lenovo b470 turns on only on battery
  • lapfix
    • Mar 2020
    • 2720
    • my workshop
    #81
    Re: lenovo b470 turns on only on battery
    Your PU3801 is shorted , did you check it ! make a wire between pin 1 and 8 just to confirm that.
    repeat taken voltage on pin 1-3 / pin 4 / pin 5-8 and post it
    • String2016
      • Nov 2015
      • 2235
      • philippines
      #82
      anyone can help please i still cannot solved this problem
      • String2016
        • Nov 2015
        • 2235
        • philippines
        #83
        yes pulled out and test it both pin 1 and pin 8 PU3801 hve 19v
        • lapfix
          • Mar 2020
          • 2720
          • my workshop
          #84
          Please see post #81
          • String2016
            • Nov 2015
            • 2235
            • philippines
            #85
            i checked on schematics page 81 is blank
            • lapfix
              • Mar 2020
              • 2720
              • my workshop
              #86
              No bro , i m not meaning schematics
              Post 81 = Your PU3801 is shorted , did you check it ! make a wire between pin 1 and 8 just to confirm that.
              • String2016
                • Nov 2015
                • 2235
                • philippines
                #87
                i checked it pn 1 and pin 8/ both have 19v of PU3801
                • lapfix
                  • Mar 2020
                  • 2720
                  • my workshop
                  #88
                  Without PU3801 soldered and you got 19V at pin 8 !!!
                  or did you make a wire btween 1 and 8!
                  • String2016
                    • Nov 2015
                    • 2235
                    • philippines
                    #89
                    with the PU3801 removed pin has 19v but pin8 0v
                    • String2016
                      • Nov 2015
                      • 2235
                      • philippines
                      #90
                      I try to make a wire from pin 1 to pin8 with PU3801 Removed still cannnot turn on with charger only plugged and both battery and charger plugged in
                      • String2016
                        • Nov 2015
                        • 2235
                        • philippines
                        #91
                        still not solved this problem anyone can help on this please
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          #92
                          I'm really confused by all of this, 5 pages of random measurements and component replacement and I can't follow the troubleshooting process.
                          Where are we now? Does it still turn on from battery but not from AC adapter?
                          Are all components properly soldered back on the board (and no random jumper wire!)?
                          Do we have the 19V power rail (DCBATOUT)?
                          Is any of PU3801, PU4001 and PU4002 shorted drain/source/gate?
                          • String2016
                            • Nov 2015
                            • 2235
                            • philippines
                            #93
                            @piernov laptop can turn on with battery only plugged in but cannot turn on with charger only plugged in and both charger and battery plugged in. PU3801 drain 0.700 source and gate both have pu4001 and pu4002 both drain, source have 0.700v and gate have 0l
