Lenovo Yoga 500-14ISK - No battery charge
  • rbvndonh
    • Mar 2021
    • 162
    • B
    Re: Lenovo Yoga 500-14ISK - No battery charge
    Originally posted by matkauton
    Very useful theme. I will upload a picture with the exact resistor!
    Hi, so you unsolder 2 resistors and 1 capacitor and replace 10 ohm resistor?
    Why you desolder those items instead only replacing resistor?
    • rbvndonh
      • Mar 2021
      • 162
      • B
      I have yoga 500-15IBD with same malfunction.
      I've checked motherboard config and it is different.
      Have someone solution for my laptop?
      Thank you
      • marthin
        • Jun 2018
        • 5
        • argentina
        thanks for the solution
        • bachir2004
          • Feb 2015
          • 439
          • maroc
          I confirm motherboard same default but different behavior.it would sometimes charge the battery and work as normal but if the battery is too low it would not start(just on and off instantly).pr4413 had a value of 99.8k changing it to 10 ohms solves the problem.
          • lazybigyan
            • Mar 2017
            • 82
            • Nepal
            I have some new issue like laptop work with battery is ok but if i connect the charger remove battery then it turn off in 2 second. battery not charge bq24780 been changed what should i do help me.
            • Conste
              • Oct 2018
              • 235
              Had the same Problem, but my Unit didn't Turn on at all anymore. AC OK missing on Charger Chip. Chip blown.
              Then I replaced Charger Chip, Unit worked again Fine.
              Now after two weeks the flickering issue and not charging. Replaced resistor this morning to a 10 Ohms one but with bigger footprint.
              Charging and working again, I hope this works longer.
              • audrimars
                • Apr 2020
                • 48
                • palestine
                #27
                very useful theme. I will upload a picture with the exact resistor!
                that"s it
                thanks alot
                • huliki
                  • Dec 2022
                  • türkiye
                  #28
                  Originally posted by teknikbursa
                  find the resistor on image and change it with 10 ohm resistor
                  thank you teknikbursa
                  • Califauna
                    • Jul 2020
                    • 28
                    • Spain
                    #29
                    Hi all. I'm having the same problem with my board. Confirmed that the 10 ohm resistor identified in the picture (where it says "This one") is blown on my board and is reading infinite resistance on the meter. I have another of the same board and on that board the resistance is 10 Ohms.
                    Is anyone able to confirm if this is a design flaw with these boards? I can use the other board as a donor and take it's IC and resistor and place it there (or buy them) but if it's likely to blow again I'd like to know what to do first.
                    Also, is it necessary to unsolder the two resistors and capacitor that matkauton​ removed? If so I can use one of the two 10 ohms resistors there to replace the faulty one.
                    Thanks for any help.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      Check resistance to GND on both pads of 10 Ohms resistor after de soldering. If the resistance is high,you can go ahead with replacing the faulty parts.However,one of the pads of 10 Ohms resistor may be shorted to GND and usually that indicates a faulty cap around charger IC.
                      • Califauna
                        • Jul 2020
                        • 28
                        • Spain
                        #31
                        After replacing the mentioned resistor this has been working for me for a few weeks now. I couldn't manage to solder it using an iron, so I used hot air.
                        Never sold anything this small before. When I received the packet of resistors I thought I had been ripped off and almost ordered another packet. All I could find were specks of dust until I thought to look at them using my phone as a microscope.
                        • REpairAT
                          • Nov 2020
                          • 152
                          • Austria
                          #32
                          Confirming that this is the solution. Thank you!
                          • techfreak9356
                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                            by techfreak9356
                            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                            09-14-2023, 11:10 PM
                          • huzo
                            Lenovo y700 not showing battery charge state
                            by huzo
                            The above mentioned laptop with the board NM B-163 is showing 1% battery charge in OS,but the battery holds for about 2h when unplugged from the charger ....when plugged in the windows says plugged in,the voltage goes up from 13.6V when empty to 15.7V when full,nominal voltage is 14.8V for that battery....SO it does charge and it does deplete, but it doesn't show charging or goes up from 1% on the battery meter....Here is the schematic for the battery charge connector, how should i test data and clock lines? They are connected to the EC on the mentioned pins,so no brekage,i don't have an oscilloscope...
                            11-21-2025, 07:36 AM
                          • razenxd
                            How can I charge that battery pack?
                            by razenxd
                            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                            Now, I have noticed a few things.
                            The "dead" battery, while connected to charger and NOT Charging will...
                            12-05-2024, 06:11 AM
                          • emeskay
                            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                            by emeskay
                            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                            08-06-2024, 07:13 AM
                          • ruletero
                            Acer a515-43 low battery charge voltage
                            by ruletero
                            Hi
                            Acer A515-43
                            LA-H801P
                            Fail: Does not charge battery, has low voltaje on connector.
                            Laptop didn't want to turn on, only charge led blinked.
                            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                            10-24-2022, 02:31 PM
