MacBook Pro 15" Mid 2012 Unibody NO AUDIO
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    So get this, I replaced the Cirrus Chip on this board assuming it failed, and tested all the volts in most of the chip and they all do fine. But I still have no audio, I traced down to other few areas and still no avail. SO basically I am lost, I have the schematic and can't seem to figure out which is the INTERNAL AUDIO components I need to test and replace, I read the chip on the board schematics and I know common sense applies to some ares like AUDIO MIC etc...blah blah blah...My question is what should I look for on this board to find out why the audio is not playing, ALSO I replaced the Headphone jack as well and still have the same issue. Did a reset as well (smc and nvRam) and still no avail. Can someone point me in the right direction?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: MacBook Pro 15" Mid 2012 Unibody NO AUDIO
    No audio on speakers or headphones? No chime even after PRAM reset? Does audio device show up in System Preferences? Does it say Digital Out only?
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      No chime ever, no devices being shown either. Did reset and chime never came back. Swapped out Audio Codec chip with a new one and still no sound. I am lost at this point.
      sigpic
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3621
        • slovakia
        did u check audio ic for power, short on outputs ...
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          Let me check I am certain I did but that may have not been checked.
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            Yeah I did check this area. Its the AUDIO Codec Chip. I replaced it but I guess that wasnt the issue. It def is a short somewhere.
            sigpic
            • Abu Ali
              • Aug 2019
              • 15
              • Denmark
              Whats the board number. Schematic and boardview?
              • Abu Ali
                • Aug 2019
                • 15
                • Denmark
                Did you check the SMBus (I2C) connections to the AUDIO ICs?
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 674
                  The board is 820-3330B
                  sigpic
                  • Abu Ali
                    • Aug 2019
                    • 15
                    • Denmark
                    What happens when you press the volume buttons?
                    When it does not appear in system preferences, it means that the SMC does not "see" the audio device.
                    It could be SMBus connections failure or bad audio driver in firmware. Try make a backup of your EFI ROM, then flash a good known EFI Rom from this forum.
                    Other suggestions:
                    Maybe HDA_RST_L is held low?
                    Corrosion under SMC?
                    Bad connections caused by almost no see corrosions. Had an issue with missing charger detect signal. The trace looked fine, but was broken at the edge of a testpoint.
                    • Abu Ali
                      • Aug 2019
                      • 15
                      • Denmark
                      Any progress??
                      • samson7point1@yahoo.com
                        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                        by samson7point1@yahoo.com
                        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                        The player processes the audio signal using two different reference frequencies. The "R"...
                        04-30-2024, 11:22 AM
                      • silver60618
                        Macbook M3 A2991 Speaker Audio Amplifier IC
                        by silver60618
                        Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
                        I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
                        09-26-2025, 12:25 PM
                      • Darren Hibbert
                        MacBook A2179 Audio board+Power button boardview & schematic needed
                        by Darren Hibbert
                        Hi.
                        Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
                        There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
                        Many thanks. ...
                        08-21-2025, 02:38 PM
                      • grimacelord
                        MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
                        by grimacelord
                        I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
                        12-11-2023, 11:13 AM
                      • Rezendes
                        Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                        by Rezendes
                        Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                        I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                        The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                        05-10-2024, 02:18 PM
