RAZER BLADE 2016 - Turns on and black screen after POST
  • magneh
    • Apr 2014
    • 633
    • Portugal
    Hello guys!
    I have a Razer Blade 2016 Model RZ09-0195 motherboard Betty R5 V3.1
    Laptop turns on, I can get to the BIOS screen, but after it just hangs in black screen.
    Visual inspection nothing, board is factory.
    Tried another Bios dump, same thing. I see CPU activity at the start, but when I try to boot USB stick, it disappears and hangs in black screen.
    I measured just now CPU vcore, when turning on or when on bios I see 1.10~0.9V, but after POST it goes to 0V when back screening.
    This laptop has the SIC631 mosfets and the Intersil 95855A controller.
    Should I replace these SIC631 Mosfets?
    Anyone with some experience with these boards?
    Thanks in advance!
  • ZixuTech
    • Oct 2017
    • 90
    Re: RAZER BLADE 2016 - Turns on and black screen after POST
    Are you sure it is not a GPU issue? Can you try with lighter OS. Linux perhaps to ensure it doesn't fail when GPOU kicks in.
    BTW would you mind sharing your original BIOS, I have the same here with seems to be a corrupted BIOS.
    Thanks IT-Solve
      • 22424
      Thanks IT-Solve
      RZ09-0195* bios in the "Bios Requests ONLY!" section -
      https://www.badcaps.net/forum/showthread.php?t=76992
      • reassor
        • Apr 2021
        • 181
        • Poland
        Check what happens on Intersil 95855A - ALERT# and sense ressistors. Its tottal shot in the dark but VCORE going to 0v seems like its turning it off.
        • magneh
          • Apr 2014
          • 633
          • Portugal
          Well since these boards are known for CPU power circuitry failure, I went ahead and changed all CPU mosfets, the SIC631... and machine now works 100%!
          So when CPU was asking for power after bios screen, the ICs were not able to properly switch and deliver power... solved.
          Just as reference in case someone finds themselves with similar issue.
          Cheers
          • ZixuTech
            • Oct 2017
            • 90
            Hi @magneh. What were the symptoms of yours?
            Weirdly my one was turning on with a black screen with lights on the keyboard and a slowly blinking LED. No heat on CPU/GPU only on the chipset.
            I figured out that the CPU fuses were blown after I have tried to flash a couple of BIOS'es.
            Replacing the fuses brought it back but the keyboard wasn't detected anymore. No RGB lights. I could load the system, the trackpad is fine just no KBD.
            So I reverted the original bios and now is turning on with a black screen and no keyboard lights. Fuses are fine, the system heats up.
            Go wonder.
            • magneh
              • Apr 2014
              • 633
              • Portugal
              Go wonder.
              Hey there!
              The laptop turned on normally and it would hold up in bios etc, everything after POST would be black screen.
              If I measured CPU VCORE, it would go to 0V when screen went black.
              I would try to measure also CPU vcore on your, most likely its always 0v.
              Measure all the fuses around that area, and it would not hurt to change all 4 CPU mosfets.
              Good luck mate!
              • jipikiller
                • Aug 2020
                • 15
                • arg
                where i found cpu vcore? or there is boardview and schemetics avaiable? i think i have the same issue
                thanksss
                • gurj1979
                  • 190
                  Hey guys, I'm glad I'm not the only one with same issue.
                  Laptop turns on, BIOS shows, blah blah, then when loading OS or USB OS, or anything where the BIOS passes control to some other OS, the VCORE and VCCSA hits 0v and display goes off, but machine stays on.
                  I've changed 2 SIC631 MOSFET's for VCORE (the other 2 SIC631 are for VCCGT (onchip graphics) and are fine, and 2 other smaller ones for VCCSA, but still same result.
                  I suspect this is a BIOS issue. Probably from a previous owner doing a bad BIOS update and got corrupted.
                  Has anyone go a known GOOD BIOS and EC ??#Preferably one which has had ME Cleaned properly with the original ME Version (not updated). You can blank out the Serial in the EC chip if you like - I prefer to use my original Serial anyway.
                  The BIOS's in the other Post didn't work. I got no POST, no BIOS from them.
                  • gurj1979
                    • 190
                    Cheers
                    That actually worked. In my previous post (the one before this), I said I had changed only 2 SIC631 for VCORE. Well, now I just changed the other 2 as well for VCCGT (Graphics).
                    And hey presto....I can not boot an OS
                    Thanks dude for the tip about changing all 4 MOSFETs. Although I reckon I only needed to change my VCCGT ones from the get go.
                    • KappaDev
                      • Feb 2019
                      • 41
                      Anyone know if I can use SIC632 to replace SIC631 for this model?
                      • Bendman
                        • Feb 2016
                        • 3
                        • USB
                        I have a RZ09-0195 and did THE SAME THING, I used the CPU mosfets from a 2016 Macbook Pro 13" logic board (sic635) and they worked! Just to anyone who might be wondering. Thanks so much for this info!
                        • smic717394
                          by smic717394
                          07-25-2024, 10:16 AM
                        • Heitor - AWS Informática
                          Razer Blade 2020 RZ09 03519E11 - BIOS Request
                          by Heitor - AWS Informática
                          Hi, everyone!
                          I've a Razer Blade 2020 on my bench today, all stand-by tensions are OK, but we've no action when I press the power button.
                          Here's some informations about the laptop and the original file backup:
                          Laptop Model: Razer Blade 2020
                          MB Model: ol510mb v1.0
                          P/N: RZ09 03519E11
                          S/N: 622048M10000619
                          Many thank's in advance! And if I broke any rule, sorry, I'm a rookie here, just tell me how can I fix that ...
                          12-01-2025, 08:05 AM
                        • istvanszasz99
                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                          by istvanszasz99
                          Product Name: Razer Blade 15 (2022)
                          Product ID: RZ09-0421
                          Motherboard: CH580
                          BIOS Versions I work with: 2.02 & 2.06
                          Bios File Size: 32,768 KB
                          Dear Forum Readers!
                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                          !!! MY RAZER BLADE...
                          11-24-2025, 05:52 PM
                        • vinaypundith
                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                          by vinaypundith
                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                          08-03-2024, 12:32 PM
                        • plyanthony
                          Razer Blade 15 no external display with attached screen disconnected from motherboard
                          by plyanthony
                          Computer in question : Razer Blade 15 2020 Base Model
                          Model# RZ09-03286E22
                          BIOS CHIP: WINBOND W25Q128BV
                          What I'm trying to accomplish:
                          I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
                          What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
                          W/Stock BIOS - 1.06:
                          Disconnect the...
                          02-01-2023, 09:35 PM
