antonynl
        • Apr 2021
        • 74
        • Nederland
        Ok thank you.
        What is the significance of the "S" suffix by the way?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          https://www.badcaps.net/forum/showthread.php?t=74599
          follow this thread. there a table is listed about the difference by "bluemidnight"
          • dutchgaucho
            • 57
            • The Netherlands
            For whom this might be of interest: just replaced BQ24781 successfully by a BQ24780s on an Asus TP412UA. Thanks guys!
            • samick
              • Jun 2015
              • 5
              • us
              I have an Acer Aspire A515-43 that would not charge the battery. Acts like power cord is being unplugged & plugged. Also, if running only on AC and laptop is powered on, if battery is plugged in, system powers off without warning after a couple seconds.
              I replaced the charge controller BQ24781 with a BQ24780s and it now charges the battery.
              • J#26
                • Apr 2021
                • 8
                • Philippines
                Thanks for this INFO
                ..cant find BQ24781..
                • mon2
                  • Dec 2019
                  • 13875
                  US $3.76 18%OFF | (1piece) 100% New BQ24781RUYR BQ24781 QFN-28 Chipset
                  https://a.aliexpress.com/_mscjb28
                  • m3zharan
                    • Mar 2021
                    • srilanka
                    thaks for the informetion. im also finding a bq24781
                    • junior_desampa
                      • Aug 2022
                      • 29
                      • Brasil
                      Same thing here on the Acer a315.. but the customer's battery seems to have a problem.. still need to check
                      • mon2
                        • Dec 2019
                        • 13875
                        Check the voltage to ground of each pin on the battery connector. Need to be sure the smbus lines are not shorted due to an ESD transient event. Check the SCL and SDA pins.
                        • REpairAT
                          • Nov 2020
                          • 142
                          • Austria
                          Can confirm, it's also compatible the other way around. Just replaced BQ24780S with BQ24781.
                          • tomodachi
                            • Apr 2012
                            • 593
                            • Turkey
                            Can also confirm. Just replaced BQ24781 with BQ24780s and it worked.
                            • DonRusak
                              • Feb 2025
                              • 3
                              Ordered a BQ24780 and they sent me a BAA78C. Are these the same / interchangable? The BAA78C seems smaller and would obviously cause troubles when being replaced.
                              • tomodachi
                                • Apr 2012
                                • 593
                                • Turkey
                                if there is doubt do not use it
