Can't read 25Q128A SPI chip from a HP 840 G1
  • GulagMaster
    • Feb 2020
    • United State
    I'm trying to read a 25Q128A SPI chip from a HP 840 G1 and the software wont even detect it. I'm wondering if I need an adapter of some kind to make it work.
    I tried with windows using the Ch341a included software, wont detect and wont read
    I also tried with flashrom on linux, flashrom and I get this :
    sudo flashrom --programmer ch341a_spi -r hp840.bin
    flashrom v0.9.9-rc1-r1942 on Linux 4.15.0-88-generic (x86_64)
    flashrom is free software, get the source code at https://flashrom.org
    Calibrating delay loop... OK.
    No EEPROM/flash device found.
    Note: flashrom can never write if the flash chip isn't found automatically.
    I found the data sheet for the chip : https://www.google.com/url?sa=t&rct=...VxtJhOxoNvJL5q
    Please help, I need to remove the bios admin password.
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Can't read 25Q128A SPI chip from a HP 840 G1
    Hi
    Which version do you use of software ch341 A programmer i got the 1.38 which support all. But it is on windows.
    Regards Steve
    • GulagMaster
      • Feb 2020
      • United State
      I use 1.31 on windows... I guess I will have to dig up that 1.38 version
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        https://www.mdclab.it/lab-usb-programmer-ch341a.html
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          You can also try this says Vesko356
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            Does it work for reading bios chip
            • R_J
              • Jun 2012
              • 9607
              Is the chip you are trying to read still mounted on the board, if it is, when you connect to it you are also trying to power anything else connected to the 3.3/5v line. IE: microprocessor, memory ic's etc.
              • brew99
                • Jan 2019
                • 132
                that's a 1.8V chip, so are you using a 1.8V adapter with the 341A?
                • GulagMaster
                  • Feb 2020
                  • United State
                  With the new software (asprogrammer) it does, but I can't write it. it hang a few second clicking the write button
                  yes it is still soldered to the board. I am simply using a test clip. using a multimetre the chip gets 3.3v on pin 8.
                  no I dont. but i did order one a few week ago... still waiting on it, hoping it wont come with a free corona virus sample.
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    There is a new version of AsProgrammer and it's working more stable with ch341a.
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                    • doa379
                      • Aug 2021
                      • 19
                      • US
                      Please provide an update, could you read the chip?
                      • pcnetwork
                        • Jan 2021
                        • 30
                        • Venezuela
                        Thank you, it helped me a lot
                        • twonk9098
                          • Aug 2018
                          • 75
                          I have found NeoProgrammer to be the best software to use with the CH431A as yet.
                          This can be found here and seems to support alot of chips.
                          https://khandishnetwork.com/dl/neopr...-8-22-06-2021/
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            You're welcome.
                            There's newer version (V2.2.0.10) than the one at your link:
                            https://www.badcaps.net/forum/showth...11#post1215111
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • DynaxSC
                              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                              by DynaxSC
                              Hi
                              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                              08-04-2025, 12:20 PM
                            • BMCappelletti
                              Asus Chromebox CN62 - wrong chip put on BIOS reader
                              by BMCappelletti
                              Long story short:
                              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                              - gave the computer to his son a couple years later
                              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                              (seems like the story was not that short)
                              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                              01-08-2025, 07:27 PM
                            • inck243
                              Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                              by inck243
                              Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                              The BIOS...
                              07-25-2024, 09:17 AM
                            • intelg
                              HP Elitedesk 800 G6 lost BIOS admin password
                              by intelg
                              Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                              Here is the hardware identification specs:
                              HP EliteDesk 800 G6 Desktop Mini PC
                              Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                              BIOS ver S21 Ver. 02.05.01 01/05/2021
                              Born on date: 07/26/2021
                              SN MXL11841GN
                              SKU 3X8V9UCHABA
                              UUID 8116E79EF6FFE94DB0B98A3188270C5C
                              SYSTEM BOARD ID 8710
                              SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                              11-03-2023, 02:05 AM
