Lenovo 330 NM-B671 after HDMI cable connect no video , self restart by 10 seconds
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    hello.
    Have this Lenovo 330 NM-B671 that after HDMI cable connect, restarted to no video and self restart by 10 seconds
    i have all voltages except CPU core and iGPU voltage.
    I noticed that chipset is heating up very quickly. So i think it is burned
    dont have schematic so dont know where is hdmi connected
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: Lenovo 330 NM-B671 after HDMI cable connect no video , self restart by 10 second
    any hint how to check why is chipset heat so much?
    • videotronics
      D43-E2 vizio dark gray display 36 seconds restart
      by videotronics
      Hello everyone, the budget 4k 2017 model Vizio on power up the white led fades and the backlight illuminates, the display is dark gray modulating slightly brightness until the set restarts on 36 seconds interval. Power supply 5v 12.7v 21v are all good. Any recommendations to test the panel and display drive t-con board and mainboard will be appreciated.
      08-24-2023, 09:04 AM
    • shouri
      Dell latitude e5490 auto restart
      by shouri
      Hi guys, can someone help me?
      I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
      Board model is dm70 la-f401p rev:1.0 2017-09-20.
      At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
      After a few days test, is seems ok.
      Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
      12-10-2024, 09:27 PM
    • twonk9098
      Lenovo Legion 5 high fan spin turns off after 34 seconds
      by twonk9098
      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
      I have tried a few new bios but exactly...
      07-14-2024, 11:19 AM
    • KYBOSH
      Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
      by KYBOSH
      I picked this one up today.
      Previous owner says no signs of life.
      TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
      Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
      The TV model is QN65LS03BAFXZA - version: CB06
      The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
      I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
      Will keep you all...
      04-05-2025, 08:32 PM
    • obelix24
      MacBook Pro a2442 - 20v restart every second
      by obelix24
      I just got one MacBook Pro a2442 (M1 Pro) there was small liquid damage.
      Board starts normally at 5V and then jumps to 20V but after few seconds USB-C meter restarts (on every port) - sometime 1 or 2 times it's start and doesn't restart.
      There was hotspot on U5200 (but it looks like on PIN1 (CHGR_GATE_Q4) but I've check in diode mode and it was ok reading (but I've replaced it anyway but still the same ...
      There was corrosion around UR660, UR630, UR600 but I've checked all CAPS and it looks ok ...
      When I connect USB-C meter and check with...
      11-07-2024, 11:34 AM
