Customer brought in computer for data recovery, was successful in retrieving data however it would not let us reinstall or load an operating system. Did a DFU RESTORE and that was successful, computer launches and goes into internet recovery, however it crashes once it hits 3/4 the way and starts over again. It did this when we tried to load recovery before the DFU restore and assumed maybe a restore would resolve this issue, sadly it does not. Removed the logic board and inspected the board and it does not have any signs of visible liquid damage or any signs of burns or faulty chip areas. Would like to know where to look or what to repair to get this board to resolve itself.
MacBook Pro 13" 2020 A2289 - Board issue
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
Apple MacBook Pro 13" A2289 820-01987 Schematic & Board View
820-01987...-
Channel: Schematics and Boardviews
10-05-2024, 02:48 PM -
by Asraf AtbHi everyone,
Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by StephenCustomer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
by StephenCustomer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...09-10-2025, 03:15 PM
- Loading...
