HP G71 temps widly change
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    So got this top to work on, was for a friends friend so I decided to clean it out, it was bug bombed and a bunch of roaches were inside it. All dead, though. Not as bad as another asus ROG laptop I worked on some time ago that was just full of live ones
    aaanyhoo I decided to upgrade the PDC T4300 to a china bought T8300 Penryn-3M
    updated the bios ahead of time. Saw it fine. Cleaned some real full junk from the heatsink that was 100% covered with a mesh of dust, dirt, dog hair, and cockroach bodyparts
    fan was bad, replaced that too
    got it all ready and the fan ran pretty much all the time either very low, or very high
    hwmon was giving me these crazy temps. at idle, it was about 29c, with fair >50% activity, it jumps to ~70-100c on both cores, and quickly drops back down
    the heatsink was put on, after cleaning both sides with 90% isoprobyl, with a thin nice layer of arctic silver 5, like I do with just about all cpus
    is the thermocouple bad? is the CPU bad? because of the bad fan it was hard for me to tell if it was doing with the clogged heatsink
    is the heatpipe bad? I've never encountered such odd fluctations. Usually with laptops I see either normal temps or solid medium-high ones.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: HP G71 temps widly change
    Swapping back to the original CPU should eliminate that as the cause.
    • piernov
      • Jan 2016
      • 4437
      • France
      Usually if they spike by more than 15°C in less than couple of seconds when applying some load, there is an issue with the heatsink. Not making good contact with the CPU, broken heatpipe or just clearly undersized and saturated so it cannot dissipate any additional power.
      But it can always be a software issue reporting wrong temps, so try to cross-reference with other software.
      CPU itself reporting wrong temp could happen but that'd be very rare. You can still try to put the original CPU back to exclude that possibility as @diif said.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        Yeah found the problem. Put the original cpu in. Worked fine. Put the new one in, also worked fine. Put it back together. Problem again..
        Some nutsack made this heatsink assembly so the cpu plate is pushed down with four springs. I would push fan/fins flush and it would wind up in post. I just spent two hours with just the motherboard in the base frame pushing it down, taking the board out, bending the fins a little, and bending the pipe a little, trying to watch the plate from under the chassis move when I pushed down, listening to the fan spin up or down. This is a terrible design. Why not just bond the fucker to the assembly like everyone else does?
        Found a pic with a good angle. You see this shit?
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          I had to test the damn thing so many times last night and make small adjustments, unplugging the power button so many times, it wore the ffc. When I was going to put it together for the final time today the blue label fell off and it won't stay down. So now I gotta get the button board for it as I can find no ffc at mouser thats 16mm/1mm pitch/10 contact
          • piernov
            • Jan 2016
            • 4437
            • France
            Larger cable and cutting the excess pins would work too.
            If it's just the blue tab and the pins themselves aren't broken, glue it back or use a piece of cardboard to keep the cable in place in the connector.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              I just checked mouser and the closest 178mm, even at different number of contacts us unavailable (not stocked)
              If it's longer I can just bend it but still
              • harp
                Metod for removing glued heatsink from fragile component
                by harp
                I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                06-23-2025, 02:01 PM
              • Ven
                Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                by Ven
                I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                07-08-2024, 09:32 AM
              • harp
                can fanless heatsink replace poor original on RX26PG2
                by harp
                I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                06-25-2025, 10:56 AM
              • Ven
                Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                by Ven
                Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                Issue Description:
                1. CPU Overheating to 100°C
                  • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                  • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                  • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                  • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                  • Thermal
                02-12-2025, 03:57 PM
              • nobbnobb1
                Fixed a Velodyne DPS-12 Subwoofer. Thermal Management + Heatsink Grounding Question
                by nobbnobb1
                I have a Velodyne DPS-12 subwoofer that was making weird noises. Upon taking it apart, I noticed there was yellow glue all over the circuit board which had turned brown, so I scraped it all off and that fixed the problem. I used hot glue instead around the various components.
                There was also one bulging capacitor, and another that must've been in a really hot location because the labelling looked like it was scorched. You can see in the picture the circuit board has discolored over time from this heat. Could either be from the MOSFET (with heatsink), or the resistor....
                09-08-2022, 09:58 PM
