Hp ZBook 17 g3 battery not charging issue
  • Neddsme
    • Sep 2021
    • 30
    • Malawi
    I have the laptop mentioned in the title and i am in a bit of a pickle. The laptop Power circuit got fried after someone messed with the charger and the DC input MOSFETS were toasted. I replaced them but now it turns on and works on charger only after bypassing the FETS, they dont turn even though the charger LED is ON. The bettery on the other hand no longer charges at all.
    After a series of multimeter testing I concluded there is no more short but the BQ24780 chip is looking suspicious to me. Here are some voltage readings i think are relevant;
    ACN ~ 19.7v
    ACP ~ 19.7v
    ACDRV ~ 0.4v
    ACOK ~ 2.2v
    ACDET ~ 2.6v
    BATPRES ~ 0.0v (with or without battery)
    BATSRC ~ 0.22v
    BATDRV ~ 0.25v
    SRN ~ 0.22v
    SRP ~ 0.22v
    ILIM ~ 3.37v
    LODRV ~ 0.0v
    REGN ~ 6.0v
    BTST ~ 5.73v
    HIDRV ~ 0.22v
    PHASE ~ 0.22v
    VCC ~ 19.15v
    ACDRV & BATDRV resistance ~ 4.3Kohms
    I have not worked much with this chip so I wouldnt know how a faulty one typically behaves. I dont have a spare on hand to simply try and replace it so it would be great to know if it definitely needs to be replaced or if its a different issue before i go ahead and purchase a replacement.
  • mon2
    • 14512
    1) Do not bypass the DCin mosfets.
    2) Are the DCin mosfets the proper ones for this charger IC? They should be N-channel type. Be sure they are soldered in the proper direction like the originals.
    3) The gate voltge is driven by ACDRV on the charger IC. This ACDRV voltage should be ~25v = adapter voltage + REGN voltage = 19 + 6 = 25v. Only then will the 2 x DCin mosfets enable. Study the datasheet from TI to learn the conditions to drive the ACDRV voltage which is at 0v. Check CMSRC voltage.
    4) Other voltages look ok. It is also possible that the charger IC believes there is an excessive current draw so it powers down the ACDRV voltage for safety. Confirm the full path resistance of ACP/ACN. Do the same for the battery charge leg current sense resistors. Each check with NO power / NO battery to the board.
    • Neddsme
      • Sep 2021
      • 30
      • Malawi
      Thanks for the swift reply!
      1, the bypass of the DC-in was really just a hypothesis test on whether the laptop was dead and not a solution. I know very well the importance of the seemingly "unimpressive" DC-in FETs
      2, Yes the FETs are known good N-type equivalents. and the drain of the FETs makes it next to impossible to solder it the wrong way, the drain is most of the pad.
      3. the CMSRC voltage is at 0.22v
      4, the ACP/ACN is both 100.5 ohms
      5, the SRN/SRP is 0.1 ohms and 0.2 ohms
      • piernov
        • Jan 2016
        • 4437
        • France
        Measurements must be taken without the DC-in MOSFET bypass, otherwise they are meaningless.
        • mon2
          • 14512
          ?? Confirm that this measurement is with the meter probes directly on ACP and ACN pins of the charger IC to measure the current sense path resistance. This measurement is too high if being measured in this manner. Remove all power during these resistance tests.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Do you mean resistance to Ground on ACP/ACN measured each at a time or you mean resistance between ACP/ACN pins?
            If its the former,then you have short on main power rail ,ie, +19V rail.
            If its the later option,then check continuity between ACP/ACN pins to CLR.
            However, i think you mean the former option.
            • Neddsme
              • Sep 2021
              • 30
              • Malawi
              Yes, i removed the bypass after verifying it turned on then started taking all these various measurements.
              • Neddsme
                • Sep 2021
                • 30
                • Malawi
                Unless I am doing it wrong, but the ACN and ACP pins on the IC have some resistors in series with the tracks on the path to the current sensing resistor. the current sense resistor measures 0.5 ohms on its own but measuring from the pins of the IC to the current sense points I get 100.5 ohms. And yes this is with power removed. the only measurements taken with power were voltage readings.
                I am assuming there are 100 ohm resistors added to the path maybe? IDK
                • Neddsme
                  • Sep 2021
                  • 30
                  • Malawi
                  For the ACN/ACP measurements it was from the pins of the IC to the CLR.
                  Just to make sure I retook the measurements;
                  ACN/ACP to GND = OL
                  CLR ~ 2 ohms
                  ACN to ACP on the IC ~ 200.6 ohms
                  ACN/ACP to CLR ~ 100.5 ohms
                  The resistor in between CLR and IC ~ 100.4 ohms
                  There is no short to ground, just an "odd addition" of 100 ohm resistors to the ACN/ ACP path.
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    Then if 19V goes through the DC-in MOSFETs but ACDRV is not turning them on, most likely there's still a problem with the DC-in MOSFETs.
                    • mon2
                      • 14512
                      Any chance that you have the schematics for this laptop? Link it if available but post the schematic in the dedicated schematic forum. Respectively, check the resistors that should be present in the current sense path between ACP / ACN pins. Sounds high to me if @ 100R ohms.
                      • Neddsme
                        • Sep 2021
                        • 30
                        • Malawi
                        NEW DEVELOPMENTS
                        Yes! as it turns out there was a broken track on CMSRC, probably it suffered some physical damage during disassembly.
                        After finding the anomaly and fixing it, there are some new readings now.
                        ACN ~ 19.7v
                        ACP ~ 19.7v
                        CMSRC ~ 19.7v
                        ACDRV ~ 25.4v
                        ACOK ~ 2.3v
                        ACDET ~ 2.7v
                        BATSRC ~ 12.0v
                        BATDRV ~11.99v
                        SRN ~ 11.98v
                        SRP ~ 11.99v
                        ILIM ~ 3.37v
                        LODRV ~ 0v
                        REGN ~ 6.0v
                        BTST ~ 5.74v
                        HIDRV~ 12.33v
                        PHASE ~ 12.01v
                        VCC ~ 19.16v
                        I don't know the specifics but i assume this looks like a good BQ chip. However the BATDRV, BATSRC, AND PHASE look off in my opinion but i could be wrong.
                        The battery is a 96Whr 11.4v nominal voltage battery which i assume charges at around 13.05VDC (info on the battery itself).
                        So 12.0v on the battery terminals looks kinda low to me. But this is with the battery unplugged. Infact all those readings above are with the battery unplugged. When the battery is plugged in the story is a bit worse;
                        The Battery terminals stay at around 0.22v for the first milliseconds after plugging in the charger, then it spikes to around 9.90v before it drops back down to 0.22v
                        During this time, the following readings are registered;
                        BATSRC ~ 0.22v
                        BATDRV ~ 0.25v
                        SRN ~ 0.22v
                        SRP ~ 0.22v
                        PHASE ~ 0.22v
                        The rest of the measurements are as before only the ones related to the battery change when the battery is connected.
                        The battery charging light also stays amber throughout when the battery is unplugged but turns off after that spike to 9.90v when the battery is connected which seems odd as if its shutting down the battery circuit on purpose.
                        Lastly, i tried taking a look at the battery itself. i found it in a discharged state. >2.7v each cell. I brought back up the cell voltage with a custom balance charger i have for other projects to around 3.8v on all cells which should wake up most batteries but in this case i fear maybe the battery is done for? IDK the battery pack was still in good shape pulling 4-5 hrs on a heavy system like this before the whole charger fiasco happened.
                        I tried pulling a battery report and I get a report which shows the battery with 15% and 530 cycles but no prior information as it was a fresh windows installation. My assumption is that there is still some life in the battery.
                        What are your thoughts, and what are other things i can check for?
                        Is the battery charging portion of the BQ chip acting like its supposed to or something is still not right?
                        • Neddsme
                          • Sep 2021
                          • 30
                          • Malawi
                          Unfortunately i don't have the schematic. that would have saved me a lot of guess work. I did a search on the forums and someone already posted a request for this specific model's schematic and boardview but nothing turned up so i didn't want to create a redundant thread. I am keeping tabs on that thread incase someone finds it.
                          As for the resistors, i am just as puzzled as u are why the implementation has 100 ohm resistors on it. the battery current sense path does not have these resistors only the AC side. A guess would be maybe coz its a heavy power system? it uses like a 150Watt adapter and using anything below that the system does not turn on at all. (I tried with 45W though so maybe 65W might work IDK. But this also means it can identify chargers as its supposed to making me believe the BQ chip is definitely alive)
                          • mon2
                            • 14512
                            ACOK looks low. Study this pin and locate a pull up resistor used to park this line. It should most likely be to a 3v3 rail but you have 2v3. This may be due to a defective always rail. Measure the voltage on each side of this resistor.
                            • piernov
                              • Jan 2016
                              • 4437
                              • France
                              Still doesn't make a lot of sense because that would indeed confirm ACDRV wasn't working, but then the DC-in MOSFETs should have been turned off (at least the one placed with the body diode in reverse) and no voltage should have been measured after them.
                              Also the measurements must be taken again after charging the battery cells.
                              • Neddsme
                                • Sep 2021
                                • 30
                                • Malawi
                                Yes the 2.3v is coming from a rail with 3.38v. the resistor in between is 15K (resistance measured while power is disconnected).
                                • mon2
                                  • 14512
                                  ACOK is an open drain signal. If the charger believes the power adapter source is OK, then this output signal line will float. Then the park voltage will be based on the pull-up resistor + pull-up voltage (3v3) and the load on this line. On a good board, this line should be ~3v3 but you have 2v3.
                                  Remove all power. Measure the resistance to ground of this same ACOK pin. Also check it in diode mode. Meter in DIODE mode. Red meter probe to ground. Black meter probe on ACOK pin. Post both measurements. Perhaps someone using this ACOK status is defective.
                                  • Neddsme
                                    • Sep 2021
                                    • 30
                                    • Malawi
                                    Yes that's true. The DC-in mosfet source and drain was shorted. I didnt pick that up initially because it did not short to ground. I replaced it along with fixing the CMSRC track.
                                    This circuit is becoming a bunch of spaghetti now. a schematic would have made things a bit simpler lol.
                                    The battery pack is perfectly balanced at 3.69v but does not output voltage
                                    from the report it shows 10% charge. could it be locked?
                                    • Neddsme
                                      • Sep 2021
                                      • 30
                                      • Malawi
                                      In diode mode there is .463 voltage drop
                                      in resistance it reads 12.4K
                                      • mon2
                                        • 14512
                                        Yes. Test with a known good battery. Amazon? The ACOK voltage is lower than normal. Perhaps consider to replace the pull-up resistor with another. The value is not critical. Test with a 10k or 4k7 or 2k7, etc.
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                          HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                                          This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-07-2024, 05:20 AM
