Dell E6430 shortcircuit
  • Andreasbest
    • Aug 2014
    • 1151
    • Hellas ( Greece )
    Re: Dell E6430 shortcircuit
    Originally posted by Spider1211
    Don't remove Jumpers blindly. By the looks of it, you have a short on 19V rails (system side) [Assuming you removed PQ914 and pin 5 to 8 is not shorted to ground].
    The shorted rail is named +PWR_SRC. Jumpers are usually present when another 'section' of the board need 19V to convert it to something else, as is the case with PJP702 where the 19V will be converted to +VCC_GFXCORE.
    Removing jumpers to find shorts is only really helpful to figure out which 'section' is faulty/shorted but is useless if the fault is on +PWR_SRC.
    Think of it like this:
    Imagine you have an underground main water pipe that feeds say 5 houses. Each house gets water from the main pipe through a vane/valve (which in your case is the jumper).
    Now say you get a complaint that water is leaking. You could eliminate leaks through the houses by closing the water vane/valve for each house.
    But there is also the other possibility that the leak is coming from the main pipe itself in which case closing the valve/vane would not be helpful since the leak could be anywhere along said pipe. In such cases you might maybe inject a marker in the water and use a detector to locate the leak (which in your case is analogous to injecting voltage and feel for what gets hot).
    Hope that somewhat helps.
    Coming back on topic, if you cannot find anything wrong visually I suggest you inject voltage and locate what gets hot.
    Yes I understand.
    I opened the jumpers just to exclude areas from searching and losing time.
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      What is the resistance to ground on the 19V rail by the way?
      • Andreasbest
        • Aug 2014
        • 1151
        • Hellas ( Greece )
        i measure resistance between PQ914 1 2 and 3 (same pin, just mentioned them all) and ground, is 3.5Ω
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          Hmmmm, it could also be a high side mosfet that failed. Check continuity across PQ700 (PQ701 should be empty, but test across it too if present).
          • Andreasbest
            • Aug 2014
            • 1151
            • Hellas ( Greece )
            PQ700 upper pins are all grounded, bottom no.
            Same on missing PQ701.
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              #26
              which are upper & lower pins? Is the CPU removed or present? Measure continuity across PQ704 and PQ705(if present)
              • Andreasbest
                • Aug 2014
                • 1151
                • Hellas ( Greece )
                #27
                Upper pins are those with the dot on their side (the dot is in middle top)
                PQ701 (Not present) PQ700, PQ704 and PQ705 have common upper side (all with dot up middle) so the upper side on all of these is grounded.
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  #28
                  Did you measure continuity across the mosfets mentioned above? Is the CPU installed when you are measuring?
                  3.5ohm is not a direct short to ground, its likely that the main rail is grounded through maybe the CPU or GPU (if present) via a shorted high side mosfet. Hence why we are measuring the above.
                  • Andreasbest
                    • Aug 2014
                    • 1151
                    • Hellas ( Greece )
                    #29
                    Yes i measured continiuity to ground of the mosfet you mentions, the one side of them is common and are all shortcirctuit to ground
                    In Ω i get 0.05 (the same like when i short the probes together)
                    The same on PQ914 1 2 and 3 pins, forget the 3.5Ω ,probably something went wrong with my multimeter in that measurement.
                    CPU removed, No GPU in this mb.
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      #30
                      Ah ok. If Main rail to ground is 0.05ohm then its a dead short, injecting voltage should help a lot here since you cannot visually find the fault. Do you have a bench supply to do so?
                      • Andreasbest
                        • Aug 2014
                        • 1151
                        • Hellas ( Greece )
                        #31
                        Yes i do. I'll start with 19v 1A and check the area i isolate with the open jumpers.
                        If i only had that thermal camera
                        • Spider1211
                          • Oct 2019
                          • 532
                          • Mauritius
                          #32
                          NOOOOOO!!!! Start with 1V 1A then increase the amp only. If nothing gets hot, increase the voltage slightly.
                          Always start at lowest voltage setting to make sure you do not fry CPU, GPU, chipset, etc if ever a high side mosfet is shorted.
                          Lol, don't we all. Use the "Finger licking good" technique instead
                          • Andreasbest
                            • Aug 2014
                            • 1151
                            • Hellas ( Greece )
                            #33
                            i usually start with 19v and 0.5A. Ok i'll do it your way.
                            • Spider1211
                              • Oct 2019
                              • 532
                              • Mauritius
                              #34
                              You can if you are absolutely certain it wont go to the voltage sensitive parts. Or if you don't mind possibly frying a CPU, chipset, etc.
                              This is specially an issue with newer driver chips where the mosfets and driver chip are integrated in a single chip. I recently had atleast 2 laptops with exactly that, high side mosfet for soc was shorted.
                              • Andreasbest
                                • Aug 2014
                                • 1151
                                • Hellas ( Greece )
                                #35
                                Ok i'll do it your way and come back with results )
                                • Spider1211
                                  • Oct 2019
                                  • 532
                                  • Mauritius
                                  #36
                                  All the best!
                                  • Andreasbest
                                    • Aug 2014
                                    • 1151
                                    • Hellas ( Greece )
                                    #37
                                    PQ5 gets extremely hot at only 19v @0.5A
                                    Replaced it but the shortcircuit is still there, removed it and the PQ914 1 2 and 3 pins shortcircuit is still there.
                                    • Spider1211
                                      • Oct 2019
                                      • 532
                                      • Mauritius
                                      #38
                                      Inject voltage on pin 123 of pq914. Again, start at 1V 1A then increase slowly and see what gets hot.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1151
                                        • Hellas ( Greece )
                                        #39
                                        Ok found the guilty
                                        Was a shorted smd cap in bottom of the mb.
                                        Now i face another problem though and i'm worry about the chipset.
                                        When i apply power the power on button and the caps lock led flget immediately light up, nothing display on screen, fan not spinning and after some seconds powers off and power on again in same state.
                                        I'll try bios dump, i hope i didn't damage the chipset somehow.
                                        • Spider1211
                                          • Oct 2019
                                          • 532
                                          • Mauritius
                                          #40
                                          Dell is a bit weird. Remove the CMOS battery, plug in the charger wait 1 second, remove the charger then quickly plug it in again. It should cycle 2-3 times then turn on.
                                          Is the speaker connected? If not, connect it before turning ON. Report back if it beeps when you turn on and how many beeps.
                                          • BTubbs200
                                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                            by BTubbs200
                                            Dell Latitude 5420 P137G
                                            Board: LA-K491P REV A01
                                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                            Board seems to have no shorts, all power rails are fine and show high resistance.
                                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                            01-24-2025, 08:15 PM
                                          • Johndill
                                            Dell Inspiron 7567 LA-D993P odd charger issue
                                            by Johndill
                                            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                            Here are the tested scenarios:
                                            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                            2. With the laptop off, plug in charger (LED says on) & the front charging...
                                            11-16-2022, 10:55 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • exerion5000
                                            DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                                            by exerion5000
                                            Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                                            below normal, as if it were operating in an extreme energy...
                                            10-15-2023, 02:12 PM
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
