Samsung NP350V5C boots directly to bios
  • SuperAman
    • Dec 2018
    • 121
    I have Samsung NP350V5C laptop that boots directly to bios. I have removed keyboard and all peripherals, cleaned the board but it always starts up to bios only. Even after exiting bios it restarts again into the bios.
  • mielta
    • Apr 2015
    • 368
    Re: Samsung NP350V5C boots directly to bios
    Hi
    This can be happend after defective HDD
    check HDD or try to boot from USB
    • piernov
      • Jan 2016
      • 4439
      • France
      It's normal behaviour on a lot of UEFI systems when there's no system to boot. (no storage drive, no UEFI bootloader, or boot menu entry missing)
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        go to bios then check all the peripherals there including the hdd sdd or boot device unchecked the secure boot.. try legacy boot if you have a brand new hdd. or try to reset it using load default settings.. then reboot.. check also the bios rtc battery 3v .. gud luck
        Never stop LEARNING because life never stops TEACHING!
        • RJARRRPCGP
          • Jul 2004
          • 6304
          That's what happens with my MSI B450 Tomahawk, the first desktop motherboard I own that does this, IIRC.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • george_gpu
            • Dec 2015
            • 77
            • greece
            good day
            in bios see h.d.d ?
            check also keyboard \ sidconect it ( maybe any key is press or damage keyboard )
            • SuperAman
              • Dec 2018
              • 121
              You guys it still does this with a working, or blank or even an OS installed hard drive in there. I have removed the keyboard, reset the bios to defaults and it still does this. I have even taken it apart and cleaned the board with alcohol and it still happens.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3628
                • slovakia
                did u check if u have hdd in bios as u have been asked?
                • SuperAman
                  • Dec 2018
                  • 121
                  Yes I have tried different hdd and they all show up in the bios including odd. It boot loops into bios always.
                  • Udara Umayanga
                    • May 2020
                    • 11
                    • Sri Lanka
                    I have same fault with Samsung 350v .
                    I tried same ways but I can't solve it..any has some suggestions..
                    Thanks..
                    • Kjell
                      Samsung Series 9 - BIOS issue
                      by Kjell
                      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                      08-01-2025, 09:15 AM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • Vesko356
                      by Vesko356
                      08-11-2023, 03:27 AM
