Possbility of data recovery, is it true?
  • kingiii
    • Mar 2020
    • 19
    • canada
    Hello, A customer told us that there is a data recovery company that can by pass IMac pro 2020 with t2 chipset GPU to get their data back, I am wondering if that is possible. GPU is shorted and Imac wont boot at all. I informed customers that data are almost impossible to be retrived, and they are upset and think we are BS them. Of course being up in Canada, people like to believe that usa will have a better solution for it, a US data recovery company they searched on google told customer that they could get the data back without needing worry about T2 chip or Imac not working all that, I do not believe it at all, but just in case, if anyone knows if it is possible or just BS. The GPU is dead for sure on the 2020 Imac pro, shorted with 0oms on its power rail. I understand if GPU can be replaced, then there is data, but by pass GPU or get another Logicboard and by pass T2 .... is that possible to get data?
    Thanks for reading and input please
  • dellxps15
    • Feb 2014
    • 1590
    • italy
    maybe they will just replace the bad gpu ?
    • kingiii
      • Mar 2020
      • 19
      • canada
      That would make sense, but I think my customer was told they did not have to change anything, and can by pass GPU or the worst would be a new logic board and transfer the ssd over then data would be back.
      As far as I can tell, those options are impossible to get data back. but it is just my opinion.
      • dellxps15
        • Feb 2014
        • 1590
        • italy
        for data transfer i think they need to swap cpu, ssd , t2 chip. it's not an easy task so i assume price is not in the low level....
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • tommy97
          iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
          by tommy97
          we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
          Any ideas what might've...
          04-20-2024, 04:48 AM
        • DoOm86
          Swap nand flash smartphone for data recovery
          by DoOm86
          Hello everyone.
          I would like to know more about the following topic:
          Nand flash on smartphone for data recovery.
          I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
          But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
          How does it works? How do I know if data are encrypted or where is the key?
          I know there are also very expensive external socket where you can put the nand flash in...
          08-20-2023, 07:10 AM
        • abajor
          Attempting Data Recovery WD20EARS series HDD Reads as 0 byte drive.
          by abajor
          I was wondering if there is a knowledge base on troubleshooting HDD failures and when it might be viable to try certain repair/recovery techniques.
          I recently got a WD20EARS 2TB Drive from a customer in hopes of retrieving data. The drive reads as zero size, I can't hear any head activity but it does appear the platter is spinning I can feel some gyroscopic action picking up the drive.
          As a shot it the dark I bought a donor board and swapped the rom chip. Same issue zero byte drive.
          I'm assuming that the armature is no longer functional internally so no data can...
          05-18-2024, 08:35 PM
        • welcometoo
          acer nitro 5 AN515-55 no display / caps lock
          by welcometoo
          Hi brothers, please i need help diagnose acer nitro 5 no display issue.
          model: nitro 5 an515-55
          motherboard part number: GH51M LA-K862P Rev: 1A
          i received this laptop with a short in power line, it was a capacitor + a mosfet on VCORE line , the laptop turned on cpu and gpu getting warm all voltages seem ok except vcc_gt but no display/caps lock activity also no hdmi out.
          i flashed new bios also ec(ene kb9022) the same result .
          disabled discrete graphics (rtx 3060 ) by cutting its power and shifting a resisror near pch VCC_GT comes but still the same...
          07-05-2025, 11:11 AM
