Macbook pro A1706 820-00923-A BKLT_EN_R missing
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    I need some help.
    I received Macbook pro A1706 820-00923-A from customer that was water damage.
    After open it there was a liquid damage around lcd connector. I clean it and measure but there is no short.
    Tried to turn it on but got blank display but the fan spin and the keyboard backlight is on so i think it only has problem with backlight or display.
    So later i measure J8500 port:
    PPVOUT_S0_LCDBKLT = 0v
    PP3V3_S0SW_LCD = 3,2v
    PP5V_S0SW_LCD = 5v
    So i measure R8442 near Backlight ic and found out there is no Voltage on BKLT_EN_R.
    The BKLT_EN_R goes straight to CPU. does it means that CPU is fail or am i missing something.
    So i was looking for the source as you can see in the picture that
    LCDBKLT_EN_L is 12.9V
    PPVIN_S0SW_LCDBKLT_R is 13V
    but i get 0V on PPVIN_S0SW_BKLT
    so does it mean that the main problem is Q8400 mosfet?
    Really appreciate for the help.
    http://www.imagebam.com/image/3b12301330282981
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Macbook pro A1706 820-00923-A BKLT_EN_R missing
    Take a picture of the LCD connector on the logic board.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      here is the picture
      http://www.imagebam.com/image/97a8851330707138
      http://www.imagebam.com/image/6bccf01330707700
      • piernov
        • Jan 2016
        • 4439
        • France
        It doesn't look like the connector itself is liquid damaged so that's a good sign.
        I think you have image but just no backlight. Measure resistance to ground on PPVIN_S0SW_BKLT, with sceen connected then screen disconnected.
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          i get 0.736 with and without LCD
          • pgoodpgood
            • Jan 2020
            • holland
            You can shine a bright torch through the apple logo. If backlight is problem you should see a portion of your image on the screen.
            You will then know if it is no-backlight with image or no backlight with no image. Then you know where to troubleshoot further.
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              Thanks for the reply.
              I already tried with torch but there’s no image at all so i think it is no image and no backlight.
              Any suggestion for the next step i should do?
              • Pedro147
                • Sep 2016
                • 168
                Hi @Kingskie I have the same board with a similar issue. Did you ever make any headway with this board please ? Not sure if these are Retina screens but they are dark and it’s very hard to see if you have image but no BKLT by shining a torch through the Apple logo
                My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
                • Jilly
                  • Mar 2017
                  • Qatar
                  the torch through the apple logo will not work on this model, the apple logo is not semi transparent on any with the silver coloured logo, only those with the white logo.
                  • vinse
                    • Nov 2018
                    • 10
                    • france
                    jump r8590 ,r8591,r8592
                    check if you get PP3V3_S0SW_LCD,PP5V_S0SW_LCD
                    • Agrim
                      • Nov 2022
                      • Nepal
                      I have same issue like have trackpad working, fan after a while get turning on but amp meter shows 20.2v and 71ma steady on monitor connected. but no display. l7410, l7420, and l74 30 shows ov . any further help would be appreciable
                      • mon2
                        • Dec 2019
                        • 14664
                        What is the voltage to ground of ppbus_g3h ?
                        You can measure at fuse F7000.
                        • vinse
                          • Nov 2018
                          • 10
                          • france
                          can you diode mode the edp lines aux P and aux N ??
                          • Adogabriel100
                            Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                            by Adogabriel100
                            Hey! This is a A1278 macbook 2011.
                            Problem: Not turning on / No green light
                            Im using by3200s charger.
                            Voltajes:
                            PPBUS_G3H = 12.26v
                            SMC_RESET_L = 3.3v
                            PP3V42_G3H = 3.42v
                            U7000 =
                            Pin 1 CHGR_AGATE = 0v
                            Pin 2 CHRG_DCIN = 19v
                            Pin 3 CHRG_ACIN = 4.6v
                            Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                            Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                            Pin 12 PP3V42_G3H = 3.42v
                            Pin 13 CHRG_RST_L = 3.3V
                            Pin 14 SMC_BC_ACOK = 0.8V
                            Pin 19 PP5V1_CHRG_VDD = 5.05V
                            Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                            04-01-2024, 01:02 PM
                          • Danielreinaa
                            HELP need password bios Macbook A1706
                            by Danielreinaa
                            Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                            Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                            Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                            gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                            Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                            09-07-2024, 03:47 PM
                          • capon5153
                            Macbook A1706 works perfectly but no data on USB C
                            by capon5153
                            hello,
                            so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                            i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                            06-22-2025, 09:42 AM
                          • B2L_Repairs
                            Macbook A1706 touchpad and keyboard not working. Please help
                            by B2L_Repairs
                            Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                            10-09-2023, 04:56 AM
                          • obelix24
                            A1706 - Macbook pro - one USB-C port only 20V 0A
                            by obelix24
                            I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                            I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                            There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                            There were some broken pads under CD3215 but i've recreated them.
                            What should be...
                            05-22-2024, 08:04 AM
