Dell 15-3537 motherboard part identification
by ismail119dell inspiron 14 7000 *motherboard part number (19765-1 2W1D5$CA)* services tag 1JSTN93 PROBLEM SSD NOT DETECTING IN THIS BIOS...
Channel: BIOS Requests ONLY!
by Baludoki80I have a wrong motherboard,does not switch on,no power.the framed part heats up,and the smd market is RUA3 but I couldn't find this part.I search schematic thank you...
by thinkcentreHello,
this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe... -
by rudyclabI bought this Dell at a local store! What a problem! At first, it was booting cyclically. After flashing and clearing the region, the 16MB flash drive started beeping differently each time: 2/1, 3/5, 3/6! It also beeped when removing the RAM or CPU! I suspect something's wrong with the 32MB flash drive. I flashed that too, and after several failures, the 32MB flash drive stopped showing any signs of life! That's why I'm stuck now—it doesn't respond to the power button or anything! Is this the end of the motherboard's life, or is it a BIOS issue? I need your help....
by mirakHi, I have a Dell Latitude 5410 motherboard (LA-J37), REV A00 PWB P/N 8578V.
I'm building a custom setup similar to a tablet but without touch capability by attaching this motherboard to the back of a USB-C monitor without the chassis. I have several critical questions before proceeding:
First, does my specific motherboard revision REV A00 PWB 8578V support USB-C power delivery charging, in order to be able to use the external monitor with just one usb c cable for both charging and receiving the image from the mb? I've read conflicting information suggesting some 5410...05-06-2026, 03:51 AM - Loading...
