very weired issue with step dowd IC SY8208B!! please help
  • Weelcup
    TopTech
    • Oct 2017
    • 302
    Hi friends.
    I have an OMEN 17w board. no shorts in the board. but it cannot provide the 3.3v output from sy8208B IC. although the 5.0v is provided.
    instead it only outputs 0.635v not 3.3v.
    I have replaced the ic with a fully working sy8208B but still the same issue. I checked the diode values on the all pins of the SY8208B and compare it with the ones on the working board and it matched. So I really do not know what to check next. by the way, sy8208B warms up to 38C when I powers up the board. but no shorts or low resistant component are detected....
    I did not replace the super IO chip yet. but wondering if it is the cause
    any help will be much appreciated... I have attached the schematics... the ic I am referring to is PU2001..
    thanks
  • khaahk
    • Dec 2013
    • 763
    • Estonia
    Re: very weired issue with step dowd IC SY8208B!! please help
    Pin 5 has 3.3V?
    How much current is drawn from psu?
    • u666sa
      • Jan 2014
      • 70
      • Russia
      Since any help is appreciated. This kind of google search SY8208B нет 3.3 might provide some help.
      • Francisco.s
        • 686
        • Spain
        Probably 5VS5_ON is present, but S5_ON is missing.
        Try to reprogram IT8987.
        • Weelcup
          TopTech
          • Oct 2017
          • 302
          thanks for the advice. I suspected that but if I am not mistaken IT8987E is auto programable and not in need to reprogram like IT8586E. I just soldered a new IT8987E. but same issue is still present.
          but thanks you very much for the help..
          by the way.. S5_ON is present...
          • Weelcup
            TopTech
            • Oct 2017
            • 302
            Originally posted by khaahk
            Pin 5 has 3.3V?
            thanks for the help
            Yes the LDO 3.278V is present on pin 5...
            this is a very complicated board in regards to the dc power tip. I was not able to power it on using powersupply to measure the current. but the thermal image shows only the warming ICs are the IO and Sy8208B are using the current. SY8208E temp is 38 and the IO chip is about 30C. of couse when the main battery removed. because when it is connect the currect go to the charge ic and rail. so it is charging correctly.
            I expect around 0.1A or 0.2A only considering no heating issues ….
            I tried to inject only 2V at the rail but no current consume.
            all the resistor measures around the Sy8208B are correct.
            thanks again
            • Weelcup
              TopTech
              • Oct 2017
              • 302
              Thanks .. I downloaded the datasheet..
              • Weelcup
                TopTech
                • Oct 2017
                • 302
                what could possibly made SY8208B to output lower voltage 0.635V while the 19v in and 3.280V enable signal are present?
                • Francisco.s
                  • 686
                  • Spain
                  Can you check for pulses in both pins of PC2008 with a oscilloscope?
                  There must be pulses in PC2008, and also in pin 6 of PU2001.
                  Also make sure you replaced PU2001 with the correct part, sometimes vendors sell this chips wrong, SY8208C instead of SY8208B.
                  • Weelcup
                    TopTech
                    • Oct 2017
                    • 302
                    Thanks a lot.
                    Unfortunately, I do not have the oscilloscope yet. So it will be difficult to know if there are pulses.
                    However, can we assume 2 scenarios saying the pulses are there / the pulses are not there so what might be a responsible fault so that I just replace it.
                    In terms of wrong chip vendor. Well, I have a fully working omen board, exactly the same as the non working one. I brought the sy8208b from the working board. Also the marking code on the chip is MS3xx not the MT5xx so I am pretty sure it is the right one.
                    One more thing I just noticed. The bios chip got 2.02V when the I press the power button. I think it was supposed to come from the output of the sy8208B... just confused how did it get the 2V while the sy8208B tail only gets 0.635V...
                    Thanks again
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Pin2-Pgood present??
                      • Francisco.s
                        • 686
                        • Spain
                        PC2008 is a fundamental component to make good pulses at PU2001 output.
                        Make sure PC2008 is in good condition or replace it, also check there is no open circuit between its pads and PU2001.
                        got 2.02V when the I press the power button....
                        It is not clear from schematic where +3VSPI cames from.
                        Usually it should come from +3VPCU.
                        • Weelcup
                          TopTech
                          • Oct 2017
                          • 302
                          Thanks a lot.
                          I check them tonight. I will replace the ldo cap. And will let you informed of the results.
                          Thanks again.
                          • Weelcup
                            TopTech
                            • Oct 2017
                            • 302
                            The ldo replacement did not work.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              You didnt answered this
                              • smali
                                • Sep 2014
                                • 287
                                • Pakistan
                                How many ohms showing PL2001 to Ground??
                                • khaahk
                                  • Dec 2013
                                  • 763
                                  • Estonia
                                  Disconnect PJP2001 and see if it makes 3.3v ok. If ok, then you've got some secondary rail using too much current.
                                  • Weelcup
                                    TopTech
                                    • Oct 2017
                                    • 302
                                    Sorry, the customer has taken the motherboard...
                                    • rounin
                                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                      by rounin
                                      🛠 Original Issue
                                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                      04-19-2025, 01:18 AM
                                    • ugamazing
                                      by ugamazing
                                      12-17-2024, 07:05 PM
                                    • PantherDave
                                      by PantherDave
                                      Hi all!
                                      05-29-2024, 02:01 PM
                                    • elmark
                                      HP 15-cw1002ua strange keyboard issue
                                      by elmark
                                      HP Pavilion 15-CW1002UA
                                      S/N 5CD0251CBC
                                      P/N 7KE54EA
                                      Hello guys!
                                      I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                      It powers on OK and has no other issues except the following:
                                      • CAPS LOCK does not work at all
                                      • Fn button toggles Flight Mode
                                      • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                      • (with SHIFT pressed: 't%' and 'y^' respectively)
                                      I initially thought it was a keyboard malfunction (internal short, etc.),
                                      but when I press and hold...
                                      06-27-2025, 01:10 AM
                                    • Simone Vergani
                                      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                      by Simone Vergani
                                      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                      To assist with troubleshooting, I'm attaching two power circuit schematics:
                                      • Power
                                      03-05-2025, 02:25 PM
