Macbook M1 Unlocked!
  • Azaka
    • Nov 2022
    • 6
    • Uzbekistan
    #61
    Re: Macbook M1 Unlocked!
    Originally posted by ugamazing
    You can easily find the serial of a locked board by booting to diagnostics/AHT. It will show the serial in the bottom-left.
    Thank you very much! This is what I needed.
    Apple Diagnostics - Command (⌘)-D
    • alassane.dontavius
      Banned
      • Jan 2023
      • 28
      Originally posted by kjchatman
      i'm seeing on checkm8.info that their activation bypass supports macOS ventura. does this mean that there is a bypass for ibridge 6?
      You are late to the party my friend, the new bridge unlock got released by the end of December
      • kjchatman
        • Dec 2012
        • 213
        • united states
        #63
        so all of the new intel macs are unlockable?
          Banned
          • Jan 2023
          • 28
          till today 02-19-2023 Yes every intel can be done, no need for any hardware, all software, icloud , mdm , efi
          • EyeDoc1
            • Feb 2019
            Re: M1 Unlocked!
            I have a 2000 MacBook Air that is iCloud locked. Bought it on E-bay for me to study. I also have a full working MacBook Air (2000) that I connected to try to use DFE. But all I get is a Big Paddlock on the Host machine. I tried to connect to CheckM8 software, but that does not work either. I'm just a hobbyist that does not like Macs junked when they can be fixed. THX.
            Good luck on your quests!
              Banned
              • Jan 2023
              • 28
              Re: M1 Unlocked!
              Good luck unlocking ur mac
              • oxonater
                • Oct 2012
                • 77
                • uk
                #67
                Originally posted by Stephen
                EUREKA! Yours truly may have just figured out how to unlock an M1! I am doing more stress testing boys but you might just see the first M1 unlocked that is activation locked! I will give more details soon when we get a few more M1's to test this out on! It is a hardware unlock so just be mindful as I trial and error this stuff!
                Ah this sounds very good indeed
                I wonder was there an additional ROM located somewhere that has this info separate from the actual rom IC itself as a cover. As work on so many of these boards and are a pain in my back side LOL
                Well done for finding a solution
                • ugamazing
                  • Jun 2013
                  • 171
                  • usa
                  #68
                  That post was 5 months ago; no progress made on unlocking Activation-Locked M1 boards/units as of right now. If anyone says otherwise, request hard proof and confirm it's not just a bypass.
                  • oxonater
                    • Oct 2012
                    • 77
                    • uk
                    #69
                    Hi
                    Yes seems I was a bit late for the party however more interested in perm solution to MDM removal as opposed to the FMM unlocking. Keep up the good work guys
                    • QBC
                      • Mar 2023
                      • 8
                      • belgium
                      #70
                      m1 and m2 only permanent unlock with enterprise account (other unpossible)
                      • QBC
                        • Mar 2023
                        • 8
                        • belgium
                        #71
                        mdm never permanent remove ( only when old owner delete serial from mdm server) or you must change the serial on mac
                        • EyeDoc1
                          • Feb 2019
                          FYI Article the group might read....
                          https://reverse.put.as/2016/06/25/ap...the-scbo-myth/
                          Cost effective to just by a new Apple...
                          • QBC
                            • Mar 2023
                            • 8
                            • belgium
                            #73
                            scbo file only for mac until 2017
                            • oxonater
                              • Oct 2012
                              • 77
                              • uk
                              #74
                              Yes we already know how to sort previous models it is just M1 versions, I wonder if anyone has investigated the similar IC next to the CPU on the schematics says it's another ROM ?????
                              • nmatavka
                                • Dec 2022
                                • 0
                                There was a topic posted here before: https://www.badcaps.net/forum/showth...103095&page=18
                                Unfortunately, someone seems to have locked it. No idea why, there's no message from a moderator.
                                • oxonater
                                  • Oct 2012
                                  • 77
                                  • uk
                                  #76
                                  Morning all
                                  I have a question so if one changes the serial of said T2 device to that of another T2 same year same spec colour etc etc no FMM and maybe an MDM lock is there not something in the T2 that verifies all is well or is there something else that needs changing.
                                  Ok reason I ask running sys config will be greyed out if the above happens of course I am sure you guys know what I am talking about. Just wondered if it stores the previous serials of all components in T2.
                                  Then if there is changes to this the system will not allow connection to Apple network for configuring i.e Touch ID, TOP-CASE DISPLAY as all these have serial numbers written to something during the process.
                                  Please excuse my loose terms in case of prying eyes
                                  Thanks for any input you very clever people
                                  • thereedcloud
                                    • Trinidad and Tobago
                                    #77
                                    Is there a tutorial on how to do the intel T2 unlock here?
                                    • kevingill
                                      • Jun 2013
                                      • 152
                                      • England
                                      #78
                                      Check out this thread:
                                      https://www.badcaps.net/forum/showthread.php?t=93978
                                      • thereedcloud
                                        #79
                                        Originally posted by kevingill
                                        • curiositymaster
                                          • Apr 2021
                                          • 45
                                          • Nigeria
                                          #80
                                          Hey Stephen, have you heard of the software method for editing T2 serial? I came across the download link, but it's a paid service.
                                          I'm wondering if your software guy could work around it and make it free for all.
                                          • bouch
                                            unlock macbook air A1932 2019
                                            by bouch
                                            hi
                                            i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                            i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                            i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                            have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                            I need help or information?
                                            Does anyone have the minat2 activator 1.4 software?
                                            Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                            Thank yo...
                                            03-12-2025, 10:14 AM
                                          • keats11
                                            T2 Macbook MDM Unlock by S/N change.
                                            by keats11
                                            I was hoping someone could point me to a tutorial on MDM unlock. Basically, I picked up a Macbook (A1989) from someone which did not have OS installed. The guy said it started software update and but did not finish. Long story short, the touchbar on this device has some kind of a short, so after unplugging it, I was able to install the OS on it, when I found out that it is also MDM locked by his company. I tried changing the serial number on the ROM by only changing a couple of digits of the original serial number. Now after installing the ROM back, the Macbook appears dead = DFU mode. When I...
                                            05-15-2023, 06:46 AM
                                          • Flasman90
                                            Macbook Pro DFU Restore Issues
                                            by Flasman90
                                            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                            08-30-2025, 10:27 AM
                                          • tobeend
                                            Bypass mdm macbook m2 ventura
                                            by tobeend
                                            1. RESET MACOS WITH IPSW
                                            a. Power off MacBook, press and hold the power button to enter Recovery
                                            b. Open Disk Utility, remove Macintosh HD
                                            c. Reboot, connect to the network to Activate Mac.
                                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                            05-26-2023, 07:18 AM
                                          • SarcasticOP
                                            General question about MacBook power rails for repair.
                                            by SarcasticOP
                                            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                            • PPBUS_G3H (12.6V-12.8V)
                                              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                            • PP3V42_G3H (3.42V)
                                              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                            • PPVRTC_G3H (3.3V)
                                              • This
                                            12-12-2024, 05:50 PM
