MacBook Pro a2442 - 20v restart every second
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    I just got one MacBook Pro a2442 (M1 Pro) there was small liquid damage.
    Board starts normally at 5V and then jumps to 20V but after few seconds USB-C meter restarts (on every port) - sometime 1 or 2 times it's start and doesn't restart.
    There was hotspot on U5200 (but it looks like on PIN1 (CHGR_GATE_Q4) but I've check in diode mode and it was ok reading (but I've replaced it anyway but still the same ...
    There was corrosion around UR660, UR630, UR600 but I've checked all CAPS and it looks ok ...
    When I connect USB-C meter and check with thermal camera I can see light on RC282, RC283 (only blink when USB-C meter turn off and again on) but diode mode is ok for both sides.
    Also U9500 and U9400 get title warm - but I guess it's ok as there was no corrosion around this
    PPBUS_AON on F5200 and F5201 is 12,32V and then it goes to 0V (when USB-C meter turns off and on
    What should I check to find what is causing this ? I guess it must be short somewhere but I'm unable to find it ...
  • mon2
    • 14238
    What is the resistance to ground of PPBUS_AON?
    Flux and remove the 2 fuses on PPBUS_AON and test again to see if the power cycling stops.
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      Resistance on fuses to ground is 5M ohms
      when i've removed both fuses usb-c meter stays on but only on 5V.
      • obelix24
        • Jun 2023
        • 291
        • Slovakia
        should i try to inject voltage to PPBUS_AON and monitor what is getting hot ? (12V and monitor board or this isn't good idea ? i'm just thinking because PPBUS_AON should handle 12-13V and as there is no short probably it should be visible with injection or no ?)
        • mon2
          • 14238
          No. Never inject such a high voltage because this high voltage may be directly leaking onto a lower power rail. This PPBUS_AON voltage is used as the highest voltage to power many buck regulators like the CPU rail. If the high side mosfet on any of these downstream power rails is defective and leaking, then that leg of the power rail will be killed by the high injection voltage. Very possible it is already dead but proceed always with caution.
          You will not see anything heat up because the resistance to ground on the removed fuses is too high. Only if the resistance was very low, then you can see the part(s) heating up under a thermal camera or IPA will evaporate faster due to the generated heat.
          At this time, suspecting the CD321x controllers. Leave the fuses OFF the board. Confirm the checklist created by piernov and others on how 20V is selected by these PD controllers.
          Confirm the presence of each LDO rail on each CD321x controller.
          https://logi.wiki/index.php/CD3215_Bootup_Sequence
          • obelix24
            • Jun 2023
            • 291
            • Slovakia
            but when fuses were there i got 20V isn't this proof that all CD3217xx chips are ok ? I was in this that when i get 20V PD controllers (CD321xxx IC are ok).
            also other question i should get 20V even if fuses are removed ?
            • obelix24
              • Jun 2023
              • 291
              • Slovakia
              I've checked
              PP3V3_UPC0_LDO - 3,4V
              PP3V3_UPC1_LDO - 3,4V
              PP3V3_UPC2_LDO - 3,4V
              PP3V3_UPC5_LDO - 3,4V
              PP1V5_UPC0_LDO - 1,5V
              PP1V5_UPC1_LDO - 1,5V
              PP1V5_UPC2_LDO - 1,5V
              PP1V5_UPC5_LDO - 1,5V
              so they all looks ok
              • mon2
                • 14238
                There are more rails to check for the BMC interface @ 1v1
                • obelix24
                  • Jun 2023
                  • 291
                  • Slovakia
                  I'm still not sure about the 2 resistors RC282 and RC283 they just blink (when fuse is there)
                  but both lines PP5V_S2_MAIN and P5VS2_DSCHG looks ok (I get no short) - see attached video
                  • obelix24
                    • Jun 2023
                    • 291
                    • Slovakia
                    I just noticed one strange thing. When i keep USB-C amp meter connected it keeps restarting (starts at 5v reach 20v approx 0,2a and restarts) but after 4 restarts (one time it was after 6, anothertime after 2 or 3) it stops and stay on 20v 0a (it-s not restarting ampmeter)
                    does this help to indentify what this can be causing ? Some mosfet that needs to heat up or something ?
                    • obelix24
                      • Jun 2023
                      • 291
                      • Slovakia
                      Also to add when it stays on 20v 0a PPBUS_AON is 12,04V
                      • rilley
                        MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                        by rilley
                        I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                        I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                        My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                        And the resistor L4004 is literally burned.
                        From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                        07-10-2024, 01:57 AM
                      • dbuergi
                        Macbook A2442 no display board 820-02098
                        by dbuergi
                        i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
                        So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
                        05-25-2025, 10:58 AM
                      • TechSplendid
                        MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                        by TechSplendid
                        Hi All,
                        I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                        Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                        04-09-2025, 02:13 AM
                      • Constantinos
                        Macbook Pro A2442 820-02098 No image but has backlight
                        by Constantinos
                        Hi all
                        I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                        He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                        Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                        Obviously, he decided against this and gave it to me so that I could have a crack at it.
                        From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                        08-24-2024, 09:48 AM
                      • Enzo150i
                        MacBook A2442 exclamation mark after oxydation
                        by Enzo150i
                        I have a MacBook Pro A2442 with board 820-02098-A very highly oxydated (water) by an accident.
                        The customer just need to recover the data (no backups, heh), so we cleaned fully to make it power on.
                        Fortunately the Mac is still alive but it shows an exclamation mark in a circle (!) (Apple T2 fw issue?) with the text "support.apple.com/mac/restore" and doesn't go further.
                        We tried to interface with another Mac, but can't get in DFU. Very likely the keyboard is gone too because the water, so we're planning to buy a cheap compatible one just to....
                        06-29-2025, 01:26 PM
