Razer Blade 15 no external display with attached screen disconnected from motherboard
  • plyanthony
    • Feb 2023
    Computer in question : Razer Blade 15 2020 Base Model
    Model# RZ09-03286E22
    BIOS CHIP: WINBOND W25Q128BV
    What I'm trying to accomplish:
    I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
    What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
    W/Stock BIOS - 1.06:
    Disconnect the eDP cable from motherboard- no dice, no signal to external display
    Through testing I found if the attached display is connected but cable is removed after POST the external monitor keeps signal.
    Customizing BIOS attempts:
    Primarily made changes under Setup > Chipset > System Agent Configuration > Graphics Configuration
    I have tried various combinations of changing "Primary Display" (both of them, there are 2) to PCI, PEG, AUTO, etc.
    Disabling Integrated graphics
    then under > LCD
    Changing active LFP to - No eDP
    Primary / Secondary boot Display to EFP
    Under Setup > Boot > CSM
    Disabled secure boot
    Under CSM changed "Video" to Legacy
    Ive tried all at once, various combinations of each and nothin. May be some other options I attempted but just cant remember, anything that seemed relevant to boot displays, primary displays, etc.
    Side note: During testing sometimes windows would boot and Id hear the welcome jingle, other times the laptop was stuck in a boot loop on its own. But never an external display signal. I did disable the integrated graphics driver in windows before testing just in case that made a difference.
    Has anyone had luck on getting these laptops to work without the attached screen being connected or any ideas? I've wasted a whole day messing with the thing (not wasted when you're having fun right?) and dont want to give up on this task.
    Reason I to want to do this:
    Computer has serious heat dissipation problems I believe heatsink related, want to build a custom case and may do some water cooling just for fun. Also the battery is just beginning to becoming a spicy pillow (to no surprise if you read r/Razer) and plan to retire the unit as portable and just make it a desktop at this point.
    TLDR;
    No external display signal when the laptop attached screen is disconnected from the motherboard. Various BIOS changes were tried but all for naught. Any information is helpful!
  • plyanthony
    • Feb 2023
    Re: Razer Blade 15 no external display with attached screen disconnected from motherb
    SOLVED:
    About 15 total hrs of trial and failure (irrelevant but just wanted to share) I have gotten the laptop to boot the external display as primary (shows BIOS / POST screens) and does so with all attached display connectors removed from the motherboard.
    Using AMIBCP to modify BIOS:
    Under Setup > Chipset > System Agent Configuration > Graphics Configuration > LCD Control
    I set primary and secondary "Boot Display" to EFP (Not sure if this is necessary but havent had time to test without it selected).
    What I believe the secret sauce was I enabled visibility of Each menu of
    Setup > Chipset > System Agent Configuration > Graphics Configuration by selecting "USER" under the Access/Use options in AMIBCP. That way you can modify options directly on the computer and save to BIOS there.
    First boot up I went into the BIOS on the computer, go to Graphics configuration and under "Primary Display" set to PCI, and disable "Internal Graphics", all done on the attached display. Once you save and reboot the attached display no longer functions and all connectors can be removed and the laptop will boot as per usual but fully rely on the external connected display.
    Hope this helps anyone in search of getting something like this working on a Razer Blade.
    • kolebug
      • Vietnam
      SOLVED:
      Hi plyanthony, I have razer blade 15 2018 and it has broken screen as well. I have had taken off completely the screen before doing the mod you provided. However, the loading screen of razer and bios mode still not display on my external monitor. I used HDMI cable to connect it. Could you share iamge of complete .rom file of your changes. It would be easier for me to follow through. Thanks in advanced
      • theplop
        Razer blade 2022, 14" PI480 wont boot to OS, freezes
        by theplop
        Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
        I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
        I've run memtest quite a few times, and more often then not...
        03-20-2025, 06:42 PM
      • 0xx
        2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
        by 0xx
        Hi folks,
        My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
        What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
        I assumed that Windows Update was interrupted due to closing...
        09-14-2025, 03:46 PM
      • istvanszasz99
        Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
        by istvanszasz99
        Product ID: RZ09-0421
        Motherboard: CH580
        Bios File Size: 32,768 KB
        Dear Forum Readers!
        !!! MY RAZER BLADE...
        11-24-2025, 05:52 PM
      • chinsuckseed
        Need Help to Boot with External Display XPS 13 9343
        by chinsuckseed
        I need some help !! I just update Display firmware of XPS 9343 but it 's wrong firmware the system prevent me from BOOT and got 8 beeps even i press FN+F8 to connect HDMI to external Display then FN+F12 to select Boot Menu, it stucked at Dell Logo and preparing to Boot Menu, i would need your help to boot to an external display I have dump my BIOS of my XPS 9343 . pls advice me would be highly appreciated. THank u very much
        https://drive.google.com/file/d/1pXd...usp=share_link
        02-23-2023, 06:48 AM
      • shellybelly
        Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
        by shellybelly
        Back Story
        I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
        So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
        08-27-2023, 10:40 PM
