Help to identify an smd component 330 2R0
  • JuanL
    • Dec 2021
    • 14
    • Spain
    I haven't worked with electronic components in years and some of the current smd's are difficult for me to identify. In this case, is it a capacitor? which measures 4.5 x 7.4 mm. and is 1.9mm thick.
    The text on it is: 330 then comes a logo and follows 2R0 and below G39.
    Can you help me to identify it?
    This is to order the spare part because this one has a short circuit and the encapsulation is open.
    Thanks in advance.
  • Repdata
    • May 2020
    • 67
    • Deutschland
    Re: Help to identify an smd component
    what kind of name is on the board ?
    • mon2
      • Dec 2019
      • 14047
      Appears to be a 330uf tantalum cap.
      Does it have 2 leads (top side & bottom side) ?
      Then it is a capacitor. Post more pix from the other side of the part.
      • R_J
        • 9535
        SMD CAP Aluminum Solid Electrolytic Capacitor - ECAS series
        • JuanL
          • Dec 2021
          • 14
          • Spain
          Sorry but there is no printing on the motherboard component.
          • mon2
            • Dec 2019
            • 14047
            @R_J has nailed it. He wins the washer & dryer
            • JuanL
              • Dec 2021
              • 14
              • Spain
              An complete view of this small motherboard.
              Fron the information posted by J_R (thanks) I assume my cap has to be ECASS‐331E09 and triyin to get some on Google I only find the flier with the specs.
              Could some of you teach a newby how to purchase a cap with this specification number, please?
              • mon2
                • Dec 2019
                • 14047
                https://www.digikey.ca/en/products/d...E331XE/1731687
                • JuanL
                  • Dec 2021
                  • 14
                  • Spain
                  I have spent a few hours searching for this component. Digi-Key, Mouser, Farnel have them but they have to be imported into Europe:
                  https://www.digikey.es/es/products/d...AzGgjAlIC6AvkA
                  https://www.mouser.es/ProductDetail/667-EEF-SX0E331XE
                  https://es.farnell.com/en-ES/panason...917/dp/2358262
                  Considering a purchase of 10 units, the cost of shipping, import costs and VAT exceeds 60 U$.
                  Neither Ebay nor Amazon offer me alternatives.
                  Importing from China is an option, but the supply of
                  Aluminum Organic Polymer Capacitors is closed to only some values, 100 uF.
                  Coul use instead a Tantalum capacitor ? v.g. https://tinyurl.com/bdzczzkj
                  Thanks in advance
                  • mon2
                    • Dec 2019
                    • 14047
                    Hi. Important factors for selecting this component are:
                    a) physical size. So you can solder back onto the same and pads with ease. The replacement appears to be a drop in replacement as the datasheet shared by @R_J.
                    b) the capacitance. It is the same.
                    c) the rated voltage. It is the same.
                    d) the ESR value. The lower the better. Lower ESR means higher current can be supported without damage. Respectively, too low of current support will damage the part as the switching power rail turns on / off during normal operation. This Panasonic replacement is a valid match. The AliExpress is rated at 5-6 ohms for the ESR so is not suitable. The Panasonic replacement is about 6 milli-ohm.
                    Arrow shows stock:
                    https://www.arrow.com/en/products/ee...nic?region=nac
                    What is the max dollar / euro value you can import without extra fees? Do you have to pay VAT on all purchased goods?
                    We have a free world-wide shipping account with Arrow. Can try to send to you by drop shipping it with FedEx.
                    Let us try if it makes sense. Send me a PM if interested.
                    Arrow is the real deal and will not be a fake part.
                    • JuanL
                      • Dec 2021
                      • 14
                      • Spain
                      The cost begins to rise when considering import taxes (perhaps avoidable due to the low cost of the merchandise); import cost fee (minimum € 6 for anything) and shipping costs (DHL, FedEx and UPS).
                      To the resulting total, 21% VAT must be added.
                      So 5 units (5 x € 1.12 = € 5.60); shipments = € 14; VAT = € 4.12 .... total = € 23.72 (27 U$). Then add the curier cost and the bill rises to near 50U$.
                      Arrow also works in Europe and I have a processor and a request that if I have not misunderstood, it costs me 13.90 U $, which I think is acceptable for 5 capacitors Panasonic EEF-SX0E331XE.
                      I await the progress of the order.
                      Thank you for your willingness and I hope I can correspond in a similar way in another case, but I want to learn to be able to collect the components, if possible in my environment.
                      Customs are a pain in the neck.
                      Thanks once more for your collaboration.
                      Merry Christmas
                        • 20732
                        Have you checked rs-online and conrad
                        https://es.rs-online.com/web/c/compo...056,4294417066
                        https://www.conrad.com/p/wurth-elekt...-1-pcs-1925743
                        • mosfetratus
                          Sure Not
                          • Feb 2019
                          • 174
                          • Resistron
                          Merry Christmas
                          i ordered stuff from digikey, above 50 euro is free shipping, add VAT according to your country, is added at the checkout, very simple. Import duties are handled and covered by digikey itself. So no headache.
                          Grab ifixit tool kit to inflate to minimum of 50 euros, or whatever.
                          • JuanL
                            • Dec 2021
                            • 14
                            • Spain
                            Thaks for the help. I've been sollecting information aboutr import rules:
                            Product value Commercial shipping
                            • From 0 to 22 euros --> No duties or VAT are paid
                            • From 22 to 150 euros --> VAT is paid
                            • More than 150 euros --> VAT and a minimum tariff of 2.5% are paid
                            So, better to be below 22 € (25 U$).
                            Thanks to all of you and Merry Christmas.
                            Be good. stay safe
                            • piernov
                              • Jan 2016
                              • 4435
                              • France
                              Re: Help to identify an smd component 330 2R0
                              Since 1st July 2021 in all EU countries VAT has to be paid even for products below 22 €, but the VAT is collected by the seller for B2C.
                              • JuanL
                                • Dec 2021
                                • 14
                                • Spain
                                I've received today the capacitor. I'm happy. See the invoice
                                • mon2
                                  • Dec 2019
                                  • 14047
                                  That is awesome!! Hope the repair works out well for you.
                                  • silver60618
                                    Lenovo Legion 7 - Help Identify IC
                                    by silver60618
                                    Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                                    I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                                    Any help would be appreciated...
                                    07-02-2025, 12:16 PM
                                  • chth96
                                    How can I identify varistor which have been blew up?
                                    by chth96
                                    I mistakely pluged 100v japanese retro game console to 220v outlet.
                                    So It seems that glass fuse and varistor have been blew up.
                                    I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                    Is there any way to identify varistor type in my sega saturn PSU?
                                    Any reply would be appreciated.
                                    EDIT:
                                    It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                    11-26-2023, 08:52 AM
                                  • thesame
                                    DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                                    by thesame
                                    Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                                    The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                                    02-27-2024, 04:31 AM
                                  • freakorio
                                    Need Help To Identify Component on Ymain LJ41-05120A
                                    by freakorio
                                    Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                                    05-21-2024, 02:32 AM
                                  • baiceanu_stefan
                                    nm-f251 Schematic, boardview or help identify componente
                                    by baiceanu_stefan
                                    Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                                    04-24-2024, 12:49 AM
