when i close the led screen, don't go to sleep.
  • eng.jaudat
    • Aug 2016
    • 63
    • Palestine
    i have HP 250 G5, i replaced the back cover and hings. and every thing is ok unless i try to close the screen, the laptop still working and not going to sleep.
    i know that should be a sensor some where on the screen to sense the status of the screen. if i close the screen the sensor know that and bring laptop to sleep. if i open the screen the sensor will bring the laptop wake again.
    i'm trying to search but not found any sensor there.
    i was thinking it was software issue, and trying to go to the power options. but every thing there fine.
  • khaahk
    • Dec 2013
    • 766
    • Estonia
    Re: when i close the led screen, don't go to sleep.
    There should have been a magnet glued to the lcd assembly, on the opposite of the laptop there is a hall sensor somewhere. Hall sensor reacts to magnet and laptop knows that you have closed the lid.
    • eng.jaudat
      • Aug 2016
      • 63
      • Palestine
      the magnet glued, you think its on front cover or in back cover?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3592
        • slovakia
        take off screen front plastic and u see the magnet on side of panel
        • eng.jaudat
          • Aug 2016
          • 63
          • Palestine
          Yes, guy's. i solved it. the new cover and hings have no magnet. i added one, then every things goes fine.
          thanx a lot
          • eng.jaudat
            • Aug 2016
            • 63
            • Palestine
            and i attached pics explain every things.
            first to find the location of the sensor i pass an external magnet on the body of the laptop beside the keyboard, until the laptop goes sleep.
            • corrize
              Soldering plastic low profile FPC close camera CMOS sensor ?
              by corrize
              Hello, I will have to solder a very small FPC connector (pins : 0.3mm), on the pcb of CMOS sensor, it is very close. I was surprised by movie on ytb, someone soldering directly with hot air directly on the sensor without kapton, nothing.
              CMOS sensor seems resist to high temps.
              But I also directly saw sensor broken because a blocked motor at the corner became very hot and probably bent the metal frame and cracked the sensor.
              I have low melting point solder.
              I will probably test hot air directly on one of plastic connector (I have a lot) at 320 degree on a test
              07-12-2024, 02:21 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • survivalbloke
              Lenovo Flex 5 14ITL05 - will only sleep if commanded to through start menu>power icon
              by survivalbloke
              This laptop refuses to sleep unless specifically commanded to sleep through Windows. If I close the lid, the screen does go dark just before the lid is closed, so it appears the hall sensor works. However, it will sit there, drawing 1.xx amps until the battery dies. If I command it to sleep, it drops down to normal sleeping current. If I have it sleeping with lid closed and I disconnect the power adapter, it will wake from sleep, even with the lid closed. I have updated the firmware, but still the fault persists. I've also verified power settings in Windows that the device is to sleep when the...
              03-20-2025, 02:29 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
