Cedar_Intel_MB 13269-1 5V_S5 0V
  • James Mi
    • Aug 2020
    • 30
    • Ecuador
    Hello colleagues, good morning, it is a pleasure to greet you.
    Could you help me? First of all I want to tell you that this forum has been very helpful to me, here I find diagrams and clarify the doubts I have since I am new to this, but I find the subject of plate repair. interesting
    I have a dell board, model
    PWM FX3MC REV: AOO
    It is off, with a consumption of 0.034
    reviewing the diagrams that I leave attached so that you can help me
    I have all the signs
    + RTC_VCC
    RTC_RST #
    DCBATOUT
    3D3V_AUX_S5
    3D3V_AUX_KBC
    S5_ENABLE
    up to S5_ENABLE of KBC pin 14 which is in high voltage without pressing the button,
    I replaced the PU4503 giving the same result, ping 6 and pin 20 on voltage 0, it receives voltage through pin 12 with 19.0 V, pin 3 VREG3 3.30 V, I do not get VREG5, nor do I have voltage on pin 18 which I understand gives output to 5V_PWR to become the next 5V_S5 signal
    I would like to know where I can find the error or if I need any conditions to enable them.
    PWR_5V_LL1 -> 5V_PWR -> 5V_S5
    PWR_3D3V_LL2 -> 3D3V_PWR -> 3D3V_S5
    which are the following signs.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Cedar_Intel_MB 13269-1 5V_S5 0V
    Replace Q2402 first and check again. You can remove Q3004 and replace it for Q2402. Leave Q3004 unsoldered for the time being. Q3004 is located near lan connector.
    • James Mi
      • Aug 2020
      • 30
      • Ecuador
      But the voltages in the Q2402 apparently are fine, I receive in S - 3.30 V and in D - 3.30V for this to happen the G has to have low voltage and if it does
      the strange thing is that in Q2403 I do not receive voltage in D - 0 V, I think that in D I should have a high voltage that comes from S5_ENABLE and 3D3V_AUX_KBC and in G I have 0V from Q2403
      • Techtiger
        • Oct 2014
        • 1602
        • france
        PSL_OUT# should be 0V to switch on Q2402 and for Q2403 since SOURCE is GND with 0V on GATE it will not get switch on DRAIN 0V is correct what is the voltage on R2436
        • James Mi
          • Aug 2020
          • 30
          • Ecuador
          in R2436
          PIN1 3D3V_AUX_KBC - 3.3V
          PIN2 S5_ENABLE - 0V - which are the go to the DRAIN of the PQ2403
          The weird thing is that on pin 14 of the KBC - S5_ENABLE I receive 3.3 V
          R2436 is not shorted because I injected voltage into it and if it passes to the DRAIN of the PQ2403
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Remove PQ2403 and test again this is a common pro in this MBD
            • James Mi
              • Aug 2020
              • 30
              • Ecuador
              I am going to try replacing Q2403, but before I have verified that the 3 and 5 v
              They are enabled as long as 3V_5V_EN is at a high level to be able to reach the PU4503 with pin6 and pin20 at 3.3V but this 3V_5V_EN signal is 0v measuring from the pad
              PR4504
              PR4506
              so pin6 and pin 20 are at 0v
              according to the scheme this would be the sequence of S5_ENABLE
              KBC -> PAG. 36> PAG. Four. Five
              At what point would it arrive at q2403? when exiting the KBC through pin 14?
              • James Mi
                • Aug 2020
                • 30
                • Ecuador
                friends the problem was in the PU4404, it was generating voltage problems
                consumption is over 0.034
                now I have another problem and I have noticed that the signal PM_SLP_S4 # I have it in 3V
                According to the diagram, pressing the button goes down to 0v but immediately goes up to 3v
                where could i check?
                • Sametbey
                  • Jan 2021
                  • 229
                  • Turkey
                  1 AC_IN plugs in and PU4404 opens, sends AC_OK.
                  2 PU4503 sends 3VREG signal to the IO chip.
                  3 KBC 14 pin S5_ENABLE signal sends to PU4503. 6 20 + 3V
                  4 PU4503 3V_PWR and 5V_PWR generates
                  5 KBC power button. It starts with
                  and other steps.
                  I'm not happy to be so strong. because it's not humanly
                  • James Mi
                    • Aug 2020
                    • 30
                    • Ecuador
                    I found a video on youtube, which has the same problem and he fixes it like the attached image,
                    right on pin 21 where the PM_SLP_S4 signal from the KBC comes out
                    https://www.youtube.com/watch?v=hOTahvbWTcI
                    • Sojke
                      • Apr 2017
                      • 131
                      • Serbia
                      Where do RED and YELLOW wire go to??
                      • Sojke
                        • Apr 2017
                        • 131
                        • Serbia
                        Why the hell did he connect a wire to NC??
                        • James Mi
                          • Aug 2020
                          • 30
                          • Ecuador
                          Hello colleagues, I relive the issue because I have exactly 3 boards of the same model with the same problem.
                          the problem is that the signal that comes out of the CPU PM_SLP_S4#
                          It must be in low voltage in state S5 but it is not, and following the diagram this signal comes from the PCH, will the CPU be shorted?
                          • pc_okay
                            HP spectre X360 INTEL 6TH randomly starting (randomly missing 5V and AC LED)
                            by pc_okay
                            The board is working only after some hours of rest (without battery and ac charger), if i unplug it when it's working, when i replug dc_jack, board is not working...
                            I don't see any liquid damage or burn component.
                            I don't see any shortage yet.
                            When the board is not ok, AC_LED_ON is turn off:
                            3V_RTC 3V
                            RTC_RST# 3v
                            AC_IN 2.99V
                            +3VPCU 3.3V
                            +5VPCU +5V
                            NBSWON# 3.3V
                            5VS5_ON 0V
                            5VS5 0V
                            When the board is ok i can see my AC_LED_ON white (and when i press...
                            05-26-2024, 07:19 AM
                          • iyan76
                            Need Help to Fix G7AD-2G DAG7AMB38C0 Rev: C bios.
                            by iyan76
                            Please fix this Bios.
                            I got +3VS5 and +5VS5 but Power and Battery LED won't turn on, board cannot switch on.
                            S/N# 5CD9194QW1...
                            03-27-2024, 10:28 AM
                          • gizaha
                            hp DA0R23MB6D1 doesnt turn on
                            by gizaha
                            The motherboard does not turn on.
                            I use a wall power meter to check the power consumption.
                            I plug dc jack without battery, 0.9W, white led turns on.
                            Push power button, drop to 0.6W, pu3 wakes and it outputs +5vs5 and +3vs5 and it's LDO are ok. Also i stress test the +5vs5 and +3vs5 lines and they withstand many amperes.
                            PU3 replaced, same results.
                            HWPG is pulled down from something, i checked all IC that connect with HWPG and they act normally. One by one i injected them their EN signal and they output power.
                            I tried to inject 3.3v at...
                            05-28-2022, 04:14 AM
                          • ruletero
                            HP Omen only do not turn on, only flashes white light
                            by ruletero
                            Hi everyone
                            Please help me with this laptop
                            HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
                            It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
                            But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
                            Bios was programmed with a working version, no changes.
                            Voltages
                            +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
                            06-07-2023, 10:11 AM
                          • ruletero
                            HP 14 DA0U33MB6E0 3/5ALW strange behavior
                            by ruletero
                            Hi everyone
                            MB Model: DA0U33MB6E0
                            Fail: Not turn on, power led on
                            I have +5VPCU, +3VPCU, NBSWON1#, the 5/3 alw power supply is turn on by s5_ON after press power button but in +3VS5 only get 1.7v and in +5VS5 only get 3.5v.
                            Before I changed +5VS5 mosfets (PQ27 and PQ28) because these were in short, also I changed PU4, nothing changed.
                            I have 155 ohms in PL19 and 131 ohms in PL21 then I guess don't have a short, if I press the power button the two voltages are present but low.
                            What thing can I check, please...
                            12-20-2020, 09:31 PM
