DELL 15 3537 La-9981p UMA enable .
  • lapfix
    • Mar 2020
    • 2765
    • my workshop
    8 beeps!..i change screen and screen cable too...still 8 beeps...any idea please !
    I remove PL 802 / Pl 1101 /Pl 800 still 8 beeps !
    any idea..Thank you
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: DELL 15 3537 La-9981p UMA enable .
    what do you mean "UMA enable"? have you converted it to UMA?
    • lapfix
      • Mar 2020
      • 2765
      • my workshop
      Not yet.i find this steps in other forum but.still got 8 beeps
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        If there is no picture on external monitor, probably the GPU is defective. but you can not be 100% sure.
        • lapfix
          • Mar 2020
          • 2765
          • my workshop
          The GPU is defective, the lap comes from another repair shop who damage the gpu with bad flux and heating...so i try to enable the UMA...that what i ask for here
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            To convert this mb to UMA-only two steps required.
            01 Remove PL802
            02 Shift RC99 to RC100(located near PCH part of SOC).
            I'm attaching pic for same but they are not very good quality but will still help you.
            • lapfix
              • Mar 2020
              • 2765
              • my workshop
              01 Remove PL802
              THank you mcplslg....but still 8 beeps!!
              PL 802 / Pl1101 / PL 800 removed.
              pjp 1300 / pjp 1301 / pjp 600 / pjp 1101 / pjp 1100 open jumper
              RC99 moved to RC100.
              Flashing bios with different dump from website and dell site.
              Always 8 Beeps..any idea
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                are you sure you plugged in the LVDS cable properly?
                how is picture on an external monitor?
                • lapfix
                  • Mar 2020
                  • 2765
                  • my workshop
                  YES , it s basic..changing screen and cable and pluged in.
                  For external ( HDMI ) i didn t try
                  • lapfix
                    • Mar 2020
                    • 2765
                    • my workshop
                    Good news , the conversion works ..but only at external display via HDMI.
                    without it 8 beeps..maybe the LVDS cable is the issue..i will try with another one to confirm.
                    Thanks for all
                    • Anirudhvl
                      • Feb 2018
                      • 25
                      • India
                      I did a successful conversion on LA-9981p, Here the power sequence video. Just sharing my experience
                      • lolohacko
                        • Apr 2018
                        • 36
                        • Iran
                        01 Remove PL802
                        THank you work FINEEEE....
                        • vickey_vip
                          • Mar 2016
                          • 136
                          • India
                          01 Remove PL802
                          thanks its working fine
                          new clear image i am posting here
                          • redman13
                            • Aug 2016
                            • 66
                            • bangkok
                            Thank All
                            • Calidebear
                              Dell 3537 laptop doesn't boot without embedded display.
                              by Calidebear
                              I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
                              So checked the schematics to bypass this issue.
                              Found something but I don't know how to read this schematics.
                              Dell 3537 mobo 9982p rev 3
                              Schematics attached,...
                              03-29-2025, 11:37 AM
                            • Akhlz001
                              by Akhlz001
                              09-20-2025, 07:15 PM
                            • master3112
                              by master3112
                              07-29-2025, 01:55 PM
                            • Talonts
                              Dell Latitude 7290 enable touchscreen entry in BIOS?
                              by Talonts
                              For those that have worked through the 7290 BIOS in the past, do you happen to know if there is a switch in it to enable a touchscreen entry in the BIOS setup?
                              The 7290, 7390, and 7490 all use the same BIOS, and the 7390 has an FHD touchscreen as one of its' options. It turns out it can be installed in a 7290 BUT since the BIOS doesn't have the entry to turn it on, it just becomes an FHD upgrade to the 7290.
                              I was hoping if any of you that had worked on the BIOS in the past would know if either the touchscreen settings could be turned on in the 7290, or the BIOS could...
                              06-24-2025, 11:27 PM
                            • rddube
                              Dell 15-3537 motherboard part identification
                              by rddube
                              Trying to identify the following part J7 FL M1R in the photo which is on one of the power circuits on a Dell 15-3537 motherboard. Went through the SMD code manual but couldn't find it and google doesn't either.
                              Help please and thank you
                              02-27-2024, 09:50 PM
