I have Samsung NP350V5C laptop that boots directly to bios. I have removed keyboard and all peripherals, cleaned the board but it always starts up to bios only. Even after exiting bios it restarts again into the bios.
Samsung NP350V5C boots directly to bios
Re: Samsung NP350V5C boots directly to bios
It's normal behaviour on a lot of UEFI systems when there's no system to boot. (no storage drive, no UEFI bootloader, or boot menu entry missing)OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
go to bios then check all the peripherals there including the hdd sdd or boot device unchecked the secure boot.. try legacy boot if you have a brand new hdd. or try to reset it using load default settings.. then reboot.. check also the bios rtc battery 3v .. gud luckNever stop LEARNING because life never stops TEACHING!Comment
That's what happens with my MSI B450 Tomahawk, the first desktop motherboard I own that does this, IIRC.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
good day
in bios see h.d.d ?
check also keyboard \ sidconect it ( maybe any key is press or damage keyboard )Comment
You guys it still does this with a working, or blank or even an OS installed hard drive in there. I have removed the keyboard, reset the bios to defaults and it still does this. I have even taken it apart and cleaned the board with alcohol and it still happens.Comment
did u check if u have hdd in bios as u have been asked?Comment
I have same fault with Samsung 350v .
I tried same ways but I can't solve it..any has some suggestions..
Thanks..Comment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Today, 02:17 PM -
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by TJ65Hello everyone,
i made out of two broken Samsung Galaxy Tabpro S one that works partially.
The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
The problem is, that the micom Version doesn't match with the bios version, see picture.
How can i update the Micom Version? The Samsung bios update wont work.
With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
