Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • BlueMidnight
    • Jan 2015
    • 489
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    You are welcome.
    • rccrasher65
      • Mar 2014
      • 599
      Thanks again, if any body comes across another board cheap please let me know.
      • rccrasher65
        • Mar 2014
        • 599
        Originally posted by rccrasher65
        I have a Hp Probook G3 MoBO DAX73AMB6E1 Rev E charge light blinking, and no power up.Hoping someone can walk a noob through the diagnostic process. I think I have found the correct schematics, but they are a complete greek to me. will try to get some pics and add schematics to this post. thanks again for the help. George
        BlueMidnight, my laptop shit the bed again, need your help once again! same symptoms as stated before, laptop just shut off while using, and nothing once again. I moved and still unpacking, so in a week or so we can start. thanks again, George
        • rccrasher65
          • Mar 2014
          • 599
          bump
          • rccrasher65
            • Mar 2014
            • 599
            bump
            bump
            • BlueMidnight
              • Jan 2015
              • 489
              Hello again. It took me a while to see your messages because I've been doing other things.
              The best course of action is to start at the beginning, testing voltages and resistances to ground as per the instructions here and here (noting that there's a typo where I meant to say PQ9 instead of PQ6).
              Once we have an idea of what voltages you do and do not have, and if any power rails are shorted, we can go from there.
              • rccrasher65
                • Mar 2014
                • 599
                ok, its going to take a week or so, to get all my equipment unpacked from our recent move, purchased a new home and was in the process of moving when computer shit the bed again. Very disappointed in HP, will never purchase another one/ I will get some measurements for you in a week or so thank you again for your help, George
                • rccrasher65
                  • Mar 2014
                  • 599
                  I found some of my equipment, so i'll be able to open up my laptop in a day or so, and get those tests done. Thanks!
                  • rccrasher65
                    • Mar 2014
                    • 599
                    Going to pull laptop apart this evening, should have some test results in a day or so.
                    • rccrasher65
                      • Mar 2014
                      • 599
                      bump.
                      • rccrasher65
                        • Mar 2014
                        • 599
                        Disassembly and tests tonight, will post results.
                        • rccrasher65
                          • Mar 2014
                          • 599
                          Well finally got all my equipment set up. now I can get busy on this laptop. Thanks for your patience!
                          • BlueMidnight
                            • Jan 2015
                            • 489
                            Alright, good luck
                            • rccrasher65
                              • Mar 2014
                              • 599
                              Thanks for your patience, moving was a tiresome event, finally got most of my equipment unpacked,and set up. Going to break down laptop tonight. should have some results for you in a day or so. Again thanks for all your help. Fixing this POS board is becoming a monthly event.
                              • rccrasher65
                                • Mar 2014
                                • 599
                                Well, I have some results. unfortunately I might have taken my laptop apart for nothing. When I checked voltages on power supply connector, I wasn't getting 19V, so I checked my power adaptor,and its not giving me 19v. Readings are all over the place. going to look for a new power supply. Any suggestions as to where to get an original, and not a POS chinese replacement!
                                • BlueMidnight
                                  • Jan 2015
                                  • 489
                                  This best place to get a genuine HP AC adapter would be their parts store: https://parts.hp.com/Hpparts
                                  Alternatively, you can try to find a used one from eBay or somewhere. But counterfeit ones can sometimes look very much like the real thing. Or sometimes the picture is of a genuine one, but you get a generic. I'd recommend finding a low-volume private seller with a high feedback rating. I'm wary of sellers who have dozens/hundreds of "genuine" adapters available.
                                  • rccrasher65
                                    • Mar 2014
                                    • 599
                                    Back ordered, but they give a list of suppliers, I found one in Pa. TKO industries, waiting for their quote. Have another board that does not shut down properly, its not the settings either, boards works other than that, have to remove battery to shut off completely. I will attach a pic of light, as I do not know what it is called. Going to dig out board in a few days while I wait for power adapter.
                                    • rccrasher65
                                      • Mar 2014
                                      • 599
                                      Ordered from TKO 50+10 shipping for an original.
                                      • rccrasher65
                                        • Mar 2014
                                        • 599
                                        Power adaptor should arrive on Mon. Will re check everything, hopefully I broke down my laptop for nothing.
                                        • rccrasher65
                                          • Mar 2014
                                          • 599
                                          Original power adaptor on back order, should be here in 4 days, Finally, Tired of this slow toshiba backup laptop.
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • someonenotyou
                                            HP ProBook 445 G7 no POST only on battery
                                            by someonenotyou
                                            Hi.
                                            I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                                            When I attach DC Jack, the laptop will charge the battery and switch on.
                                            And now the strange part:
                                            1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                                            2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                                            06-30-2025, 01:24 AM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
