please help acer v3-571 no data
  • mo000
    • Nov 2017
    • 276
    • algeria
    hi
    after i repair the laptop , the laptop power on for 3 sec and off and power on again and off , i try to flash main and ec bios but nothing change
    any idea please .
  • mo000
    • Nov 2017
    • 276
    • algeria
    Re: please help acer v3-571 no data
    NO CPU COR
    +VCCSAP=0.9V
    1.5VP is missing comes from pu6 RT8207M vdd on pin11=5v
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Its better if you mention mb code and attache schematic, if available. Check whether you are getting 3VS and 5VS after switching on.
      • mo000
        • Nov 2017
        • 276
        • algeria
        motherboard model Q5WV1/Q5WS1 compal LA-7912P
        there is 3VALW=3.4v AND 5VALW=5v
        and i have 3vs and 5vs from pu21 pu22
        but 1.5v is missing .
        • piernov
          • Jan 2016
          • 4435
          • France
          Check enable signals S5 and S3 on PU6.
          Measure resistance to ground on +1.5VP.
          • mo000
            • Nov 2017
            • 276
            • algeria
            s3 pin7=3.2v ; s5 pin8=3.4v
            which resistance exactly ? .
            • mo000
              • Nov 2017
              • 276
              • algeria
              any help ?
              • Techtiger
                • Oct 2014
                • 1601
                • france
                Check PU6 pin 7 8 9 10 11
                PQ24 Drain 19+B , test PQ24/25 for any short, remove one pad of PL 9 and test the resistance both sides
                • mo000
                  • Nov 2017
                  • 276
                  • algeria
                  thank's for help
                  pu6
                  pin 7=3.27
                  pin8=3.40v
                  pin9=0.13v
                  pin10=0v
                  i will check the others .
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    Originally posted by mo000
                    thank's for help
                    pu6
                    pin 7=3.27
                    pin8=3.40v
                    pin9=0.13v
                    pin10=0v
                    Pin 11 VDD ?
                    • mo000
                      • Nov 2017
                      • 276
                      • algeria
                      Pin 11 VDD ?
                      pin11 vdd=5v
                      pq24 drain=0.14v
                      no short in pq24 and 25
                      pl9
                      side read 334 ; side no reading no buzzer .
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        PL8 both should be 19+V this voltage comes to the Drain of PQ24 , if the Drain is 0.14V you have to trace it back check pc68/69 caps for short
                        • mo000
                          • Nov 2017
                          • 276
                          • algeria
                          sory i make a mistake
                          i check again the voltage on pq24 drain i found 19v but no 1.5vp in the source .
                          • Techtiger
                            • Oct 2014
                            • 1601
                            • france
                            Ok now it’s time to change the PU6 and see for any changes ,check PR89 PC71
                            • mo000
                              • Nov 2017
                              • 276
                              • algeria
                              Ok now it's time to change the PU6 and see for any changes ,check PR89 PC71
                              I'm searching for an replacement
                              i have RT8207 but is not Appropriate.
                              • welcometoo
                                acer nitro 5 AN515-55 no display / caps lock
                                by welcometoo
                                Hi brothers, please i need help diagnose acer nitro 5 no display issue.
                                model: nitro 5 an515-55
                                motherboard part number: GH51M LA-K862P Rev: 1A
                                i received this laptop with a short in power line, it was a capacitor + a mosfet on VCORE line , the laptop turned on cpu and gpu getting warm all voltages seem ok except vcc_gt but no display/caps lock activity also no hdmi out.
                                i flashed new bios also ec(ene kb9022) the same result .
                                disabled discrete graphics (rtx 3060 ) by cutting its power and shifting a resisror near pch VCC_GT comes but still the same...
                                07-05-2025, 11:11 AM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • kingiii
                                Possbility of data recovery, is it true?
                                by kingiii
                                Hello, A customer told us that there is a data recovery company that can by pass IMac pro 2020 with t2 chipset GPU to get their data back, I am wondering if that is possible. GPU is shorted and Imac wont boot at all. I informed customers that data are almost impossible to be retrived, and they are upset and think we are BS them. Of course being up in Canada, people like to believe that usa will have a better solution for it, a US data recovery company they searched on google told customer that they could get the data back without needing worry about T2 chip or Imac not working all that, I do not...
                                07-02-2025, 02:29 PM
                              • mscottdoran@gmail.com
                                Can anyone identify the classification of this data signal?
                                by mscottdoran@gmail.com
                                Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
                                The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
                                The boards are powered by a ground referenced...
                                02-08-2025, 11:31 AM
                              • Joe24
                                Maytag Whirlpool Kenmore clothes dryer data bus
                                by Joe24
                                Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                I've been over the board looking for...
                                01-13-2025, 06:50 PM
