very weired issue with step dowd IC SY8208B!! please help
  • Weelcup
    TopTech
    • Oct 2017
    • 307
    Hi friends.
    I have an OMEN 17w board. no shorts in the board. but it cannot provide the 3.3v output from sy8208B IC. although the 5.0v is provided.
    instead it only outputs 0.635v not 3.3v.
    I have replaced the ic with a fully working sy8208B but still the same issue. I checked the diode values on the all pins of the SY8208B and compare it with the ones on the working board and it matched. So I really do not know what to check next. by the way, sy8208B warms up to 38C when I powers up the board. but no shorts or low resistant component are detected....
    I did not replace the super IO chip yet. but wondering if it is the cause
    any help will be much appreciated... I have attached the schematics... the ic I am referring to is PU2001..
    thanks
  • khaahk
    • Dec 2013
    • 816
    • Estonia
    Re: very weired issue with step dowd IC SY8208B!! please help
    Pin 5 has 3.3V?
    How much current is drawn from psu?
    • u666sa
      • Jan 2014
      • 87
      Since any help is appreciated. This kind of google search SY8208B нет 3.3 might provide some help.
      • Francisco.s
        • 686
        • Spain
        Probably 5VS5_ON is present, but S5_ON is missing.
        Try to reprogram IT8987.
        • Weelcup
          TopTech
          • Oct 2017
          • 307
          thanks for the advice. I suspected that but if I am not mistaken IT8987E is auto programable and not in need to reprogram like IT8586E. I just soldered a new IT8987E. but same issue is still present.
          but thanks you very much for the help..
          by the way.. S5_ON is present...
          • Weelcup
            TopTech
            • Oct 2017
            • 307
            Originally posted by khaahk
            Pin 5 has 3.3V?
            thanks for the help
            Yes the LDO 3.278V is present on pin 5...
            this is a very complicated board in regards to the dc power tip. I was not able to power it on using powersupply to measure the current. but the thermal image shows only the warming ICs are the IO and Sy8208B are using the current. SY8208E temp is 38 and the IO chip is about 30C. of couse when the main battery removed. because when it is connect the currect go to the charge ic and rail. so it is charging correctly.
            I expect around 0.1A or 0.2A only considering no heating issues ….
            I tried to inject only 2V at the rail but no current consume.
            all the resistor measures around the Sy8208B are correct.
            thanks again
            • Weelcup
              TopTech
              • Oct 2017
              • 307
              Thanks .. I downloaded the datasheet..
              • Weelcup
                TopTech
                • Oct 2017
                • 307
                what could possibly made SY8208B to output lower voltage 0.635V while the 19v in and 3.280V enable signal are present?
                • Francisco.s
                  • 686
                  • Spain
                  Can you check for pulses in both pins of PC2008 with a oscilloscope?
                  There must be pulses in PC2008, and also in pin 6 of PU2001.
                  Also make sure you replaced PU2001 with the correct part, sometimes vendors sell this chips wrong, SY8208C instead of SY8208B.
                  • Weelcup
                    TopTech
                    • Oct 2017
                    • 307
                    Thanks a lot.
                    Unfortunately, I do not have the oscilloscope yet. So it will be difficult to know if there are pulses.
                    However, can we assume 2 scenarios saying the pulses are there / the pulses are not there so what might be a responsible fault so that I just replace it.
                    In terms of wrong chip vendor. Well, I have a fully working omen board, exactly the same as the non working one. I brought the sy8208b from the working board. Also the marking code on the chip is MS3xx not the MT5xx so I am pretty sure it is the right one.
                    One more thing I just noticed. The bios chip got 2.02V when the I press the power button. I think it was supposed to come from the output of the sy8208B... just confused how did it get the 2V while the sy8208B tail only gets 0.635V...
                    Thanks again
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Pin2-Pgood present??
                      • Francisco.s
                        • 686
                        • Spain
                        PC2008 is a fundamental component to make good pulses at PU2001 output.
                        Make sure PC2008 is in good condition or replace it, also check there is no open circuit between its pads and PU2001.
                        got 2.02V when the I press the power button....
                        It is not clear from schematic where +3VSPI cames from.
                        Usually it should come from +3VPCU.
                        • Weelcup
                          TopTech
                          • Oct 2017
                          • 307
                          Thanks a lot.
                          I check them tonight. I will replace the ldo cap. And will let you informed of the results.
                          Thanks again.
                          • Weelcup
                            TopTech
                            • Oct 2017
                            • 307
                            The ldo replacement did not work.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              You didnt answered this
                              • smali
                                • Sep 2014
                                • 287
                                • Pakistan
                                How many ohms showing PL2001 to Ground??
                                • khaahk
                                  • Dec 2013
                                  • 816
                                  • Estonia
                                  Disconnect PJP2001 and see if it makes 3.3v ok. If ok, then you've got some secondary rail using too much current.
                                  • Weelcup
                                    TopTech
                                    • Oct 2017
                                    • 307
                                    Sorry, the customer has taken the motherboard...
                                    • rounin
                                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                      by rounin
                                      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                      🛠 Original Issue
                                      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                      04-19-2025, 01:18 AM
                                    • ugamazing
                                      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                      by ugamazing
                                      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                      12-17-2024, 07:05 PM
                                    • PantherDave
                                      by PantherDave
                                      Hi all!
                                      05-29-2024, 02:01 PM
                                    • shahnld
                                      Lenovo legion 5 pro startup issue
                                      by shahnld
                                      Good day Experts
                                      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                      08-24-2025, 12:31 PM
                                    • ahmarzo
                                      Acer laptop battery draining issue
                                      by ahmarzo
                                      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                      08-02-2025, 06:39 AM
