MacBook Pro 13" 2020 A2289 - Board issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Customer brought in computer for data recovery, was successful in retrieving data however it would not let us reinstall or load an operating system. Did a DFU RESTORE and that was successful, computer launches and goes into internet recovery, however it crashes once it hits 3/4 the way and starts over again. It did this when we tried to load recovery before the DFU restore and assumed maybe a restore would resolve this issue, sadly it does not. Removed the logic board and inspected the board and it does not have any signs of visible liquid damage or any signs of burns or faulty chip areas. Would like to know where to look or what to repair to get this board to resolve itself.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Update? Just curious if any has experienced this. Was wondering where to proceed.
    sigpic
    • zivo
      • Apr 2023
      • philippines
      try to replace the battery and reinstall the os it might resolve the issue..i tried it and it works for me.
        Apple MacBook Pro 13" A2289 820-01987 Schematic & Board View
        820-01987...
        10-05-2024, 02:48 PM
      • Soulzink
        Samsug washing machine. Power supply DC41-00189a board issue
        by Soulzink
        I am trying to fix a samsung washinmachine power supply main board.
        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
        The power supply board reference is the following: DC41-00189a
        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
        04-19-2025, 06:26 AM
      • Asraf Atb
        by Asraf Atb
        01-27-2025, 05:02 PM
      • tony359
        2007 Macbook logic board fault
        by tony359
        Good day all,
        I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
        Once the fan was swapped, I installed an OS and it worked fine.
        The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
        Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
        If I see that right, I have missed VCORE on L7100 (page 59)....
        01-23-2025, 06:59 AM
      • notallbad
        TCL 55RP620K power board issue
        by notallbad
        Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
        0% p_dim at 1.65v and a_dim at 1v
        50% p_dim at 3.3v and a_dim at 1.65v
        100% p_dim at 3.3v and a_dim at 2.88v
        Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
        Leds are 2 rows of 15 6v leds.
        On inspection of the power board found diode MBR3200 shorted so replaced with...
        07-12-2025, 05:45 AM
