Dell E6430 shortcircuit
  • Andreasbest
    • Aug 2014
    • 1168
    • Hellas ( Greece )
    Hello!
    I received one E6430 that has a shortcircuit, when i plug the charger in it, the charger turns off. Must unplug and plug from mains to make charger work again.
    Any ideas???
    Thank you in advance!!
  • Sametbey
    • Jan 2021
    • 229
    • Turkey
    Re: Dell E6430 shortcircuit
    Check DC_IN input on page 44 and PQ1300 mosfet on page 52. Check if there is a short circuit on the Pr1301 shunt resistor. Good works.
    I'm not happy to be so strong. because it's not humanly
    • Andreasbest
      • Aug 2014
      • 1168
      • Hellas ( Greece )
      Just to mention i found shortcircuit to ground in PQ914, pins 1 2 3 & 4 (pin 4 is already ground anyway) soldered and unsoldered.
      Is that change what you told me before??
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        If there is a short circuit on the 1 2 3 pins of the PQ914, there may be a short circuit on the 19v line of the motherboard. like nf capacitor.
        • Andreasbest
          • Aug 2014
          • 1168
          • Hellas ( Greece )
          Can you show me please?
          • Spider1211
            • Oct 2019
            • 532
            • Mauritius
            Pin 4 of PQ914 should not be grounded. Remove PQ914 and check again. Usually short on main rain is due mostly because of shorted caps (those brown little bricks).
            Do you have a microscope or a good magnifying lens? Before removing any parts, do a close visual check with special attention to those little brown caps. If you find any that is cracked/missing part of the brown part or looks very discolored, its most likely the culprit. Remove it and check if your short is gone.
            • Andreasbest
              • Aug 2014
              • 1168
              • Hellas ( Greece )
              My mistake, pin 4 is not grounded.
              • Spider1211
                • Oct 2019
                • 532
                • Mauritius
                OK good. I wont worry about PQ914 yet though. If you want, remove it and check if the short is still there (pretty sure it'll still be). Then look for the shorted caps as mentioned above.
                • Andreasbest
                  • Aug 2014
                  • 1168
                  • Hellas ( Greece )
                  Problem is all capacitors on the top left (DC_IN area) are all grounded.
                  Can't desolder them all to test and none is discolored or cracked, i searched before opening the thread.
                  • Spider1211
                    • Oct 2019
                    • 532
                    • Mauritius
                    Look throughout the board and on both sides, not just the DC_IN area.
                    • Andreasbest
                      • Aug 2014
                      • 1168
                      • Hellas ( Greece )
                      Perhaps it's better to open the jumpers one by one until i notify the shortcircuit is gone.
                      • Spider1211
                        • Oct 2019
                        • 532
                        • Mauritius
                        You could do that also but will take a bit more time. Or if you have a bench power supply, you can inject voltage. Start at 1V 1A, then increase the AMP only slowly until you find something getting hot.
                        • Andreasbest
                          • Aug 2014
                          • 1168
                          • Hellas ( Greece )
                          Yes i was thinking that after the jumpers.
                          Tell me something, all these under CPU socket are C or PL?? (except the black cap in the middle)
                          • Spider1211
                            • Oct 2019
                            • 532
                            • Mauritius
                            Remove the white-ish plastic cover. The parts should be labelled, but judging from the shape outline in your picture it looks like a capacitor (C).
                            • Andreasbest
                              • Aug 2014
                              • 1168
                              • Hellas ( Greece )
                              Unfortunately they are not labeled.
                              I open the jumpers and i only see shortcircuit now on the very top left dcin area and in this under cpu area.
                              That's why i want to know if they are c or pl.
                              • Spider1211
                                • Oct 2019
                                • 532
                                • Mauritius
                                It is actually labelled, Capacitors are sometimes also labelled as "PC". In your case that would be PC1077. And no, I don't think its a short circuit. Measure its resistance and report back. +VCC_Core will have a low resistance because of the CPU.
                                Also, post a picture similar to post #13 but without the plastic, I saw a cap that looks a bit odd (not sure if its because of reflection, glue or dirt). Maybe you could take a closer look.
                                Edit:
                                Nevermind, the capacitor is not present looking at picture in post #15.
                                • Andreasbest
                                  • Aug 2014
                                  • 1168
                                  • Hellas ( Greece )
                                  Edit:
                                  Resistance in all capacitors there is 3.2Ω
                                  PC1077 in the center is tantalum cap, i know. I meant about all these around it, are these caps too?
                                  • Spider1211
                                    • Oct 2019
                                    • 532
                                    • Mauritius
                                    Just make sure you are factoring in your probe resistance. Short your probes together and check its resistance value (should be 0).
                                    Otherwise 3.2 seems fine for CPU. If your CPU is socketed remove it and measure again, it should be a much higher resistance value.
                                    • Andreasbest
                                      • Aug 2014
                                      • 1168
                                      • Hellas ( Greece )
                                      yes with probes short i get 0.05Ω.
                                      Without CPU i get 3.22KΩ, much higher indeed
                                      Now without pjp601, pjp1301 and pjp702 i get the shortcircuit only in top left dcin area.
                                      Pins 1 2 and 3 of PQ914 to be more precise.
                                      • Spider1211
                                        • Oct 2019
                                        • 532
                                        • Mauritius
                                        Don't remove Jumpers blindly. By the looks of it, you have a short on 19V rails (system side) [Assuming you removed PQ914 and pin 5 to 8 is not shorted to ground].
                                        The shorted rail is named +PWR_SRC. Jumpers are usually present when another 'section' of the board need 19V to convert it to something else, as is the case with PJP702 where the 19V will be converted to +VCC_GFXCORE.
                                        Removing jumpers to find shorts is only really helpful to figure out which 'section' is faulty/shorted but is useless if the fault is on +PWR_SRC.
                                        Think of it like this:
                                        Imagine you have an underground main water pipe that feeds say 5 houses. Each house gets water from the main pipe through a vane/valve (which in your case is the jumper).
                                        Now say you get a complaint that water is leaking. You could eliminate leaks through the houses by closing the water vane/valve for each house.
                                        But there is also the other possibility that the leak is coming from the main pipe itself in which case closing the valve/vane would not be helpful since the leak could be anywhere along said pipe. In such cases you might maybe inject a marker in the water and use a detector to locate the leak (which in your case is analogous to injecting voltage and feel for what gets hot).
                                        Hope that somewhat helps.
                                        Coming back on topic, if you cannot find anything wrong visually I suggest you inject voltage and locate what gets hot.
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • PowerAmpFreak
                                          Dell Latitude 7280 does not recognize charger
                                          by PowerAmpFreak
                                          I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
                                          Any common faults that could be fixed?
                                          I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
                                          How does the communication between the charger and the PC work?...
                                          07-28-2025, 07:18 AM
                                        • exerion5000
                                          DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                                          by exerion5000
                                          Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                                          below normal, as if it were operating in an extreme energy...
                                          10-15-2023, 02:12 PM
