ACOK at BQ24728 DA0R53MB6E0 issue
  • rookieme
    • Oct 2014
    • 397
    • Greece
    Hello team,
    I'm having issue with ACOK signal at BQ24728.
    The notebook is able to work with battery but with power adapter only blinks 3 times at dc in when power button is pressed.
    I managed to find that ACOK is missing from BQ24728,
    so far I have replaced it with BQ24735, replaced the KBC, checked the dc in mosfets and currently I'm out of ideas.
    Any help will be appreciated.
  • lapfix
    • Mar 2020
    • 2742
    • my workshop
    Re: ACOK at BQ24728 DA0R53MB6E0 issue
    Why you replaced BQ,KBC without taken voltages before!
    Start with taken the requirements voltages for BQ to work : Pin 20/6/16 and post it here
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Have you checked if middle pin of charger is functioning properly?
      • rookieme
        • Oct 2014
        • 397
        • Greece
        Thank you for replying,
        voltages at BQ p20=19,5V, p6=2,68V & p16=6V
        they seem normal to me
        The adapter ID pin has been messured ok all way to kbc.
        replacing parts seemed to me the only way to figure it out...
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          Can you share what is the voltage on cmsrc and ad-id?
          • rookieme
            • Oct 2014
            • 397
            • Greece
            BQCMSRC is 19,5V and AD_ID is 0,77V measured at C737
            • qayyum786
              • Aug 2018
              • 1933
              • INDIA
              what is your gate voltage on PQ46 & PQ48
              • rookieme
                • Oct 2014
                • 397
                • Greece
                Nice question, PQ46 gate has 17,62V and PQ48 has 24,58V
                • kadi144
                  • Aug 2015
                  • 690
                  • algerie
                  same problem ACOK =0v
                  therefore i have changed the bq
                  https://www.badcaps.net/forum/showth...ikosalalalal33
                  • rookieme
                    • Oct 2014
                    • 397
                    • Greece
                    already done that but problem remains
                    • emestee
                      • 228
                      ACOK you mean ACPRES? Pin 5? If so then: ACPRES is pulled up from the charger's LDO (pin 16) via PR80. So, you're saying that you have 6V on the left side of PR80 (=REGN6V) and 0v on right side (=ACPRES). ACPRES is open drain (meaning that the charger does not push voltage on that pin when it needs to be high, only that it shorts it to ground when it needs to be low; the voltage of the high level must come from elsewhere). If the resistor doesnt pass REGN6V voltage, the pin will remain in floating state. Measure PR80 resistance.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3608
                        • slovakia
                        check first two mosfet if not shorted
                        • rookieme
                          • Oct 2014
                          • 397
                          • Greece
                          non of them is shorted onboard
                          I haven't removed them though to test if the work properly
                          • emestee
                            • 228
                            Did you test PR80 like I wrote?
                            • qayyum786
                              • Aug 2018
                              • 1933
                              • INDIA
                              what is the impedance of pin 5(ACPRES) of pu8 ?
                              • qayyum786
                                • Aug 2018
                                • 1933
                                • INDIA
                                both gate voltages is fine as per R53 mbd
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  PQ11 populated on mb??PU12 pin15 resistance??
                                  • rookieme
                                    • Oct 2014
                                    • 397
                                    • Greece
                                    Yes it is measuring about 83K onboard, one side 6V and the other 0V
                                    from datasheet: ACOK AC adapter detection open drain output. It is pulled HIGH to external pull-up supply rail by external pull-up resistor when
                                    voltage on ACDET pin is between 2.4V and 3.15V, and voltage on VCC is above UVLO and voltage on VCC pin is
                                    275mV above voltage on SRN pin, indicating a valid adapter is present to start charge. If any one of the above
                                    conditions can not meet, it is pulled LOW to GND by internal MOSFET. Connect a 10kΩ pull up resistor from ACOK to
                                    the pull-up supply rail.
                                    So ACDET pin has correct voltage.
                                    Also pulled high trough PR80.
                                    VCC pin is much higher that SRN pin.
                                    VCC above UVLO? What is the UVLO?
                                    • rookieme
                                      • Oct 2014
                                      • 397
                                      • Greece
                                      It is about 65K
                                      • rookieme
                                        • Oct 2014
                                        • 397
                                        • Greece
                                        PQ11 is missing - it seems it was never there.
                                        PU12 pin 15 has about 65K
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                          🛠 Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                          by ugamazing
                                          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                          12-17-2024, 07:05 PM
                                        • shahnld
                                          Lenovo legion 5 pro startup issue
                                          by shahnld
                                          Good day Experts
                                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                          Yesterday, 12:31 PM
                                        • ahmarzo
                                          Acer laptop battery draining issue
                                          by ahmarzo
                                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                          08-02-2025, 06:39 AM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          06-27-2025, 01:10 AM
