macbook air 2020 A2179 boot loop cpu hot
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    hi all, got this macbook that looks perfectly clean. no visible liquid damage or burned component that boot loop. if i try to enter diagnostic , it reboot too after a while.
    owner want to recover data, so im asking if i try a dfu (dunno ifi can do it in that model) do i loose all data ?
    what can cause cpu to get very hot from the beginning ?
    generally i fixed some boot loop by reprogram bios, of do a ssd SOS task from recovery menu, but before i start doing things, it's better listen to someone that had this problem on that model
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: macbook air 2020 A2179 boot loop cpu hot
    hi, today i tried a dfu reactivation, but while he is working after a while the macbook restart and goes in boot loop again.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      still didnt find a solution to this. i wont replace component just to see some improvement.
      i noticed that without battery, once it start and u power it off it draw 0,03 0,04 ampere.
      12,6 volt stable, 3,3 and 5 volt stable too.
      when it boot loop, ppbus oscillate from 12,6 to 12,3 volt. also cpu get extremely hot, but a bad cpu will not make macbook stay on if i go into recovery mode and i dont put wifi password.
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        update: problem fixed: i did some reactivate through dfu 3-4 times and didnt work. owner wanted to get data back but unfortunatelly it wont reactivate whatever i did.
        after owner told me i can reset the mac, i did a restore through dfu and got error, then i did a reactivate and got error but after i restarted mac i got the folder question mark, so i reinstalled osx with command option r keys and mac went back to normal working.
        • No Lan
          [Macbook pro A1708] [Boot loop] [Trackpad ?]
          by No Lan
          Hey everyone,
          Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
          Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
          Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
          05-24-2025, 03:09 PM
        • NolesFan
          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
          by NolesFan
          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
          10-24-2024, 06:36 PM
        • tccyo22
          MacBook Air 13" 2020 A2179 Audio Board
          by tccyo22
          Hey all! I have a MacBook Air 13" 2020 A2179 that won't switch on with the audio board connected so before just replacing it outright I took a quick look and found a cracked cap and short. Removed the cap and the short has gone so want to replace the cap to see if we can use this audio board still.
          TL;DR Anyone know the value of the cap circled in red in the attached picture?...
          07-23-2024, 03:36 AM
        • obelix24
          Macbook Air 2020 (a2179) - touch id not working
          by obelix24
          Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
          I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
          02-09-2025, 12:57 PM
        • ACS-Repair
          MacBook Pro A2141 820-01700 Boot loop
          by ACS-Repair
          Hello All,
          I was handed a 2019 MacBook Pro A2141 that is boot looping. There is never a display or backlight but there is a chime about every 8-10 seconds.
          I plugged in a USB-C meter and it see that it is negotiating 20 volts but there is no current draw at all. Voltage is stable, no resets.
          It appears that the battery has a charge but possibly is not charging.
          The following voltages are present:
          PPBUS_G3H = 12.61V
          PP3V3_G3H = 3.33V
          PP3V3_GH3HRTC = 3.33
          I haven't worked n one of these before so I have limited experience with...
          02-04-2025, 07:48 PM
