Help with Macbook Pro A2338 no power and no display needed
This topic has been answered.
  • dbuergi
    • Jul 2024
    • 130
    • Deutschland
    Hi all
    i have a 2338 which had no display (there is a little crack near the edge to the case) but worked with external display. Some weeks later it didn`t boot anymore.
    USB Tester shows 5,18v, 0,08 a and 0,38w with power supply.
    With battery connected i get 20v and 0,0 a
    Thermal camera shows that U0500 is heating up to 30c.
    F5200 is not shorted
    Visual inspection didn't show any problems.
    I'm sure that i need to change the display but what can i do to find my other problem with the board?
  • Answer selected by dbuergi at 08-15-2024, 01:33 PM.
    mon2
    • 14636
    Study this webpage on how the 20v power delivery contract is selected:
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    Be sure the BMC power rail is present on each port that is active with the power adapter. Do also test the opposite side of each port by rotating the connector by 180 degrees.
    • dbuergi
      • Jul 2024
      • 130
      • Deutschland
      Okay, looks like i should add some more details. Board is 820-02020A
      Checked all fuses now and no shortage.
      C5250 shows 12,34v and nothing susicious on second power line. I tried to find this problem with google and got a thread where M1 chip was dead. Is this a possibilty and "fast" way to find it out?
      What i didn't try until now is DFU recovery. As stated in other posts i`m new to Apple and don`t know if this makes sense in this case.
      • mon2
        • 14636
        Is the voltage @ C5250 stable or power cycling?
        Issue may be that you require the DFU.
        MacBook Pro A2338 Not turning on, 0.00 - 0.05A current draw at 5V repair - Repair Wiki
        Update:
        U0500 - any liquid damage to this region? Apply alcohol and clean up this device area if you suspect any liquid spills. 30C is not too high for an IC.
        • dbuergi
          • Jul 2024
          • 130
          • Deutschland
          No liquid spills and everything looks dry and clean. C5150 is stable.
          So tomorrow i will try DFU recovery.
          • dbuergi
            • Jul 2024
            • 130
            • Deutschland
            I tried several times to enter DFU mode without any success so maybe i missed something else. :-/
            • mon2
              • 14636
              The board is not at 20V so this usually means the ACE controllers (power delivery CD321x) are suspects. Check the LDO rail of each such controller.
              Carefully measure the voltage to ground of:
              I2C_SMC_PWR_3V3_SCL ; at battery connector J5151 (TP5103)
              I2C_SMC_PWR_3V3_SDA ; TP5104
              • dbuergi
                • Jul 2024
                • 130
                • Deutschland
                I2C_SMC_PWR_3V3_SCL is 3,261v
                2C_SMC_PWR_3V3_SDA​ is 3,260v
                Checking CD3217 showed
                PP5v_S2 on LC320is 0,006v
                PP3v3_S2_UPC is 3,3v
                PP1v25_S2 is 1,226v
                All is present. So if i understand it right there can be a problem with UF400 and UF500?
                • mon2
                  • 14636
                  The LDO rails on the CD321x must be present for the IC that is mating with the usb cable. That is the active port and the PD controller should create each required power rail. If one PD controller fails then you will not reach the 20v contract.
                  • dbuergi
                    • Jul 2024
                    • 130
                    • Deutschland
                    Thank you! So maybe another stupid question but can i find out which IC ist causing the problems or should both be replaced?
                    Im not at my desk so i don't know the name of the points i checked near the ICs but at both ICs i get 3,3 and 1,5v. If this isnt any help i will give more details later.
                    • mon2
                      • 14636
                      • dbuergi
                        • Jul 2024
                        • 130
                        • Deutschland
                        I checked both sides and everything looks the same.
                        One thing i found is PP3v3_S2_UPC having 3,3v but in diode mode i get 1,6v without power supply attached.
                        Sorry if i get something wrong or it takes longer to understand but reading all this stuff not in my mother language is way harder than i thought.
                        • dbuergi
                          • Jul 2024
                          • 130
                          • Deutschland
                          So once again i'm looking at this board and i guess i made a mistake.
                          With power supply connected i get 0.070A and it goes up to 0.078 and back down and up. So is this already power cycling?
                          If so i also get different measurements when testing output of U8100 and U8100.
                          Diode mode:
                          PPVDD_PCPU_AWAKE 0,038v
                          PPVDD_ECPU_AWAKE 0,47v
                          PPVDD_CPU_SRAM_AWAKE 0,6v
                          PPVDD_SOC_S1 0,37
                          PPVDD_GPU_AWAKE 0,034v
                          PPVDD_DISP_S1 0,091v
                          PPVDD_DCS_S1 0,46v
                          PP1v4_LDO_PREREG 1,36v
                          Resistance is too low on all points. As example PP1v4_LDO_PREREG 3,8k Ohm.
                          • dbuergi
                            • Jul 2024
                            • 130
                            • Deutschland
                            I made one more finding. CF031 and CF051 Look corroded.
                            • dbuergi
                              • Jul 2024
                              • 130
                              • Deutschland
                              Hello again,
                              im sitting at this board again and this should be the main problem. UF710 is looking the way shown in the pictures and RF713 is missing.
                              Right now i don`t have a donor board, so anything i can do without it? Only spare around is a A1466 board.
                              • sdogs
                                macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                                by sdogs
                                Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                                First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                                I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                                06-27-2025, 01:58 PM
                              • sdogs
                                by sdogs
                                06-27-2025, 11:26 AM
                              • mcbadcbv
                                MacBook Pro M1 A2338 820-02020 - No WiFI/Bluetooth or internal display
                                by mcbadcbv
                                I have a MacBook Pro M1 A2338 820-02020. It boots to OS but WiFi/Bluetooth are non-functional (exclamation point through WiFi symbol in menu bar) and the display is not working.
                                Starting at the WiFi chip... PP3V3_S2_WLBT_ISNS is fluctuating at around 2.4V. No shorts detected around UL000.
                                PPBUS_AON is 12V steady, but PPBUS_AON_3V3_S2_VIN_ISNS (measured at CC721) is 2.76V.
                                LC710 is getting 2.4V at P3V3_SW, which explains PP3V3_S2 fluctuating around 2.4V.
                                No detected shorts around UC710.
                                This makes me believe that RD560 has failed and...
                                07-28-2025, 06:52 PM
                              • User555111
                                A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                                by User555111
                                Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                                02-05-2024, 08:16 AM
                              • ledbylight
                                M1 A2337 Macbook - No Display, likely due to logic board
                                by ledbylight
                                Hi all!
                                This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                                I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                                11-04-2024, 06:36 PM
