ACOK at BQ24728 DA0R53MB6E0 issue
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ACOK at BQ24728 DA0R53MB6E0 issue
    UVLO-Under Voltage Lock Out. At this point its not clear to me why acok is not present on this mb. Resistance at 65K is correct. Try removing PU12 from mb and then measure resistance on pin5 of pu8. If there is significant rise in resistance, PU12 may be bad but seems very unlikely to me.
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      Check all nodes where acin attached.
      Three points here
      If reg6 voltage divider area resistors are ok it means
      Acin signal is reflected back due to short in line
      Acin attached to KBC
      Acin attached to pu12
      Quick solution: replace KBC Which is shorted internally, getting this signal but I do not recommend it
      Second : first check pu12 Pg pin which is getting acin then try first solution
      • emestee
        • 228
        Originally posted by rookieme
        Yes it is measuring about 83K onboard, one side 6V and the other 0V
        from datasheet: ACOK AC adapter detection open drain output.[...]
        I'm confused. Which datasheet are you reading? There's no datasheet for BQ24728 that I could find. That chip doesn't have an ACOK output and the schematic calls it ACPRES and not ACOK. PR80 is supposed to be 100k and not 80k and, more importantly, it needs to be the same value as PR79. Is PR79 short? Is either of those resistors out of spec? Does PR80 get hot? What is the voltage across it when the board is powered up?
        You say PR80 also pulls up ACDET, I dont understand how this is possible..
        You should also probably disable PR175 to disable U12, and then lift pin 21 of the KBC to see if either part is shorted and pulling ACOK down. Note that the KBC pin is GPIO, which means (however unlikely) that wrong BIOS may cause this too.
        • ruletero
          • Nov 2018
          • 183
          • Mexico
          I had a similar case months ago, the kbc acin pin was short, you need to remove the KBC and see if the ACIN goes up. Before I measured resistance on the pin and it did not indicate short but it was. Yes.. already I read you has changed the KBC but it was my case.
          • emestee
            • 228
            This is actually typical because internally, there are several mosfets and a latch to control the function of the GPIO and the pull up. The shorted mosfet may not be connected to the pin until the KBC is fully initialized. I know this because I've been reverse engineering KBC firmware and basically the datasheets speak to me in tongues while I am dreaming.
            An interesting solution to this problem would be to hack the firmware to remap the pin and then move the ACIN to another pin, provided an ADC isn't required. However I imagine for most people just replacing the KBC would be a far better idea.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #26
              As per post#1, he has already replaced kbc.
              • emestee
                • 228
                #27
                Actually he also replaced the converter with another BQ, and I am not 100% sure they are interchangeable. Maybe the divider on ACPRES needs adjustment?
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  #28
                  That is strange
                    • 21880
                    Three points here
                    You might be on the right track ,and @emestee too .EDIT: and @mcplslg123 post #21
                    https://ascnb1.ru/forma1/viewtopic.php?f=231&t=115324
                    • stingerchamp
                      • Sep 2020
                      • 425
                      • Pakistan
                      #30
                      Thanks @SMDflea
                      Btw in schematic diagram power good signal direction is wrong, it is an output signal not input
                      Pu12 Pg is the culprit pin
                      • rookieme
                        • Oct 2014
                        • 399
                        • Greece
                        #31
                        PU12 removed but no change to resistance
                        UVLO is not clear to me, where can I measure it?
                        • rookieme
                          • Oct 2014
                          • 399
                          • Greece
                          #32
                          Currently I have soldered a BQ24735 [from the forum is mentioned as alternative] and that has a datasheet. Both PR79 and PR80 were removed and measured 100K. PR80 6V from side to side.
                          PR80 doesn't nothing to do with ACDET
                          PR175 doesn't exist, it's just a line at pcb
                          After lifting pin 21 of the KBC, ACIN still remains low BUT the system powers on as the floating pin has 2,6V
                          So, there's somewhere an issue but if that cannot be found, working it like that could be ok?
                          • rookieme
                            • Oct 2014
                            • 399
                            • Greece
                            #33
                            ok, some issue with PU12
                            according to https://ascnb1.ru/forma1/viewtopic.php?f=231&t=115324
                            pin 16 should have 19V
                            I have 0 there, no issue with cap pc131
                            • emestee
                              • 228
                              #34
                              You previously said that it has 0v on the exit. What changed? Or was this a bad measurement?
                              I only mentioned is as a method to disconnect PU12
                              Do you mean ACOK remains low?
                              Which floating pin? Do you mean the pad under the lifted pin or ACDET? ACDET should be 2.6v (and was in your first tests). IIRC it should not be anywhere near the KBC.
                              If you're saying that you lifted KBC pin 21 and ACOK still doesn't go up, then the good news is the KBC isn't what's causing this. The other alternative is PU12. Disconnect it and see if ACOK goes up. Remember this is open drain, 0v doesn't mean the chip isn't giving out voltage; it means the pull up voltage isnt there to begin with, or the chip (or something else) drops it to the ground.
                              Replace PU12 then.
                              • rookieme
                                • Oct 2014
                                • 399
                                • Greece
                                #35
                                Replace PU12 then.
                                The 6V I mention is voltage difference from one side to the other so still 0 V on exit.
                                replacing PU12 should be the fix, I will as soon as I'll find a replacement and post the results
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  #36
                                  I had a doubt on PU12 as mentioned earlier at post#21. Lets wait and see the result.
                                  • rookieme
                                    • Oct 2014
                                    • 399
                                    • Greece
                                    #37
                                    after replacing PU12 all worked as should
                                    I had GS7502Q3, I placed GMT-G5934 I found at a scrap M/B.
                                    I have to mention that:
                                    GS7502Q3 = GMT-G5934 = P2806
                                    Hope that will help sb with any similar repair
                                    Thank you everyone for the granted knowledge from this repair.
                                    • emestee
                                      • 228
                                      #38
                                      We should have a little party every time someone finishes with a successful repair. Congrats.
                                      • stingerchamp
                                        • Sep 2020
                                        • 425
                                        • Pakistan
                                        #39
                                        Great news, congratulations
                                        We only guided you it was you who repaired it
                                        Congrats again,
                                        • mcplslg123
                                          • Jun 2015
                                          • 7262
                                          • india
                                          #40
                                          The cost of the party will be more then the cost of repair.LOL
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                            🛠 Original Issue
                                            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
                                          • ugamazing
                                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                            by ugamazing
                                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                            12-17-2024, 07:05 PM
                                          • shahnld
                                            Lenovo legion 5 pro startup issue
                                            by shahnld
                                            Good day Experts
                                            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                            08-24-2025, 12:31 PM
                                          • ahmarzo
                                            Acer laptop battery draining issue
                                            by ahmarzo
                                            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                            08-02-2025, 06:39 AM
                                          • elmark
                                            HP 15-cw1002ua strange keyboard issue
                                            by elmark
                                            HP Pavilion 15-CW1002UA
                                            S/N 5CD0251CBC
                                            P/N 7KE54EA
                                            Hello guys!
                                            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                            It powers on OK and has no other issues except the following:
                                            • CAPS LOCK does not work at all
                                            • Fn button toggles Flight Mode
                                            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                            • (with SHIFT pressed: 't%' and 'y^' respectively)
                                            I initially thought it was a keyboard malfunction (internal short, etc.),
                                            but when I press and hold...
                                            06-27-2025, 01:10 AM
