BQ24780 VS BQ24780s Power IC?
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Hello There
    I Have a Some Question About this 2 IC. BQ24780 & BQ24780S
    1.It is A Same Operation? Or Compatible?
    2.BQ24780S Can Replace this IC BQ24780?
    3.What is the Meaning Of "S". On This IC.
    Thank for Reply.
    also do you have Data Sheet of this BQ24780.
    Thank
  • dj_ricoh
    • 2073
    • uk
    Re: BQ24780 VS BQ24780s Power IC?
    It's saying in the pdf that the S its a better version. A new model.
    • BlueMidnight
      • Jan 2015
      • 489
      This is the only information I could find on the non-'S' version. I would not consider them compatible given the differences listed. Most importantly, the power monitoring signal apparently works differently. That could cause some weird behavior.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Extracted from schematic. See if it helps. Charger IC is bq24780
        • lorins_core
          BlackSmith
          • Dec 2012
          • 552
          • Philippines
          Thanks DJ...
          • lorins_core
            BlackSmith
            • Dec 2012
            • 552
            • Philippines
            Thanks For this Table. Now Iknow the Operation of this IC...
            • lorins_core
              BlackSmith
              • Dec 2012
              • 552
              • Philippines
              Thanks For This i appreciate.
              • vlado159
                • May 2015
                • 1
                • Slovakia
                Hi
                ASUS FX502VD Rev 2.0
                Original BQ24780S replaced with BQ24780 working OK.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Replacing BQ24780S with BQ24780 works on some board but dont wont work on many others. So its mixed bag. Instead of getting confused, replacement ic should be of same specs.
                  • bambangwa
                    • Oct 2016
                    • 12
                    • indonesia
                    Originally posted by vlado159
                    Hi
                    my problem not charging. what solusion? any help
                    • bembeno
                      • Feb 2016
                      • 311
                      • egypt
                      need datasheet for BQ24780 Charging ic
                      need datasheet for BQ24780 Charging ic and can i use BQ24780S instead of BQ24780 ?
                      • mon2
                        • Dec 2019
                        • 14659
                        Re: need datasheet for BQ24780 Charging ic
                        Yes, you can use the BQ24780S to replace the BQ24780 original. The BQ24780S datasheet can be found on the TI / Digikey / Mouser / this forum websites.
                        Reference (BQ24780S vs. BQ24780):
                        https://e2e.ti.com/support/power-man...end%20BQ24780S.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                          09-06-2024, 05:59 AM
