So get this, I replaced the Cirrus Chip on this board assuming it failed, and tested all the volts in most of the chip and they all do fine. But I still have no audio, I traced down to other few areas and still no avail. SO basically I am lost, I have the schematic and can't seem to figure out which is the INTERNAL AUDIO components I need to test and replace, I read the chip on the board schematics and I know common sense applies to some ares like AUDIO MIC etc...blah blah blah...My question is what should I look for on this board to find out why the audio is not playing, ALSO I replaced the Headphone jack as well and still have the same issue. Did a reset as well (smc and nvRam) and still no avail. Can someone point me in the right direction?
MacBook Pro 15" Mid 2012 Unibody NO AUDIO
Re: MacBook Pro 15" Mid 2012 Unibody NO AUDIO
No audio on speakers or headphones? No chime even after PRAM reset? Does audio device show up in System Preferences? Does it say Digital Out only?OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
No chime ever, no devices being shown either. Did reset and chime never came back. Swapped out Audio Codec chip with a new one and still no sound. I am lost at this point.sigpic
MEOWING IN THE IMPOSSIBLE UNIVERSE!Comment
did u check audio ic for power, short on outputs ...Comment
What happens when you press the volume buttons?
When it does not appear in system preferences, it means that the SMC does not "see" the audio device.
It could be SMBus connections failure or bad audio driver in firmware. Try make a backup of your EFI ROM, then flash a good known EFI Rom from this forum.
Other suggestions:
Maybe HDA_RST_L is held low?
Corrosion under SMC?
Bad connections caused by almost no see corrosions. Had an issue with missing charger detect signal. The trace looked fine, but was broken at the edge of a testpoint.Comment
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
by silver60618Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?... -
Hi.
Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
Many thanks. ...-
08-21-2025, 02:38 PM -
by grimacelordHello,
I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase... -
by RezendesHello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...-
- Loading...
I am certain I did but that may have not been checked.
