Can't read 25Q128A SPI chip from a HP 840 G1
  • GulagMaster
    • Feb 2020
    • United State
    I'm trying to read a 25Q128A SPI chip from a HP 840 G1 and the software wont even detect it. I'm wondering if I need an adapter of some kind to make it work.
    I tried with windows using the Ch341a included software, wont detect and wont read
    I also tried with flashrom on linux, flashrom and I get this :
    sudo flashrom --programmer ch341a_spi -r hp840.bin
    flashrom v0.9.9-rc1-r1942 on Linux 4.15.0-88-generic (x86_64)
    flashrom is free software, get the source code at https://flashrom.org
    Calibrating delay loop... OK.
    No EEPROM/flash device found.
    Note: flashrom can never write if the flash chip isn't found automatically.
    I found the data sheet for the chip : https://www.google.com/url?sa=t&rct=...VxtJhOxoNvJL5q
    Please help, I need to remove the bios admin password.
  • Stevedb
    Stevedb
    • Feb 2018
    • 625
    • Belgium
    • Repairing electronics
    Re: Can't read 25Q128A SPI chip from a HP 840 G1
    Hi
    Which version do you use of software ch341 A programmer i got the 1.38 which support all. But it is on windows.
    Regards Steve
    • GulagMaster
      • Feb 2020
      • United State
      I use 1.31 on windows... I guess I will have to dig up that 1.38 version
      • Stevedb
        Stevedb
        • Feb 2018
        • 625
        • Belgium
        https://www.mdclab.it/lab-usb-programmer-ch341a.html
        • Stevedb
          Stevedb
          • Feb 2018
          • 625
          • Belgium
          You can also try this says Vesko356
          • Stevedb
            Stevedb
            • Feb 2018
            • 625
            • Belgium
            Does it work for reading bios chip
            • R_J
              • Jun 2012
              • 9710
              • Making Money
              Is the chip you are trying to read still mounted on the board, if it is, when you connect to it you are also trying to power anything else connected to the 3.3/5v line. IE: microprocessor, memory ic's etc.
              • brew99
                • Jan 2019
                • 132
                that's a 1.8V chip, so are you using a 1.8V adapter with the 341A?
                • GulagMaster
                  • Feb 2020
                  • United State
                  With the new software (asprogrammer) it does, but I can't write it. it hang a few second clicking the write button
                  yes it is still soldered to the board. I am simply using a test clip. using a multimetre the chip gets 3.3v on pin 8.
                  no I dont. but i did order one a few week ago... still waiting on it, hoping it wont come with a free corona virus sample.
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    • Gadget & motorcycle addicted
                    There is a new version of AsProgrammer and it's working more stable with ch341a.
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                    • doa379
                      • Aug 2021
                      • 19
                      • US
                      Please provide an update, could you read the chip?
                      • pcnetwork
                        • Jan 2021
                        • 32
                        • Venezuela
                        Thank you, it helped me a lot
                        • twonk9098
                          • Aug 2018
                          • 76
                          I have found NeoProgrammer to be the best software to use with the CH431A as yet.
                          This can be found here and seems to support alot of chips.
                          https://khandishnetwork.com/dl/neopr...-8-22-06-2021/
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            You're welcome.
                            There's newer version (V2.2.0.10) than the one at your link:
                            https://www.badcaps.net/forum/showth...11#post1215111
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • vijayppatel017
                              5420 bios Chip interchange and ssd not detect
                              by vijayppatel017
                              I have same board GDF40 LA-K491P REV 3.0(A02),
                              one board has login issue, when we install os and at initial login page it ask to login with Microsoft account, looks remote management lock, and other laptop is clean, so I have remove Bios chip from clean laptop and fixed in another one. now my remote management lock laptop's service tag changed. then I try to install os but ssd not detecting, also not showing in bios as well, I have reset bios as factory setting, but not help. then I have again interchange bios chip , so now both are original and it work ok, also shows ssd in bios as well....
                              01-15-2026, 09:15 AM
                            • Berun
                              HP EliteDesk 800 G6 mini - BIOS Chip (GD25B127DSIG) replacement after epic fail :D
                              by Berun
                              Hello All,
                              I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
                              I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
                              I read the Chip on board 8 times (with power...
                              04-09-2026, 06:24 AM
                            • chonkyrabbit
                              Need help disassembling xx30 thinkpad battery BMS chip firmware
                              by chonkyrabbit
                              Hi there,
                              I need some help reverse engineering a BMS chip from a battery for an xx30 thinkpad. The Laptop uses a challenge-response type of system to verify if a battery is genuine:
                              The laptop writes four bytes to 0x3C and then reads 0x3C. The battery responds with "Lenovo JapanXXXX", with the Xs corresponding to four response bytes. For example "0xDC 0x42 0x5B 0x82" to BMS => "Lenovo Japan0x9F 0x76 0x97 0x2E" from BMS.
                              What I know so far:
                              • It's an 51F51 BMS chip based on the R2J24020F group. Karosium has already figured out how to dump
                              01-21-2026, 10:32 AM
                            • portal7
                              Dell Latitude 5440 - Help reading dual Winbond SPI flash in-circuit with CH341A on Linux
                              by portal7
                              I’m working on a relatively new Dell Latitude 5440, Intel i5 model, and I’m trying to make clean backups of the onboard SPI flash chips without desoldering, if possible.
                              The motherboard has two Winbond SPI flash ICs close to each other:
                              - UC2: Winbond 25Q256JVEN, likely 32 MB
                              - UC6: Winbond 25R128JVSN, appears to be 16 MB
                              I’m using a CH341A programmer with a SOIC8 clip on Linux.
                              Tools tested:
                              - flashrom on Linux
                              - IMSProg GUI on Linux
                              With flashrom, UC6 is sometimes detected...
                              05-14-2026, 12:26 PM
