HP 17-bs025cl
  • mazloum
    • Sep 2012
    • 503
    • Lebanon
    HP 17-bs025cl
    hi
    can this laptop be converted from discrete to uma?
    HP 17-bs025cl
    • 21869
    Re: HP 17-bs025cl
    motherboard part number ?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: HP 17-bs025cl
      is it LA-E791P??. If so removing just the graphics coil will work in uma mode.
      • lapfix
        • Mar 2020
        • 2764
        • my workshop
        Re: HP 17-bs025cl
        Same motherboard for HP 15 250 G6 with Disc graphic.
        No picture ( there's a backlight ) at intern/extern , try bios/clean me same issue
        EC :
        RSMRST# pin 100 = 3.2v
        6 SLP S3# = 3v
        115 LID SW# = 3.2v
        110 AC_IN = 3.2v
        13 = PLT_RST# = 3.321v
        This voltage at the different coils :
        plz1 = cpu core = 0.931
        plg1 = integrated graphic = 0.692
        pl301 = 3v alws
        pl302= 5v alwas
        pla1 = 1.05v
        pl1001 = 1.05v
        plm1 = 1.2v
        So , can i conclude that it s a graphic issue !
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Re: HP 17-bs025cl
          LPC lines checked?? Edp cable replaced??
          • lapfix
            • Mar 2020
            • 2764
            • my workshop
            Re: HP 17-bs025cl
            Thank you mcplslg for your advises.
            No schematic/boarderview available ..i will try another EDP cable ...for LPC i think it needs oscilloscope!! don't have for the moment
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Re: HP 17-bs025cl
              Why not get the kbc datasheet from another schematic and start checking LPC pins on KBC. You can somehow check them with simple DMM. Dont give up without giving a hard fight.
              • lapfix
                • Mar 2020
                • 2764
                • my workshop
                Re: HP 17-bs025cl
                i know and i use another schematics just to know the pinout of KB.
                For LPC_AD0/1/2/3 = 3.3v
                The consumption is : 0.700 amp
                • lapfix
                  • Mar 2020
                  • 2764
                  • my workshop
                  Re: HP 17-bs025cl
                  Update : i try another motherboard with the same screen and it works , so the EDP cable works fine
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Re: HP 17-bs025cl
                    @lapfix, with LPC readings ok and PLT_RST present-there are hardly any options left without schematics. BUFO_CPU_RST is something to watch for but not possible without boardview. So seems like end of story. May be someone else have any idea. Still do check the following:
                    01.UC5-pin8-9 for 1.8V & 13-14 for 1.0
                    02.UC6-pin6 for 1.0V
                    03.JU22 for VCC_GT
                    However, i do beleive all the test points above are having requisite voltage.
                    Numlock on usb kbd glows??
                    • lapfix
                      • Mar 2020
                      • 2764
                      • my workshop
                      Re: HP 17-bs025cl
                      Hello my friend
                      No UC5/UC6/Ju22 on this motherboard.
                      No reaction from KBd
                      Try to convert it !!
                      Update :
                      75 = AD_ID = 0.649 with psu
                      75 = AD_ID = 0.378 with 45W
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Re: HP 17-bs025cl
                        I'm 100% sure there is UC5/UC6 on LA-E791P mb. Its located near PCH part of SOC
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Re: HP 17-bs025cl
                          Both are part of DC-DC conversion circuit. Your mb is dis??
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Re: HP 17-bs025cl
                            If NUmlock is not glowing on kbd, your mb is not posting. So do probe RAM circuit .PG present or not on RAM PWM?? As far as i remember, removing the two gpu coils make it UMA.
                            • lapfix
                              • Mar 2020
                              • 2764
                              • my workshop
                              Re: HP 17-bs025cl
                              Sorry my friend
                              UC 5 :
                              pin8-9 = 1.794v
                              pin13-14 = 0.989v
                              UC6 :
                              pin6 = 0.989v
                              yes it's a disc
                              For Ram PWM = PUM1 i m searching for Datasheet = 4B=4H
                              • lapfix
                                • Mar 2020
                                • 2764
                                • my workshop
                                Re: HP 17-bs025cl
                                If i m right ; PUM1 is RT8207P.
                                Pin 11/12 = VDD and VDDP = 5V
                                Pin 7/8 = S3/S5 = 3V
                                Pin 20 = VTT = 0.597
                                Pin 16 = PHASE = 1.198
                                Pin 10 = PGOOD = nothing stable !
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Re: HP 17-bs025cl
                                  Yes PUM1 is RT8207P. Your measurements seems good. PG of ram ic is not used in this mb-i rechecked it as i've one repaired mb in hand-so sorry my mistake. Did you try converting it to UMA??
                                  • lapfix
                                    • Mar 2020
                                    • 2764
                                    • my workshop
                                    Re: HP 17-bs025cl
                                    Hello my friend
                                    Yes removing PLV1/PlV2 but same issue , try the clean me bios same too, try another third bios still the same issue.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Re: HP 17-bs025cl
                                      Yes seems like end of story and i dont have any more idea.
                                      • lapfix
                                        • Mar 2020
                                        • 2764
                                        • my workshop
                                        Re: HP 17-bs025cl
                                        Thank you for all your help
