MacBook Pro A2159 No Power after new Display
  • phxweb
    • Dec 2015
    • 5
    HI All
    I have a Mac Book Pro A2159 with a broken screen, its been replaced with a new one, however the mac will not power on.... Before the screen was replaced the mac was working with an external monitor, and the touch bar would light up as normal
    Since the repair, nothing, dead. The power button does nothing, the touchbar does not light up to indicate any power.
    it makes no difference if power is connected or just battery or power but no battery
    I have downloaded the schematic from one of the threads here, but at a bit of a loss at the moment, I have noticed the area around and component C6907 are warn when on battery with out anything on the screen ...
    the voltage across this is 12.4v
    any suggestions on things to try / test ?
    TIA
  • BL4K3Y
    • Apr 2020
    • 27
    • England
    Re: MacBook Pro A2159 No Power after new Display
    Have you re-connected the damaged screen to the motherboard to see if the device will at least power on?
    The Apple T2 security chip on the motherboard might prevent replacement parts from being used, especially if they weren't bought from an authorised Apple reseller, but I have also read that people have been replacing the displays on these devices without issue (we used to replace them at my old workplace, but they were an authorised Apple service centre at the time with access to genuine parts).
    With this in mind, it is possible that you may have received a faulty part from your supplier.
    If you test your damaged screen and the device works, then that suggests the new display may be at fault and you should contact your supplier for a replacement.
    • phxweb
      • Dec 2015
      • 5
      Thanks, i've put the damaged screen back in and still no power
      maybe i shorted something while installing ? battery was disconnected thou
      ill have to try an work my way through the schematic.
      Any pointers on test points to begin with ?
      • mon2
        • 14368
        Hi. Have not reviewed the schematics yet but is this type C power supply?
        Assuming yes. Do you have an in-line type c meter to review the voltage and current draw of the macbook?
        It should be 20v if working correctly. This is only after proper usb handshake over the CC lines takes place.
        Respectively, review the output of u7000 in the schematic which generates the main power rail for the motherboard and battery charger voltage.
        Assuming that u7000 is the ISL9240?
        Are you using the official power supply? For safety, you should.
        If you have more than one usb port, check the others to power the macbook.
        • phxweb
          • Dec 2015
          • 5
          I have just been doing some testing, and was about to report some voltages etc, I will have a look at the U7000 later.
          It has 2 x USB 3 ports ive tried both of them and just battery and just power supply, It is the original genuine one
          I measured the following:
          PP20V_USBC_XB_VBUS = 20.29V
          PPDCIN = 20.28V
          PPBUS_G3H = 12.22v
          PP3v3_G3H = 3.291V
          PP1v8_SLPS2R = 1.801V
          PP3V_G3H_RTC = 3.3V
          PP5V_G3S = 0 V
          I am unable to find 5v supply. It maybe this is because it is not powered unless system is on, Im trying to work my way around the schematic but i'm more on the novice end of the scale so its taking some time.
          I guess i need to work out where the 5V is generated, and what if anything causes it to generate or not. or should it always be present.
          • phxweb
            • Dec 2015
            • 5
            I've measured the voltages of the following on U7000 :
            PPVBat_G3H_CHGR_REG = 12.22V
            On the U7100:
            PPVIN_S0_CPUVR_VIN = 12.22V
            PP5V_COREVR_VCC = 0 ( Should be 5.3v? but not sure what is the trigger for this to be active )
            I've measure the following too:
            PP1V8_SLPS3R_PMUGPIO = 1.8V
            PP1V1_SLPS2R = 1.1V
            PP0V82_SLPDDR = 0.8V
            PP3V3_AWAKE = 3.29V
            PP0V9_SLPDDR = 0.9V
            My only concern is
            PP0V8_SLPS2R = 0V. IS this a standard always present voltage or one thats triggered ?
            Is my PPBUS @12.22 low ? Ive read it should be around 12.6V but cant confirm in the schematics.
            Many thanks for any help anyone can give me.
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • Ado02
              MacBook Pro A2159 - No Display / Works on External Screen
              by Ado02
              I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
              Please see the attached image.
              I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
              Can anyone suggest where to go from here?...
              01-12-2023, 03:35 AM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • dbuergi
              Help with Macbook Pro A2338 no power and no display needed
              by dbuergi
              Hi all
              i have a 2338 which had no display (there is a little crack near the edge to the case) but worked with external display. Some weeks later it didn`t boot anymore.
              USB Tester shows 5,18v, 0,08 a and 0,38w with power supply.
              With battery connected i get 20v and 0,0 a
              Thermal camera shows that U0500 is heating up to 30c.
              F5200 is not shorted
              Visual inspection didn't show any problems.
              I'm sure that i need to change the display but what can i do to find my other problem with the board?...
              08-11-2024, 09:03 AM
            • Bonaventure Vigil
              ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
              by Bonaventure Vigil
              Dear All,
              Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
              At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
              12-12-2024, 10:22 AM
