Samsung NP350V5C boots directly to bios
  • SuperAman
    • Dec 2018
    • 119
    I have Samsung NP350V5C laptop that boots directly to bios. I have removed keyboard and all peripherals, cleaned the board but it always starts up to bios only. Even after exiting bios it restarts again into the bios.
  • mielta
    • Apr 2015
    • 368
    Re: Samsung NP350V5C boots directly to bios
    Hi
    This can be happend after defective HDD
    check HDD or try to boot from USB
    • piernov
      • Jan 2016
      • 4435
      • France
      It's normal behaviour on a lot of UEFI systems when there's no system to boot. (no storage drive, no UEFI bootloader, or boot menu entry missing)
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        go to bios then check all the peripherals there including the hdd sdd or boot device unchecked the secure boot.. try legacy boot if you have a brand new hdd. or try to reset it using load default settings.. then reboot.. check also the bios rtc battery 3v .. gud luck
        Never stop LEARNING because life never stops TEACHING!
        • RJARRRPCGP
          • Jul 2004
          • 6301
          That's what happens with my MSI B450 Tomahawk, the first desktop motherboard I own that does this, IIRC.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • george_gpu
            • Dec 2015
            • 77
            • greece
            good day
            in bios see h.d.d ?
            check also keyboard \ sidconect it ( maybe any key is press or damage keyboard )
            • SuperAman
              • Dec 2018
              • 119
              You guys it still does this with a working, or blank or even an OS installed hard drive in there. I have removed the keyboard, reset the bios to defaults and it still does this. I have even taken it apart and cleaned the board with alcohol and it still happens.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3561
                • slovakia
                did u check if u have hdd in bios as u have been asked?
                • SuperAman
                  • Dec 2018
                  • 119
                  Yes I have tried different hdd and they all show up in the bios including odd. It boot loops into bios always.
                  • Udara Umayanga
                    • May 2020
                    • 11
                    • Sri Lanka
                    I have same fault with Samsung 350v .
                    I tried same ways but I can't solve it..any has some suggestions..
                    Thanks..
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • Vesko356
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • TJ65
                      Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                      by TJ65
                      i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                      The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                      I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                      The problem is, that the micom Version doesn't match with the bios version, see picture.
                      How can i update the Micom Version? The Samsung bios update wont work.
                      With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                      01-09-2025, 01:35 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
