lenovo b470 turns on only on battery
  • String2016
    • Nov 2015
    • 2229
    • philippines
    Re: lenovo b470 turns on only on battery
    ok i try to removed pq4002
    • String2016
      • Nov 2015
      • 2229
      • philippines
      removed pq4002 plugged both charger and battery pin 7 have voltage of 3.3v
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        Any news ?
        • qayyum786
          • Aug 2018
          • 1933
          • INDIA
          Ok good put it back PQ4002
          And TELL ME WHAT VOLTAGES YOU ARE GETTING ON
          PU4001
          DRAIN = ?
          GATE = ?
          SOURCE = ?
          AFTER PLUG IN CHARGER
          • qayyum786
            • Aug 2018
            • 1933
            • INDIA
            If you will reply like this than it will take 2 days to fix it
            • String2016
              • Nov 2015
              • 2229
              • philippines
              #26
              sorry for the late response on the pu4001 SOURCE have 19v and GATE=19 but DRAIN=0V no voltages on the drain with charger only plugged in
              • qayyum786
                • Aug 2018
                • 1933
                • INDIA
                #27
                Do you have WhatsApp
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  #28
                  Check pq4001 pin no:- 5 = ?
                  • qayyum786
                    • Aug 2018
                    • 1933
                    • INDIA
                    #29
                    • String2016
                      • Nov 2015
                      • 2229
                      • philippines
                      #30
                      pq4001 pin 5 have 3.3v sorry i dont have whatsapp number
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        #31
                        Ok
                        Check RASISTOR VALUE
                        PR4002
                        PR4003
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          #32
                          Stay in touch continue till we fix this issue
                          • String2016
                            • Nov 2015
                            • 2229
                            • philippines
                            #33
                            pr4002 = 100kohms pr4003= 49.58kohms
                            • qayyum786
                              • Aug 2018
                              • 1933
                              • INDIA
                              #34
                              Remove PQ4001and make jumper from pin 3 to pin 4
                              • qayyum786
                                • Aug 2018
                                • 1933
                                • INDIA
                                #35
                                Any good news
                                • String2016
                                  • Nov 2015
                                  • 2229
                                  • philippines
                                  #36
                                  ok thanks ill update later
                                  • qayyum786
                                    • Aug 2018
                                    • 1933
                                    • INDIA
                                    #37
                                    Ok
                                    • String2016
                                      • Nov 2015
                                      • 2229
                                      • philippines
                                      #38
                                      update: @gayyum786 my mistakes of measurements here is the correct measurements on pq4001 6pin chip pin 1=19v pin2=3.3v pin 3 to pin6 both 0v
                                      • qayyum786
                                        • Aug 2018
                                        • 1933
                                        • INDIA
                                        #39
                                        Give ne value of pr4001 rasistor
                                        • qayyum786
                                          • Aug 2018
                                          • 1933
                                          • INDIA
                                          #40
                                          How come pin 1 is connected to the GROUND
                                          i think you are masure from pin 6
