Need help for battery issue (MAX8731A) on Dell Inspiron 1525
  • SRO2
    • Sep 2018
    • 44
    • FRANCE
    Hello !
    I have a problem with a Dell Inspiron 1525 computer motherboard. The computer refuses to charge the battery, when I am under Windows it says "Plugged in, not charging" and there is no charging indicator light on the front of the computer.
    However, the computer works without the charger when the battery is already charged, and it also works when there is only the adapter connected.
    I charged the battery with another computer and it charges well, so the battery works.
    I have already made some measurements using the motherboard schematic (thanks JaroTech), and I got these measurements when the adapter and battery are connected to the motherboard:
    (See MAX8731A-AdapterBatteryConnected.png)
    Looking at the MAX8731A documentation I think the measured values are correct, but I don't really understand how the MOSFETs that allow the battery charge are controlled...
    I saw that the signal wire AC_IN# that goes to WPC8763LDG switches well from the high logic state to the low logic state when I connect the charger so I think the "computer" detects well that the battery must charge.
    Maybe the problem comes from the battery charge control MOSFETs but I would like to be sure that the values measured on the MAX8731A are good before controlling the MOSFETs (especially since I don't really understand which ones must be "passing" to charge the battery...)
    Thank you in advance for your help!
    See below motherboard schematic, MAX8731A datasheet and measurements on the MAX8731A :
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Need help for battery issue (MAX8731A) on Dell Inspiron 1525
    Test Voltage L14 both sides
    Voltage in battery connector
    • Jesse James
      • Sep 2018
      • 95
      I ran into this many times on Dell 1525 and 1545 and it always turned out to be the charging port. Sometimes it would work with another adapter. Hope this helps
      • SRO2
        • Sep 2018
        • 44
        • FRANCE
        I'll do the measurements tonight and tell you. I have already tried different adapters for this computer, without success.
        I have tried 3 and the one I am currently using for the tests has a blue light ring on the male plug (if this can help).
        Thank you for this feedback anyway!
        • SRO2
          • Sep 2018
          • 44
          • FRANCE
          I measured the voltage on both sides of L14 and there is 11.14V
          I also measured the voltages on the battery connector.
          The voltage of the CLK_SMB pin varies slightly between about 3V-3.20V, but since it is a clock...
          On the other hand, the battery connected to the motherboard has still some autonomy so I don't know if this could be a problem for the measurements.
          • Techtiger
            • Oct 2014
            • 1602
            • france
            BATT_PRS# Signe is missing 3D3V AUX S5 test the R21 470k
            • SRO2
              • Sep 2018
              • 44
              • FRANCE
              R21=414khm
              R22=100ohm
              On the 3D3V_AUX_S5 signal I have 3.315V.
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Originally posted by SRO2
                R21=414khm
                R22=100ohm
                so pin 5 of battery connector 3.3V ?
                • khaahk
                  • Dec 2013
                  • 765
                  • Estonia
                  Pin 5 is probably pulled low by battery to indicate to the ec that it is inserted. It has # prefix, meaning low value is true.
                  From max8731 measurements it is hard to say - the gate driving signals should be looked with oscilloscope. Measure mosfets U8, U7, U5 for low resistance onboard and if unclear result then offboard.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    I think pin 23 & 24 measurement are wrong indicating low side and high side gates of fets are not opening.
                    • Duranitron
                      • Jul 2014
                      • 544
                      • Philippines
                      Hello !
                      just a suggestion. focus on battery charging ic and around it. probably a shorted mosfet or blown coil or fuse. check signal pin of mosfet or replace the mosfet to check it. hope this helps.. try again till you fixed it.
                      Never stop LEARNING because life never stops TEACHING!
                      • SRO2
                        • Sep 2018
                        • 44
                        • FRANCE
                        You advise me to visualize which signals with the oscilloscope?
                        DHI (24); DLO (20) and the gate of U5?
                        Thank you all for your help
                        • SRO2
                          • Sep 2018
                          • 44
                          • FRANCE
                          I visualized the following voltages with the oscilloscope, and they are all direct voltages, without parasites, very clean...
                          U5 Gate=19.6V Source=19.6V Drain=11.4V
                          U8 Gate=11.2 Source=11.6V Drain=19.6V
                          U7 Gate=0V Source=0V Drain=11.8V
                          Everything looks okay, I really don't see what the problem is.
                          I can try to order another MAX8731A but I don't believe in it too much...
                          EDIT :
                          I just realized that the person who gave me the computer had disabled in the BIOS the verification of the adapter... when I reactivated it I got a nice error message at startup..:
                          "The AC power adapter wattage and type cannot be determined.
                          The battery may not charge.
                          The system will adjust the performance to match the power available.
                          Please connect a Dell 65W AC adapter or greater for best system performance"
                          I had tried with several adapters (2 Dell and one generic) and I think none of the adapters I tried are compatible. I'll get a 65W adapter from a Dell 1545 I'll see if it works... I'll keep you informed!
                          I looked for something far too complicated for lack of information I think... as Jesse James said if it turns out it's just a charger problem:/
                          • khaahk
                            • Dec 2013
                            • 765
                            • Estonia
                            If the adapter is ok, then you might have a problem with adapter id circuit, PG38 on schematic. When charging the mosfet driving signals on gate should be impulses of about 25V on high side mosfet and 5V on low side mosfet.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              if you are getting adapter warning msg on startup then very likely you have problem in PS ID line. Look for 33.4 ohm resistor. thats the culprit in most of dell's
                              • SRO2
                                • Sep 2018
                                • 44
                                • FRANCE
                                I get the adapter back tonight so I'll tell you, however I didn't find a "PG38" circuit on the documentation.
                                And for the 33.4ohm resistance what is its designation Rxx ?
                                • SRO2
                                  • Sep 2018
                                  • 44
                                  • FRANCE
                                  I think I found the 33ohm resistor, it seems to be R220 (Page 38/47).
                                  • SRO2
                                    • Sep 2018
                                    • 44
                                    • FRANCE
                                    I've come to give you some news because I've finally solved my problem!
                                    The failure did not come from the adapter or the motherboard, it came from the "powerjack board".
                                    I didn't know that the Dell adapters were communicating with the motherboard via a 1-wire bus (the connectivity in the center of the powerjack), when I saw this I tried to visualize if data was transmitted between the adapter and the motherboard with my oscilloscope but nothing (except noise from the mains voltage...).
                                    Then I checked if there was a connection between the central plot of the powerjack and the connector that goes to the motherboard, and I saw that there was no continuity. So I followed the track from the connector to the powerjack and found a place where it was cut off.
                                    So I restored the contact between the central plot of the powerjack and the corresponding pin on the connector that goes to the motherboard. After briefly reassembling the PC I plugged in the adapter and there was a miracle: the charge indicator lights up, no more error messages when starting, and the battery is charged =)
                                    Thank you all for your advice and help, thanks to that the problem is solved!
                                    Some interesting links:
                                    https://hackaday.com/2014/03/03/hack...dentification/
                                    http://neighborhoodsupport.net/?entr...11005-06383845
                                    • Techtiger
                                      • Oct 2014
                                      • 1602
                                      • france
                                      Thanks SRO2
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • danielsak
                                        Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                                        by danielsak
                                        Hello, I have issue with Dell Inspiron 3542.
                                        Motherboard marking:
                                        Code:
                                        PWB FX3MC REV: A00
                                        The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                                        1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                                        1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                                        10-11-2024, 04:36 PM
                                      • ipatch
                                        dell inspiron 5567 laptop battery lipo WDX0R
                                        by ipatch
                                        recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
                                        1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
                                        2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
                                        got the computer...
                                        04-02-2023, 04:45 PM
                                      • lawrenceptrini
                                        Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
                                        by lawrenceptrini
                                        Hi Guys,
                                        I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
                                        The laptop is working fine with the adapter plugged in and also with a charged battery.
                                        Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
                                        ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
                                        loses its charge, it stays on 0%.
                                        Measurements taken
                                        Charging IC (ISL95522HRZ) 32 pins
                                        Voltage to ground with ac adapter only plugged in:
                                        1)...
                                        08-26-2024, 06:45 PM
                                      • HTR-Informatique
                                        by HTR-Informatique
                                        02-09-2025, 06:51 AM
