Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
dell inspiron 5567 laptop battery lipo WDX0R
  • ipatch
    • Jun 2020
    • 12
    • usa
    recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
    1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
    2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
    got the computer to boot, adjusted the cmos settings to my liking, securely erased the hard drive. now on to my current issue.
    presently i'm dealing with a flashing amber light on the front of the computer. from what i've read this is related to an internal battery. and fortunately/unfortunately this computer was shipped with a 42Wh dell WDX0R lipo battery. i've managed to find the pin outs of the battery via another forum on the internet. however was unsuccessful in finding a JST connector that i could break out from the battery to wire up in a cp2112 adapter i have.
    i need a way to interface with the battery so i can clear PF flag that i'm pretty sure is present, and thus why it's not working with the laptop. it's unfortunate as well because this battery looks brand new. as someone is who is on their 4th lipo battery for the macbook pro late 2013 i have a good eye for visually inspecting a lipo battery and knowing when it needs to be replaced.
    i feel that the PF flag got enabled because this laptop sat for an extended period of time without being charged thus the battery went into an unrecoverable state if i had to guess.
    either way i ordered a spare battery cable for this battery via ebay so i can hack at the current one that i have in an attempt to make a breakout connection to interface with.
    curious if anyone knows a JST connector for this style of battery, or if one even exists. i used my calipers to measure the pitch of the pins, and they appear to be the same pitch as a JST PH which is a 2.0mm pitch, however my PH connectors were still too big to interface with this battery.
    also curious to know if anybody here has successfully reset one of the batteries.
    i'll try and update this thread if i can clear the PF flag, and pull some information from the BMS.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • danielsak
    Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
    by danielsak
    Hello, I have issue with Dell Inspiron 3542.
    Motherboard marking:
    Code:
    PWB FX3MC REV: A00
    The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
    1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
    1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
    10-11-2024, 04:36 PM
  • lawrenceptrini
    Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
    by lawrenceptrini
    Hi Guys,
    I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
    The laptop is working fine with the adapter plugged in and also with a charged battery.
    Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
    ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
    loses its charge, it stays on 0%.
    Measurements taken
    Charging IC (ISL95522HRZ) 32 pins
    Voltage to ground with ac adapter only plugged in:
    1)...
    08-26-2024, 06:45 PM
  • HTR-Informatique
    Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
    by HTR-Informatique
    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
    I also changed the screen because the PC fell and the screen was broken.
    I changed the battery with a new and original battery.
    I also had corrosion/oxidation on the...
    02-09-2025, 06:51 AM
  • mohamed mm
    DELL Inspiron 15 3567 not powering with battery
    by mohamed mm
    Hello Everyone, I hope you are all doing well,
    I have a Dell laptop, Inspiron 15 3567, it's only powring up with the adapter not with the battery, but after it's on I can remove the adapter It works fine with the battery, so only the problem is it does not start with the battery even if its attache with the laptop.
    battery condition is excellent and the adapter is original, both are detected in the bios. ( sometimes a laptop doesn't start until I disconnect the battery and reconnect it again), I have updated the bios but nothing has changed.
    Here's my reading with...
    08-05-2023, 07:08 AM
