a2289 macbook pro 2020 no boot
  • Joyoungjae
    • Oct 2020
    • 23
    • south korea
    Dear friends
    I'm thinking that the MacBook Pro 2020 13-inch a2289 couldn't be solved during repair
    It is said that beer burst out of the bag and became flooded.
    The charging amperage was not normal, so when I looked for the short line, there was a short in the first picture and the chip was removed.
    Then, when I plugged in the charger, the trackpad responded, but there was no boot up response.
    As soon as the charger is connected, it quickly rises to 1.4 amps based on 5 volts, keeps it a little, and then falls back to 0 amps.
    So, looking at the board again, when I checked, the 2 ohm chip was scorched black.
    So I removed the chip in the part shown in the second picture.
    I didn't do this with accurate information because I don't have a circuit viewer.
    Can you help me?? ㅠㅠ
  • Joyoungjae
    • Oct 2020
    • 23
    • south korea
    Re: a2289 macbook pro 2020 no boot
    oh!~ News
    I just removed the circled part of the photo and stuck it back on.
    And when I plug in the charger on this MacBook, there is a trackpad response, so when I take the charger out and plug it in again, the charger sound is heard, but there is no screen response at all.
    And the power supply is charging, but if you give it 5 volts, it goes up to 1.2 amps, but it keeps dropping to 0 and then rising again.
    I didn't do anything for a second, but something changed again.
    This time, it is charging stably at 1.2A, and it becomes a double tap on the trackpad and the touch bar and keyboard light respond.
    I did nothing more.
    However, the screen is still unresponsive, and even when connected to an external monitor, it seems to be unresponsive.
    The monitor seems to recognize
    Anyone who knows what I'm missing ㅠㅠ
    • mon2
      • Dec 2019
      • 14250
      If you shine a flashlight (cell phone light) on the front of the screen, do you see any graphics? Try to move around the light to check if there is an Apple logo or any desktop graphics.
      Your model is too new to have boardview or schematics. For these key reasons, it will be a difficult repair to know which parts to study but do the above test.
      • piernov
        • Jan 2016
        • 4435
        • France
        https://www.badcaps.net/forum/showthread.php?t=90053
        • Joyoungjae
          • Oct 2020
          • 23
          • south korea
          Thank you for answer!
          In fact, I'm not a Macbook doctor like you did, so I don't know how to read schematics well.
          And since the words came out, I was curious...
          Sometimes there is a rar file other than the circuit brd file that members upload, but I can't open the rar file I wonder if there is a way to open this.
          The reason I ask is just you're like a great master
          • Joyoungjae
            • Oct 2020
            • 23
            • south korea
            Thank you so much for answering!!.
            I tried shining the light as you said, but I can't see any screen.
            Is there a case that the backlight goes out of this model? ㅠㅠ
            Which part should I look at
            I want to solve it too much, but I am very sorry that I do not have information about the circuit.
            • mon2
              • Dec 2019
              • 14250
              If you press the CAPS LOCK key on the keyboard, does the GREEN LED turn ON / OFF ?
              If yes, this indicates that some parts of the computer are alive.
              The touchbar lighting up is a good sign from the limited knowledge on these newer models.
              The real issue is that the model is just too new and there is little to no information on the logic board. If you can see graphics but the display is dark then this means the power supply that is required to backlight for the LCD display is damaged or not working.
              Since the display is dark with no graphics, you will have to carefully power down, remove the battery connector for safety. This will remove all power to the logic board. Then review the LCD display video cable and where it mates with the logic board.
              Perhaps the cable is not making contact or is dirty from some liquid spill ? Usually alcohol is used here (90+ purity) to clean the contacts.
              Here in Canada, saw the medical grade alcohol at Costco at fair prices. You may have the same locally there. Ironically we have bought some great quality PCBs in Seoul for many years (Seil and other shops) - for sure you have a very high tech industry there. Check your local cell phone repair shops for assistance on the alcohol or connector review.
              • Joyoungjae
                • Oct 2020
                • 23
                • south korea
                Thank you.
                The caps lock button is turned on when pressed. Which means the keyboard responds.
                However, the display is not responsive at all. It's not dark either. It's just that nothing comes out.
                Cleaner uses 99% pure alcohol.
                In conclusion, the screen is not responding at all and it doesn't come out even if I connect to the external monitor.
                I was originally an iPhone mainboard repair expert, so I have a short experience in repairing MacBooks.
                Thanks for your help.
                • baglaivlad
                  MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                  by baglaivlad
                  Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                  Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                  01-09-2024, 09:55 PM
                • saisoni20
                  MacBook Pro A2289 (820-01987-A) No boot or Display, but boots to DFU and shows status bar only
                  by saisoni20
                  Hi everyone.
                  Recently got MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no Caps Lock, no life except the fan is spinning. But it is able to connect to DFU mode and recognized by another MacBook. I tried to revive but the process ends when the MacBook usually should show an Apple logo with a progress bar and giving me error AMRestoreErrorDomain error 9. I don't have CPU Vcore.
                  Now I can't able to connect to DFU mode either.
                  On the USB meter I got 20V/0.9A power draw, and keep looping....
                  01-29-2024, 08:20 PM
                • dellxps15
                  macbook air 2020 A2179 boot loop cpu hot
                  by dellxps15
                  hi all, got this macbook that looks perfectly clean. no visible liquid damage or burned component that boot loop. if i try to enter diagnostic , it reboot too after a while.
                  owner want to recover data, so im asking if i try a dfu (dunno ifi can do it in that model) do i loose all data ?
                  what can cause cpu to get very hot from the beginning ?
                  generally i fixed some boot loop by reprogram bios, of do a ssd SOS task from recovery menu, but before i start doing things, it's better listen to someone that had this problem on that model
                  09-06-2023, 01:49 AM
                • No Lan
                  [Macbook pro A1708] [Boot loop] [Trackpad ?]
                  by No Lan
                  Hey everyone,
                  Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                  Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                  Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                  05-24-2025, 03:09 PM
                • Gigabit2
                  MacBook Pro 15" Late 2013 no chime or boot but green light on charger
                  by Gigabit2
                  I have a late 2013 MacBook Pro 15" here, with light on charger but does not boot with or without battery installed. Can anyone provide assistance?
                  I checked these rails:
                  PPDCIN_G3H - 19.80 (20V mode)
                  PP3V42_G3H - 3.41 (20V mode)
                  PPBUS_G3H - 12.56 (20V mode)
                  PP3V3_S5 - 3.32 (20V mode)
                  These look okay to me, where should I look next?
                  05-07-2022, 09:56 AM
